12-30-2020, 01:23 PM
#466
Real Name: James
Real Name: James
Originally Posted by mark@eibach
what we need is the part numbers for both the spring and damper assembly. If they are in fact Tacoma assemblies, we need to test drive / test heights our tacoma springs on the 4R.
Hey Mark, I took a look the other day and didn’t see any numbers stamped on the springs or shock individually, but I did see a part number stamped on the lower spring perch. The part number matches that found in the tsb. Here are photos of the dealer repair order and the part number found on the front driver side assembly. Please let me know if there are any other places I should look to find a part number.
01-01-2021, 02:47 PM
#467
Any updates on existing back order fulfillment for springs? I see Summit is now quoting February for new pre-orders.
01-02-2021, 12:34 AM
#468
Real Name: Bryan
Real Name: Bryan
I just ordered an Eibach Pro Truck Lift from Wheelers.....they sent me an Email stating that i should expect shipment in early Fedruary....
01-03-2021, 06:43 PM
#469
Originally Posted by Sp00ner
I've got a set of the Eibach's on backorder, and can definitely notice the slight clunk when it's cold out at low speeds. Mainly just backing out of the driveway/garage.
Anyone know if this is any sort of an issue beyond 'the small clunk annoys me'? Like... what is the clunk?
I'm in the same situation. If it's just a clunk and nothing harmful, I'll probably go ahead and install springs.
In the case I get the TSB work completed, would I be able to swap out the springs for ones that will fit the new shocks? I ordered directly from Eibach.
Sent from my SM-G981U using Tapatalk
01-03-2021, 09:10 PM
#470
Now that we've had some chunky ice and snow on the ground, the sound is making me a bit nuts.
Thinking the best approach is to kill off my backordered set and go in and get the TSB work done and review my options once Eibach has reviewed theirs.
RCI Sliders & TRD Integration, Transmission and Transfer Case Skids
Eibach TRD Pro Lift, 285/70/17 KO2s
TRD Intake, ARB Breathers
Pioneer 8500NEX
01-04-2021, 12:43 PM
#471
Good News! We are discussing special pricing for those who are currently using our springs and receive the TSB!
At a minimum, you'll need to provide proof of purchase and your service records with matching customer information.
More details once we get everything finalized for production.
2014 TRD OR, DCSB: Eibach / Magnuson / Nitto / WARN / ARB / Hella / Fifteen52 / Dirt King / Pelfreybilt / Autometer / Pelican / Switchpros
01-04-2021, 12:57 PM
#472
That's helpful, thank you.
Unfortunately, this part number does NOT match the 2020 Tacoma which is PTR61-35201. That doesn't mean the dimensions aren't the same, but without any part numbers on the springs themselves it requires having something in hand to measure.
01-13-2021, 01:56 PM
#473
Im getting the shock update done tomorrow, any update on the '21 spring info?
Be great if the Tacoma one happened to work.. but can see why Eibach would want to make sure and get it right.
01-15-2021, 05:56 PM
#474
Does Eibach offer discount codes to forum members?
01-20-2021, 03:39 PM
#475
Real Name: James
Real Name: James
Hey Mark, any new updates?
01-28-2021, 03:26 PM
#476
@ mark@eibach
......Any update?
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
02-01-2021, 08:05 PM
#477
Originally Posted by matoolie
Negative.
We need one with a TSB installed here ASAP. Can't do anything correctly without it.
Help us find a SoCal local willing to leave us their rig a couple days!
02-01-2021, 08:15 PM
#478
Negative.
I gotta believe the Venn diagram of SoCal locals and Customers with installed TSB parts doesn't have much overlap, given the conditions required conditions to recreate the issue...
Pioneer 8500NEX
02-01-2021, 08:21 PM
#479
Negative.
2021 Pro would suffice too correct? Have you put word out on other forums?
Really hoping for this kit when I eventually get my 21 Pro.
Michael
02-01-2021, 10:57 PM
#480
Negative.
its going to be hard to find a TSB in SoCali
you guys just need a 21 Pro because thats what they are replacing it with right
18 FunRunner
