mark@eibach
Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
Old 08-04-2020, 11:07 AM #211
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
Yes Prolee,
Looking good. I’m definitely leaning that way for my AG Pro. I hope I can fit 285’s on my SCS wheels and clear the front.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 01:58 PM #212
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Originally Posted by ProLee View Post
As promised the springs are installed, not going into detail on “how to”....plenty of videos on how to replace them. Tried my best to dial in the measurements but it was 100 degrees and I was trying my best to get it done quickly and efficiently as possible. So here are the measurements and pictures. I apologize for the upside down and sideways pictures, not sure why it’s doing that?
Before:
From the ground
Front Left 35 1/8
Front Right 35 1/4
Rear Left 36 5/8
Rear Right. 37
From the center wheel(Which was hard to find center)
Front Left 20 1/2
Front Right 20 5/8
Rear Left 22
Rear Right 22 3/8
After:
From the ground
Front Left 37 1/4
Front Right 37
Rear Left 38
Rear Right 38 1/4
From center wheel
Front Left 22 1/2
Front Right 22 1/2
Rear Left 23 1/4
Rear Right 23 1/4
Will measure again when I put more miles on it and see where the final numbers are. Overall the front seems to be about a 2” lift and the rear is set at 1”.
Looks good. The most accurate way to measure is fender to the bottom of your rim. Then measure diameter of the rim and divide by 2. Subtract 1/2 of that diameter and that will put you smack dab center Everytime without an error for eyeballing it
ForRun is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 02:03 PM #213
ForRun's Avatar
ForRun's Avatar
Originally Posted by RusPro17 View Post
Yes Prolee,
If his center hub measurements are accurate that's exactly the height I have on my orp. Pros already get the liner tuck at port so your set up front. I had minor rub on mudflap but a heat gun molded it out of place and zero rub now.
My rims are 17x8 4.5 backspace and zero offset
Old 08-04-2020, 02:55 PM #214
pumacat24's Avatar
pumacat24 pumacat24 is offline
pumacat24 has a spectacular aura about pumacat24 has a spectacular aura about
pumacat24's Avatar
Thank you sir!
You mean, mam... and you're welcome! Can't wait to hear about ride quality and your thoughts, etc!
2019 TRD Pro | IG: @trdprocat | RSG Sliders | Falken Wildpeak AT3W | Morimoto/XD LEDs | CTX Tint
past: '18 4Runner TRD ORP... RIP, Kaiyo!
'07 4Runner SE... SOLD
'02 4Runner SR5 4WD... SOLD
pumacat24 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 04:05 PM #215
ProLee's Avatar
ProLee ProLee is offline
ProLee will become famous soon enough ProLee will become famous soon enough
ProLee's Avatar
I apologize...thank you Sunshine! Will update on the ride quality next week after it settles a little bit more. As of now it does seem to ride stiffer but with a little bit more noticeable noise dive, may be due to the center of gravity now that it sits higher.
I was also able to get side by side shot with my Nephew's stock 19 ORP. Hopefully it will give you guys a better reference on the lift.
Eibach needs a stock TRD PRO in SoCal-img_2890-jpg  Eibach needs a stock TRD PRO in SoCal-img_2891-jpg  Eibach needs a stock TRD PRO in SoCal-img_2892-jpg
ProLee is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 04:11 PM #216
Real Name: Don
Real Name: Don
By the pics Prolee,
It’s definitely a noticeable difference.
Old 08-04-2020, 04:56 PM #217
pumacat24's Avatar
pumacat24's Avatar
It is interesting that you are experiencing a more noticeable nose dive. I'm wondering if this is because it lifts the shock into a different place on the internal bypass, because it's still 600 lb spring and not a bit stiffer, or both?
I also wonder how much it will settle after driving it for a while.
Currently, I can't do anything financially due to a cut in work (thanks, COVID), but am really interested in putting the 13" Icon 650# in the front for just a 1" lift and the matching Eibach 1" in the rear.
Anyway, thanks for sharing so far, it looks great!
Old 08-04-2020, 09:29 PM #218
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
By the pics Prolee,
Looking forward to installing mine...they finally showed up today.
ProLee, i'm guessing there was no issue installing on the two different perch heights on the FOX's?? The springs are clearly identical in height.
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 10:07 PM #219
Johnnyg182 Johnnyg182 is offline
Johnnyg182 will become famous soon enough
ProLee: looks good!
My fronts arrive 8/10. Need to decide on UCAs so I can order the rest. Keep flip flopping on SPCs due to reading about bushing and ball joints needing replacement with fairly low miles. Really like the look and so called low maintenance Dobinsons UCA. Decisions....
Can’t wait to get the parts and do the install.
Hope others post pics as they get their spring on!
Johnnyg182 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 11:44 PM #220
ProLee's Avatar
ProLee's Avatar
AMLOR
It was straight forward....no issues. I did it without a spring compressor. Took the old springs out and put the new one in with a helper to guide the shock back in.
Old 08-04-2020, 11:47 PM #221
ProLee's Avatar
ProLee's Avatar
Originally Posted by Johnnyg182 View Post
ProLee: looks good!
I haven’t thought about UCAs yet...looking at my axles it doesn’t look too bad. Alignment is set up for this Saturday, I’ll let you guys/gals know how it turns out.
Old 08-05-2020, 09:03 AM #222
ctrporsche ctrporsche is offline
ctrporsche is on a distinguished road
Looking good!
ctrporsche is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 09:24 AM #223
Real Name: Don
Real Name: Don
I ordered mine yesterday at Eibach.
Old 08-05-2020, 10:14 AM #224
peekaboo peekaboo is offline
peekaboo is on a distinguished road
My main thing with a lift and new tires is going to be making sure it still fits in the garage.. anyone have this kind of worry/problem or am I over reacting?
peekaboo is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 08:15 PM #225
Real Name: Kirk
Real Name: Kirk
Interesting...no spring compressor. I have one to use since I will be doing this solo. Wifey cant break any nails don't you know...
Also I will be installing SPC UCa's on mine. With the spacer and all the weight I have on the front, (just shy of 200lb) I figure 2.2 - 2.3 inches once everything settles.
Since this is a DD, I want all the adjustment I can get.
Thank you Sir!!
Amlor
eibach , pro , prototypes , stock , weeks
FS: 5th Gen 2010-18 Eibach Pro Lift Springs - Diamond Bar (SoCal) - $260 obo racerdre For Sale: Suspension/Wheels/Tires 10 01-27-2020 09:59 PM
New guy in Socal from Eibach Ryan at Eibach New Members 3 02-05-2019 02:23 PM
TacomaBeast's West Coast Bound @ Eibach Meetup (SoCal) June 16th ScarfaceT4R 5th gen T4Rs 2 05-01-2018 07:05 PM
Toytech eibach out of stock? blackbuzzard 3rd gen T4Rs 11 05-24-2012 10:50 AM
