mark@eibach
Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
Old 08-12-2020, 11:12 AM #241
ProLee's Avatar
ProLee ProLee is offline
ProLee will become famous soon enough ProLee will become famous soon enough
ProLee's Avatar
Originally Posted by D4Krunner View Post
I don’t think BMC will be necessary. My caster matched right at 3.0*. The mud flaps may have to come off and I need to trim the bumper a little more than what the factory did. It rubs the mud flap every once in a while, and rubs the bumper every time I back up and turn on left and right sides. So far I agree with what you said about the ride and handling.
Thank you for the info....
ProLee is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 08:41 PM #242
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
Originally Posted by K4Run View Post
I spoke with the guys at Coachbuilder and they said you can use a up to two 1/4" coilover shims per side with longer studs and bumpstop extensions so I am going to give it a try. It's similar to what the Toytec spacer kit does. They replace the front spring perch with a thicker one that preloads the spring a little and also use a coilover shim (top plate spacer w/ longer studs). One 1/4" shim is supposed to provide 1/2" of lift per the manufacturer.
Eibach (1.6") + Two 1/4" Shims per side (1") = 2.6"
Coachbuilder Strut / Coilover Shim ( Provides .50” of lift ) Tacoma/4R – Shop Coachbuilder
4RPROFX - Toytec Lift Kit for TRD Pro 4Runners (with OEM Fox Suspension)
Please let us know how this works for you.
I have the SPC UCA's also and a .400 Cornfed Suspension single top hat spacer to complete the front end. Rough guess...2.3-2.4" of lift over stock.
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 07:41 PM #243
bbphoto's Avatar
bbphoto bbphoto is offline
bbphoto is on a distinguished road
bbphoto's Avatar
Eibach spring lift installed w/275 wildpeaks
Eibach needs a stock TRD PRO in SoCal-59d6afa5-e5e3-4bf9-9405-070ad436bb07-jpg
bbphoto is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 08:33 PM #244
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Like it should look from the factory.
2022 4 Runner SR5 Premium--For Sale:ConsoleVault safe, HikeIt throttle controller
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 09:36 PM #245
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
Looks good. Waiting to have my AG done also. How was the alignment afterwards. Or did you change your upper control arms? Thanks.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 06:18 PM #246
Kingships Kingships is offline
Kingships will become famous soon enough
Just had mine installed, added 1.6" in front and 1" in rear as advertised. Stock UCA, alignment seems perfect even with wheel spacers. Couldn't be happier, but now i need bigger tires.
Eibach needs a stock TRD PRO in SoCal-image0-6-jpg
Super White '19 TRDP, Eibach Lift Kit Springs F/R, Durobumps F/R, Spidertrax 1.25", TRD CAI, Shrockworks Sliders, DRZ Stealth 27" Light Bar, Baja Ladder, Canvasback liner, Ultimate camping mod, Accessorides Remote Start
Kingships is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 12:10 AM #247
Real Name: Don
Real Name: Don
So far it seems everyone doing the Eibach springs have not needed to change there UCA’s. Wonder how much caster some guys are getting.
Old 08-21-2020, 12:25 AM #248
Looks awesome. I really wish white was available when I needed my Pro. What size tire are you going with??
Old 08-24-2020, 12:00 AM #249
Saturnine90's Avatar
Saturnine90 Saturnine90 is offline
Saturnine90 is on a distinguished road
Willing to share more photos? Im considering the 275 wildpeaks over 285. Looks great in that pic.
Saturnine90 is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 05:38 AM #250
Real Name: Don
Real Name: Don
Yeah I agree it definitely helps with different angle picture shots.
Old 08-24-2020, 01:15 PM #251
peekaboo peekaboo is offline
peekaboo is on a distinguished road
Beautiful - what I intend my set up to be.. AG and all. Thank you for sharing! I'd love to hear pros/cons.
peekaboo is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 05:14 PM #252
Real Name: Don
Real Name: Don
My install in 2 weeks will be done.
Old 08-24-2020, 05:15 PM #253
Looking forward to more than one pic.
Old 08-24-2020, 06:35 PM #254
Real Name: Don
Real Name: Don
I like posting pics DallasTrdPro!! I will post a couple with different angle shots. I’m also going to leave my Pro wheels on till I get it lifted with stock size tires and do some measurements with the tires turned and see if I can compare with my SCS wheels I will be putting on to see the difference with any rub. Then if I decide to add 285’s down the road I will be able to see if I’m going to clear.
Old 08-24-2020, 07:16 PM #255
Looking forward to it.
eibach , pro , prototypes , stock , weeks
FS: 5th Gen 2010-18 Eibach Pro Lift Springs - Diamond Bar (SoCal) - $260 obo racerdre For Sale: Suspension/Wheels/Tires 10 01-27-2020 09:59 PM
New guy in Socal from Eibach Ryan at Eibach New Members 3 02-05-2019 02:23 PM
TacomaBeast's West Coast Bound @ Eibach Meetup (SoCal) June 16th ScarfaceT4R 5th gen T4Rs 2 05-01-2018 07:05 PM
Toytech eibach out of stock? blackbuzzard 3rd gen T4Rs 11 05-24-2012 10:50 AM
