Originally Posted by RusPro17
Looks good your plan. Couple questions with the shims added to the front won’t it be much higher than the rear? Also do you think you need the diff drop or just adding it incase. The reason I’m asking waiting on my springs to come. Making sure on all this before I have the install done. I just noticed your going with different springs for the rear. Ok. Thanks.
The Dobinson diff. drop only lowers it by 1/2" even though they are larger spacers. I don't think its 100% necessary but its pennies in the bucket to reduce the angle of the cv axle.
Ya, i got different springs for the rear. The total lift should be 2.6" front/ 2.5" rear to keep some rake. If needed later on i could remove a shim and adjust the rears for a more level look. I'm f'n pumped though, counting the days!
