mark@eibach
Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
Old 09-24-2020, 10:57 AM #376
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Originally Posted by DallasTRDPro View Post
When I get this aligned, should I have my 285's already installed?? Also, do I want them to just go for the highest caster numbers they can get??
OK. I called my alignment shop and they recommended having the tires installed.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 11:08 AM #377
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
Yes.285’s has to be installed before alignment, but I suggest you drive for ~ 1000 miles just the way it is ( let it settle) and then install new tires. As for the caster? If you don’t have aftermarket UCA’s, your shop won’t be able do much about caster.Let’m try as high as can. Good luck!!!
ax2021 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 12:07 PM #378
mark@eibach's Avatar
mark@eibach mark@eibach is offline
mark@eibach will become famous soon enough
Before
After
Before
After
Must say I'm a bit biased, but that looks perfect. Thanks for the thorough Before / After shots.
2014 TRD OR, DCSB: Eibach / Magnuson / Nitto / WARN / ARB / Hella / Fifteen52 / Dirt King / Pelfreybilt / Autometer / Pelican / Switchpros
mark@eibach is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 12:08 PM #379
It will be perfect with a 285 tire.
Old 09-24-2020, 02:00 PM #380
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
Just a curious question out to any one. Why are the 285’s need to be put on before alignment is done. Is it because of clearance? Thanks.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 02:05 PM #381
MicrowaveOven MicrowaveOven is offline
MicrowaveOven is on a distinguished road
Eibach needs a stock TRD PRO in SoCal
Almost looks like it gives a negative rake, but I think all “leveling” done on these rigs looks that way. Front fender gap should be less, unless you’re in an E36 M3 Eibach needs a stock TRD PRO in SoCal
Sent from my iPhone using Tapatalk Pro
MicrowaveOven is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 05:27 PM #382
No. Even if you go with same size of the tires you had before, tires first and then alignment . It just works that way.
Old 09-24-2020, 05:31 PM #383
Real Name: Don
Real Name: Don
I still have my stock tires on. Going in for the state inspection and first oil change and alignment since Eibach prints were installed. Put over 300 miles on them. Thanks.
Old 09-24-2020, 05:45 PM #384
It definitely good idea since you touched your suspension components. I do my alignment like once a year as maintenance, just makes my tires last longer and better driving overall.
Old 09-24-2020, 05:53 PM #385
Real Name: Don
Real Name: Don
Yeah that’s why I waited to put some miles on first before the alignment. I would like to add 285’s now but trying to hold off if I can. Working on some other ideas if they pan out. Thanks.
Old 09-24-2020, 07:32 PM #386
Now with the 285 Falkens. They look way better in person. I have some rubbing while backing up. If I didn’t have spacers I don’t think I would rub.
2022 4 Runner SR5 Premium--For Sale:ConsoleVault safe, HikeIt throttle controller
Old 09-25-2020, 12:18 PM #387
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
PSA: These just came back into stock on Eibach's website if anyone is looking for them (were out of stock for a few weeks). Just ordered a pair this morning.
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
Old 09-26-2020, 05:29 AM #388
Before I go hacking up the bumper, I'm going to remove my spacers today and see if that will help with the rubbing. I checked the space between the UCA's and I have at least 2" of space so I know rubbing won't be an issue once removed. I will report back later today.
Old 09-26-2020, 09:45 AM #389
So I removed my spacers today and now there is zero rubbing anywhere. So glad I didn’t have to hack up my bumper. I actually prefer the more tucked in tire look. Now the tires are almost flush with the fenders.
Old 09-26-2020, 01:33 PM #390
Real Name: Don
Real Name: Don
Looks good DallasTrdPro!! Just curious question why with tires pushed out cause rubbing? Now I’m concerned my 8.5 inch wheels the tires will rub.
eibach , pro , prototypes , stock , weeks
FS: 5th Gen 2010-18 Eibach Pro Lift Springs - Diamond Bar (SoCal) - $260 obo racerdre For Sale: Suspension/Wheels/Tires 10 01-27-2020 09:59 PM
New guy in Socal from Eibach Ryan at Eibach New Members 3 02-05-2019 02:23 PM
TacomaBeast's West Coast Bound @ Eibach Meetup (SoCal) June 16th ScarfaceT4R 5th gen T4Rs 2 05-01-2018 07:05 PM
Toytech eibach out of stock? blackbuzzard 3rd gen T4Rs 11 05-24-2012 10:50 AM
