mark@eibach
Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
Old 10-01-2020, 05:37 PM #406
Flea7907 Flea7907 is offline
Flea7907 will become famous soon enough
Anyone with a low pro and a winch or an heavier front bumper running this setup?
Flea7907 is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 04:47 PM #407
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
Just had my 285’s installed today. Added the Nitto Ridge Grapplers. Loving the look.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 04:52 PM #408
Real Name: Don
Real Name: Don
Here is some pics. Added my SCS wheels and no rubbing. Removed front mudflaps. Planning on adding the Rockbloz flaps.
Old 10-09-2020, 05:03 PM #409
Real Name: Don
Real Name: Don
Another.
Old 10-09-2020, 08:16 PM #410
Horizon Horizon is offline
Horizon is on a distinguished road
So I got the Rokblokz mudflats because I did not want to have any clearance issues. The problem is that my rear passenger flap started to warp and look shiny close to the TRD Pro exhaust. Ended up contacting them and they send me two new ones for 10 dollars shipping. I ended up just cutting the warped area off the original and matched the other side. Hope that helps
Horizon is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 08:26 PM #411
Real Name: Don
Real Name: Don
Thank Horizon, Yeah the thing I don’t like about the Toyota oem flap. I removed my Tacoma ones years ago when I had it and put the Rockbloz on. The Toyota ones cut into the paint and rub. The back don’t seem to do that. I only see marks on my front one. But thanks for the info.
Old 10-09-2020, 08:30 PM #412
For sure. That was another major consideration for changing them for me as well. Now that the Rokblokz’s are modified I like how they look and no more warping and much better than no flaps at all I scored and snapped with a blade and sanded the edges after. Happy with the end result.
Old 10-09-2020, 08:39 PM #413
Real Name: Don
Real Name: Don
You also have the Rockbloz on the front correct? So if I get the Rockbloz I will need to do that to the rear correct?
Old 10-09-2020, 08:44 PM #414
Yes I installed them in front and back. And yes I would recommend cutting prior to installing them at the back to avoid the warping. I cut the bottoms so they are just below the exhaust and cut the sides where the warping happened on the right side. It’s where the exhaust hits the flap when it exits the exhaust.
Old 10-13-2020, 02:00 AM #415
Kidwonder's Avatar
Kidwonder Kidwonder is offline
Kidwonder is on a distinguished road
Kidwonder's Avatar
The set is out of stock on Eibach's site, have to call to place order.
Looking to add sliders & aluminum skids to our 2020 Pro. Anyone have these springs with these mods? @RusPro17 appears to have sliders.
Curious how the added weight impacts these springs. I have wanted to eliminate the rake and have the Westcott kit bookmarked but really want to avoid spacers.
Kidwonder is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 02:40 AM #416
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
I'm running them with a full set of RCI aluminum skids (including the gas tank skid) and Victory 4x4 Blitz aluminum sliders (around 70 pounds). I had the springs installed at the same time as all of the armor and did not grab before and after measurements (which I should have in retrospect), but I definitely am leveled out pretty nicely and the lift is still noticeable.
Honestly, the only thing that I think could push you back towards rake with this lift would be a relatively heavy front bumper setup. I need to grab some pictures; have not had a good opportunity to get any as stuff just went on last Thursday.
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 08:03 AM #417
Real Name: Don
Real Name: Don
So far I have been very happy with the spring lift. My 285’s clear with no issues rubbing. Also note I’m running 8.5 inch wheel also. My Tyger steps look like sliders but technically there not. But they have held up very well. They really protect the side of the 4runner especially parked next to someone. They really help to prevent door dings. If you talk to any mechanic most will tell you the springs are the better way to go than spacers.
Old 10-13-2020, 02:36 PM #418
Kidwonder's Avatar
Kidwonder's Avatar
Thank you ! I was recently on Victory’s website but didn’t notice they made aluminum sliders. I will check them out.
Old 10-13-2020, 02:38 PM #419
Kidwonder's Avatar
Kidwonder's Avatar
Hadn’t thought about door ding protection. That is worth the cost for decent steps or sliders.
Old 10-13-2020, 02:51 PM #420
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Only if its from cars. Most SUV's are tall enough to clear them. Well maybe not with the Eibach springs and 285's.
DallasTRDPro is offline   Reply With QuoteReply With Quote
eibach , pro , prototypes , stock , weeks
FS: 5th Gen 2010-18 Eibach Pro Lift Springs - Diamond Bar (SoCal) - $260 obo racerdre For Sale: Suspension/Wheels/Tires 10 01-27-2020 09:59 PM
New guy in Socal from Eibach Ryan at Eibach New Members 3 02-05-2019 02:23 PM
TacomaBeast's West Coast Bound @ Eibach Meetup (SoCal) June 16th ScarfaceT4R 5th gen T4Rs 2 05-01-2018 07:05 PM
Toytech eibach out of stock? blackbuzzard 3rd gen T4Rs 11 05-24-2012 10:50 AM
