mark@eibach
Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
Old 08-06-2020, 10:22 AM #226
Thedirtrunner Thedirtrunner is offline
Thedirtrunner is on a distinguished road
Eibach needs a stock TRD PRO in SoCal
Currently on a road trip and woke up around 4:30. I was cruising the thread and came accross this one. Thanks Mark for stepping in to answer some questions. Good luck Ryan at your new job. So now I need to buy some springs. Thanks all for making me spend money. Lol
Also waiting for settled measurements and confirmation of 285’s. Do you still need the uca to make them fit without rubbing?
Thedirtrunner is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 09:28 PM #227
D4Krunner's Avatar
D4Krunner D4Krunner is offline
D4Krunner is on a distinguished road
D4Krunner's Avatar
Eibach springs front and rear with 285/70/17 Ridge Grapplers. Have spidertrax 1.25 spacers installed too. Had some slight rubbing at times on fender liner and mud flap that a heat gun fixed for now. Quick eye ball measurement with stock tires.
Stock tires before
From ground
FR 35 1/4
FL 35
RL 36 3/4
RR 37
From hub
FR 20 3/4
FL 20 1/2
RL 22
RR 22 3/8
Stock tires after
From ground
FR 37
FL 36 3/4
RL 37 1/2
RR 38
From hub
FR 22
FL 21 3/4
RL 22 1/2
RR 23
Eibach needs a stock TRD PRO in SoCal-85ce992e-e069-4de8-aa77-bab97e0d6140-jpg  Eibach needs a stock TRD PRO in SoCal-57b88706-83c4-44c5-89e0-47de2efa1e76-jpg
D4Krunner is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 09:54 AM #228
JustATallDude JustATallDude is offline
Real Name: Alex
JustATallDude will become famous soon enough
Real Name: Alex
Stock tires before
From ground
FR 35 1/4
FL 35
RL 36 3/4
RR 37
From hub
FR 20 3/4
FL 20 1/2
RL 22
RR 22 3/8
Stock tires after
From ground
FR 37
FL 36 3/4
RL 37 1/2
RR 38
From hub
FR 22
FL 21 3/4
RL 22 1/2
RR 23
Did you have to do any kind of BMC? I'm hoping to not have to do that but still go with 285s
JustATallDude is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 10:10 AM #229
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
I’m waiting on my springs. When you say a heat gun you heat the inside wheel well and push it in more? I know some guys remove the mud flaps.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 05:54 PM #230
ProLee's Avatar
ProLee ProLee is offline
ProLee will become famous soon enough ProLee will become famous soon enough
ProLee's Avatar
Quick 1 week update....had the alignment done on Saturday and the best we can get on the caster was 2.9. Drives straight and handles well with this setting, eventually I will be upgrading to JBA UCA to reach the spec of 4.0 just for the sake of it and for better articulation.
Ride quality on road has improved, didn't notice how it was before but with these springs the truck shows little or no body roll on sharp turns and four leaf exits on the highways. Truck also rides a lot stiffer in a positive way, no more of the cushy feel that was starting to bug me. I think there was a thread on here about some other members stating the same ride quality after owning their Pro's for a certain amount of time.
Also was able to hit the same trail before the swap this Sunday but didn't notice any major improvements other than a stiffer ride and the shocks handling small bumps better. I'm no expert but it seem to rebound quicker and better? Maybe other more experienced off roaders can chime in on this.
ProLee is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 06:00 PM #231
ProLee's Avatar
ProLee's Avatar
You have exactly what my next 2 mods are going to be 285's and Spidertrax, thank you for the info. Have you done any flexing/articulation while turning to see if we'll have to do a BMC?
Old 08-11-2020, 02:19 AM #232
K4Run K4Run is offline
K4Run is on a distinguished road
Incoming
IMG-2422 — ImgBB
Install Date Booked. 8/26/2020. Pictures coming soon.
