mark@eibach
Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
Old 03-01-2020, 09:06 AM #76
Steel28 Steel28 is offline
Steel28 is on a distinguished road
Originally Posted by osideplayer View Post
The 19/20 Toyota TRD Pro’s are essentially TRD Off Road’s with added wheels, badges and suspension at the port. Don’t believe, open the driver door of any trd pro and read the spec label. It will incorrectly show the trd off roads' wheel dimensions instead of the TRD pro wheel dimensions
So yes, the Elbach lift will give you an added 2.6 inches of total lift from what the Toyota 4Runner was originally designed to handle.
Personally, I think an additional 1 inch of lift would have been perfect. 1.6 inches is a weird number that will definitely give negative rake on the TRD pros. Its going to force most people to buy rear coils to preserve a leveling look.
I imagine that was the point though, cross selling.
Interesting...
2017 Super White TRD Pro - SOLD
2020 Army Green TRD Pro
Steel28 is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 02:30 PM #77
Classified's Avatar
Classified Classified is offline
Classified is on a distinguished road
Classified's Avatar
I never mentioned where they were bolted on, and that doesn't change anything being discussed here either way.
It seems you do agree on everything I did mention though, and that's exactly the issue. If these springs add the 1.8" (now revised to 1.6" in another thread) to our current lift settings as was stated, that leaves us at 2.8" (now 2.6") total lift into our IFS. It seems generally accepted from everything I've seen on this forum and pretty much everywhere else, that UCAs are recommended over 2", and pretty much a necessity over 2.5" although opinions do vary on this subject, which is somewhat contrary to Ryan's post about no UCAs required depending on where you draw line (or how it affects your ability to align properly).
Clearly there is confusion here about exactly what we are getting, and how much lift we'll end up with, which is important to know. Personally, I am fine with having 2.6" overall and don't mind replacing my UCAs if necessary to get it provided the Fox shocks work well set up this way, but the result needs to be clear and it doesn't seem to be at this point as some folks have pointed out and inquired about.
I agree completely about the 1.6" in the front and rake angles. I'd want to bring up the rear a similar amount as well, as I personally would prefer to keep the rake as it is or only slightly lessened as I always keep a fair amount of gear in the back and tow frequently. I'd rather it have the rake on the rare occasion that I'm not loaded in the rear, as opposed to having the front high the majority of the time as it would be if I was "leveled"...
Classified is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 09:38 PM #78
ArmyTRDPro ArmyTRDPro is offline
ArmyTRDPro is on a distinguished road
Eta on being able to order these?
ArmyTRDPro is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 10:19 AM #79
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Coming from Jeeps, I know exactly what lifting does to a vehicle. The Jeep could be lifted about 2" without any caster correction. If you lift a Jeep 3+ then you have all kinds of steering components that need to be addressed. I bought the Pro because I didn't want to touch the suspension. I admit I would like it to be about another inch taller with some 275's. Since this Eibach is another 1.6" higher I can't see how that wouldn't affect alignment and other components. Lifting a Jeep seems way less complicated than adding a lift to an IFS.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 10:49 AM #80
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
It definitely will.. and I still dont really understand "1.6 inches" as it doesn't even level it. There's definitely some corners being cut to push this product out faster.
osideplayer is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 10:53 AM #81
I will wait until Eibach starts selling it before I begin questioning it. More than likely I will stay with the stock suspension anyway, but I'm still interested in seeing what Eibach has to offer.
Old 03-04-2020, 11:56 AM #82
Its either cross selling or cutting corners to push a product out. Either way one thing is for sure, this product wasn't designed in the best interest of the consumer.
Old 03-04-2020, 02:08 PM #83
MGordo MGordo is offline
MGordo has a spectacular aura about MGordo has a spectacular aura about
From Ryans posts, it was meant to be paired with their rear 1" lift coils..
If you are looking for a smaller lift there are several other options:
-Cornfed/Westman spacers
-Icon/Fox/Elka 13" 600/650lb coils. This will give you ~0.8" lift.
MGordo is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 04:29 PM #84
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
Just don't buy it. Simple as that.
We've been in the suspension business for 65 years. If we cut corners we wouldn't be in business.
We've spent hours and hours on R&D, made various prototypes, dyno'd the shocks multiple times and we're also the OE spring supplier for the PRO. You're getting your info from forums and google. You just asked me two months ago if the PRO had different clips in the front and now you're the expert....
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 04:45 PM #85
official vendor
official vendor
While we are it here's another Eibach product for your PRO that osideplayer will hate
Being able to adjust your ride height in the rear is ridiculous, right? This will certainly ruin a PRO...
Eibach needs a stock TRD PRO in SoCal-runner-rear-jpg
2019 TRD Off Road
2007 GT3
1982 911 SC
Old 03-04-2020, 04:46 PM #86
That's how I feel.
Old 03-04-2020, 05:45 PM #87
Never said I was an expert, but I do own the the TRD fox shocks and I love the way they ride on my vehicle.
You are so dramatic man lol
Old 03-04-2020, 05:47 PM #88
Any chance you will be able to post the shock dyno with comparison to stock springs?
Old 03-04-2020, 05:54 PM #89
official vendor
official vendor
You generally don't dyno shocks with springs installed.
2019 TRD Off Road
2007 GT3
1982 911 SC
Old 03-04-2020, 06:08 PM #90
official vendor
official vendor
When you accuse us of cutting corners I'm going to get very dramatic. Jump in the spacer thread if you want to to talk about cutting corners.
2019 TRD Off Road
2007 GT3
1982 911 SC
eibach , pro , prototypes , stock , weeks
FS: 5th Gen 2010-18 Eibach Pro Lift Springs - Diamond Bar (SoCal) - $260 obo racerdre For Sale: Suspension/Wheels/Tires 10 01-27-2020 09:59 PM
New guy in Socal from Eibach Ryan at Eibach New Members 3 02-05-2019 02:23 PM
TacomaBeast's West Coast Bound @ Eibach Meetup (SoCal) June 16th ScarfaceT4R 5th gen T4Rs 2 05-01-2018 07:05 PM
Toytech eibach out of stock? blackbuzzard 3rd gen T4Rs 11 05-24-2012 10:50 AM
