08-13-2019, 01:07 PM
official vendor
official vendor
Sherpa Equipment Company - 5th Gen
Located on the front range of Colorado, we are a couple of adventure-seeking, Toyota loving, videographers. On our travels, we needed a rack that would live up to the workload of our adventure video production. We were traveling with large amounts of equipment and camping gear but had a very little place to store it. We found that the rack systems available on the market left us sacrificing either strength or modularity. We set out to combine all of the features we wanted into one rack system. We are now pushing to create new products that are both strong and affordable so you can worry less and explore more. We have brought the same great quality to the 5th Gen 4runner Market
PRODUCTS
Drawer Systems (Coming Soon)
WHAT SETS US APART
QUALITY MATERIALS
Our rack systems are made with aircraft-grade aluminum and stainless steel hardware, worrying about rust is a thing of the past. While our competitors are using thinner materials, we believe in keeping our side plates thick to prevent issues with bowing. Each rack side plate is cut from 1/4” 6061 to stand up to even the toughest loads.
MOUNTING
Our racks use a rubber spacer to form a seal between our rack and your roof. We believe you shouldn’t have to glob on silicone just to make sure you don’t end up with water in your roof. Mounting our racks requires zero modification to your vehicle.
HANDLES
Gaining access to the equipment on your roof can often be the most frustrating part of using a roof rack or basket. We build handles right into the side of our racks to eliminate the issue and give you quick access to your gear.
ADAPTABLE
Our crossbars are designed to move to accommodate whatever spacing necessary for mounting your equipment. It's never been easier to mount your tents, awnings, and more. Simply loosen a couple of bolts and slide away.
08-13-2019, 02:26 PM
Just checked your site for the 5th gen version. It would be cool if you added a couple cut outs to install work lights in addition to those hand holds.
Build thread
08-13-2019, 06:47 PM
official vendor
official vendor
Originally Posted by mscot
Just checked your site for the 5th gen version. It would be cool if you added a couple of cut outs to install work lights in addition to those handholds.
As nice as cut-outs would be for those that want to run flush-mounted lights on the side, we also want to be able to cater to those that like the clean look of having no cutouts. Though a great feature for nice side lighting to keep it clean, we have had great luck using products from Extreme Led and Baja Designs to get a similar result without the use of cutouts.
This all comes down to keeping our lead times short and providing to the masses.
08-13-2019, 09:24 PM
Looks like an improved Prinsu. If I didn't already have my Prinsu I would certainly consider this rack as the foot mounts are a better design and the modularity of the rack is much more user friendly. I think you will do well with these. Hopefully you offer some sort of forum and military/veteran/first responder discount as well.
08-13-2019, 10:48 PM
Banned
Banned
$879, until you select no light bar , then it jumps to nearly $1100...why?
08-13-2019, 11:10 PM
You're paying for the fairing and powder coat. I think that the fairing should be included with the base price.
08-14-2019, 12:19 PM
official vendor
official vendor
$879, until you select no light bar, then it jumps to nearly $1100...why?
We offer a no fairing option for those that do not want a fairing. The price does not update until you have selected all the options. So yes, nearly $1100 with a fairing and black powder coat.
08-14-2019, 12:22 PM
official vendor
official vendor
We definitely do offer Mil/First Responder discounts! Just need to get in contact with us. We worked very hard to make an extremely strong and easy mounting solution. Not having to glob silicon all over your truck was a must for us.
08-14-2019, 12:43 PM
Banned
Banned
Ahh, makes sense now.
I was like, damn these guys will make a killing selling racks for $879 with a fairing and black powdercoat. But at $1,100 it just another aluminum extrusion rack option at a similar price point.
curious to see what happens to lead times...
08-14-2019, 01:07 PM
Real Name: Jesse
Real Name: Jesse
Can you please post some pics of the front mounting foot location. I want to make certain that the front mounting feet sit on the rubber part of the roofs rain gutter. Also just want to verify that the fairing doesn't touch the paint.
_____________________________________________
2016 Trail-P Dobinsons 302/325 DK Chromoly, 285 kO2, C4, RCI, BD Squad Sport, XD Phillips HID's, Tint, Husky liners, Crestone Rack
2020 Gx460
2000 Limited 4X4 - OME 881/890- B&M 70264
Overland Bound #10926
08-14-2019, 01:22 PM
How much does your roof rack weigh? I looked on your website but didn’t see it.
2020 MGM TRD Off-Road Prem
08-14-2019, 03:11 PM
That reply makes no sense. You have cut outs all over the rack. I don't see the utility in 4 hand holds, 2 or 3 would be more than enough if placed at the right locations. You could easily convert a hand hold to a work light cut out or you could make the hand holds work for either a hand hold or a work light.
Build thread
08-14-2019, 03:20 PM
Just buy an SSO, you get stronger crossbars, stronger crossbar mounting point (3 dedicated holes vs a long slot), and light cut outs.
08-14-2019, 03:53 PM
Yeah. Was looking to support a CO company when I can.
Build thread
08-14-2019, 05:50 PM
Pricey option here but check out upTOP Overland. They make Al2+ extrusion racks as well but they add a few wrinkles that make it a little unique, more functional, and more than just another also-ran. They also have a lot of accessory mounts as well. They're from Castle Rock, CO if that matters.
upTOP™ Alpha 4R - 2010+ 4Runner 5th Gen NO DRILL – upTOP Overland
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