Eibach Pro Front Springs - PRO-LIFT-KIT Springs (Front Springs Only)
Eibach Rear Load Leveling Springs - LOAD-LEVELING SYSTEM (Rear) (For +250lbs of Added Weight)
4x 1/4" Coachbuilder Strut/ Coilover Shims - Coachbuilder Strut / Coilover Shim (Provides 1/2” of lift per shim) Tacoma/4R – Shop Coachbuilder
Durobump Dront Bump Stop - DBF212 - DuroBumps Front Bump Stops - 03+ 4Runner/05+ Tacoma/FJ Cruiser/GX
285/75/17 BFG AT K02 - BFG KO2 285/75R17 - Best BFGoodrich KO2 285/75R17 Reviews & Prices | 4WP
SPC UCA's - https://throtl.com/products/spc-cont...hoCAgoQAvD_BwE
Diff Drop. - https://www.dobinsonsdirect.com/prod...and-fj-cruiser
Prinsu Full Rook Rack - https://prinsudesignstudio.com/produ...ull-non-drill/
Nashfabco Ladder - https://www.nashfabco.com/product-pa...h-gen-4-runner
- 2019 TRD PRO
K4Run is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 09:42 AM #233
Real Name: Don
Real Name: Don
Looks good your plan. Couple questions with the shims added to the front won’t it be much higher than the rear? Also do you think you need the diff drop or just adding it incase. The reason I’m asking waiting on my springs to come. Making sure on all this before I have the install done. I just noticed your going with different springs for the rear. Ok. Thanks.
Old 08-11-2020, 12:16 PM #234
The Dobinson diff. drop only lowers it by 1/2" even though they are larger spacers. I don't think its 100% necessary but its pennies in the bucket to reduce the angle of the cv axle.
Ya, i got different springs for the rear. The total lift should be 2.6" front/ 2.5" rear to keep some rake. If needed later on i could remove a shim and adjust the rears for a more level look. I'm f'n pumped though, counting the days!
- 2019 TRD PRO
Old 08-11-2020, 05:23 PM #235
jamoc jamoc is offline
Real Name: DeLo
jamoc is on a distinguished road
Real Name: DeLo
Any reason you chose SPC over JBA, Dobinsons, etc. for your UCA?
Installing basically the same setup BTW. Thank you for your recommendations for the front shims and bump stops!!
jamoc is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 06:08 PM #236
I'm no expert, I just like SPC's design better. The control arm seems more robust, the ball joint has more articulation, and it has slightly more available caster/camber for better alignment.
- 2019 TRD PRO
Old 08-11-2020, 06:26 PM #237
Real Name: DeLo
Real Name: DeLo
Cheers, good luck with build!
Old 08-11-2020, 08:11 PM #238
D4Krunner's Avatar
D4Krunner's Avatar
I don’t think BMC will be necessary. My caster matched right at 3.0*. The mud flaps may have to come off and I need to trim the bumper a little more than what the factory did. It rubs the mud flap every once in a while, and rubs the bumper every time I back up and turn on left and right sides. So far I agree with what you said about the ride and handling.
Old 08-11-2020, 08:35 PM #239
Johnnyg182 Johnnyg182 is offline
Johnnyg182 will become famous soon enough
K4Run: we are going for a pretty similar setup. I ordered eibach Fronts, Dobs 1/4” top mount spacers, SPCs, Dobs C59-505 1.5” rear springs, and getting 285/75/17 KO2s, 255/80/17 Wildpeak spare for underneath. Planning to do spidertraxx and tires on stock wheels.
Fronts arrive tomorrow. The rest should get in early next week. Pumped!
Curious how you are thinking you’ll get 2.6” front lift. Was thinking the eibach springs would settle out at 1.6” as advertised. This is why I got the shims to add 0.5” to get a total of 2.1”. Are people finding that the springs aren’t settling and are staying at 2” lift?
Johnnyg182 is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 12:20 AM #240
That sounds like a nice setup too! Post pics when you can.
I spoke with the guys at Coachbuilder and they said you can use a up to two 1/4" coilover shims per side with longer studs and bumpstop extensions so I am going to give it a try. It's similar to what the Toytec spacer kit does. They replace the front spring perch with a thicker one that preloads the spring a little and also use a coilover shim (top plate spacer w/ longer studs). One 1/4" shim is supposed to provide 1/2" of lift per the manufacturer.
Eibach (1.6") + Two 1/4" Shims per side (1") = 2.6"
Coachbuilder Strut / Coilover Shim ( Provides .50” of lift ) Tacoma/4R – Shop Coachbuilder
4RPROFX - Toytec Lift Kit for TRD Pro 4Runners (with OEM Fox Suspension)
- 2019 TRD PRO
eibach , pro , prototypes , stock , weeks
FS: 5th Gen 2010-18 Eibach Pro Lift Springs - Diamond Bar (SoCal) - $260 obo racerdre For Sale: Suspension/Wheels/Tires 10 01-27-2020 09:59 PM
New guy in Socal from Eibach Ryan at Eibach New Members 3 02-05-2019 02:23 PM
TacomaBeast's West Coast Bound @ Eibach Meetup (SoCal) June 16th ScarfaceT4R 5th gen T4Rs 2 05-01-2018 07:05 PM
Toytech eibach out of stock? blackbuzzard 3rd gen T4Rs 11 05-24-2012 10:50 AM
