Originally Posted by DallasTRDPro
OK. I called my alignment shop and they recommended having the tires installed.
Yes.285’s has to be installed before alignment, but I suggest you drive for ~ 1000 miles just the way it is ( let it settle) and then install new tires. As for the caster? If you don’t have aftermarket UCA’s, your shop won’t be able do much about caster.Let’m try as high as can. Good luck!!!
