mark@eibach
Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
Old 08-11-2022, 12:40 PM #646
3Lions66 3Lions66 is offline
3Lions66 is on a distinguished road
Trying to figure out the height difference with this suspension mod + 285's...I currently have 5 inches of space between the garage door opening and the top of my Pro roof rack. Calculating the new height, I will be adding 0.6" inches from the lift over stock setup plus the difference in tire diameter from the 265's to 285's. Anything else I need to add into that calculation for the new ride height?
3Lions66 is offline   Reply With QuoteReply With Quote
Old 08-13-2022, 08:12 PM #647
MP486 MP486 is offline
MP486 is on a distinguished road
Hi All, I am not very car savvy and I’m not able to tell if I have the TSB#0094-20 update on my ‘20 TRD Pro. I live in SoCal so it’s hard for me to identify the clunking noise due to our warm weather. But since I’ve had the 4Runner, I never heard any clunking noise.
I took a photo of the front spring and I’m wondering if this is enough to identify if I have the update. I really want to purchase Eibach TRD Pro lift..
Eibach needs a stock TRD PRO in SoCal-img_4044-jpg
MP486 is offline   Reply With QuoteReply With Quote
Old 08-14-2022, 09:34 AM #648
crawlingjunk's Avatar
crawlingjunk crawlingjunk is offline
crawlingjunk will become famous soon enough crawlingjunk will become famous soon enough
This isn’t updated strut
crawlingjunk is offline   Reply With QuoteReply With Quote
Old 08-14-2022, 11:04 AM #649
Thank you!
Old 08-29-2022, 01:42 AM #650
Prado150 Prado150 is offline
Prado150 is on a distinguished road
mark@eibach stupid me ordered the pre tsb springs and I need the post tsb 2021+ front springs. The vendor will refund but will cost $90 for return shipping — any chance you can help if I send back front springs to Eibach directly?
Prado150 is offline   Reply With QuoteReply With Quote
Old 08-30-2022, 06:07 PM #651
Zal4R Zal4R is offline
Zal4R is on a distinguished road
Overall, my rack went up a little over an inch, since it is mostly in the back. The 285s will add another inch or inch and a half, depending on brand etc. You may want to change out the UCAs to be able to fit the tires better with more caster as well. I am still sitting at 22 from hub to front fender on both sides and 23 in the back. So, it gave me a a little over an inch over my stock. I am running rock sliders and a full set of aluminum skids as well.
Zal4R is offline   Reply With QuoteReply With Quote
Old 08-31-2022, 01:32 PM #652
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
285s will add 1/2" over 265s as a general rule. Only half the increase in diameter is below the axle at any one time
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 08-31-2022, 09:51 PM #653
Yeah, my bad. I always go high.
Old 02-07-2023, 11:25 AM #654
MTDJS MTDJS is offline
MTDJS is on a distinguished road
Put the Eibach springs on with 750 mile on the odometer. Very very happy with the ride quality and 285 KO2's fit with zero trimming. I do get very minor rubbing if I'm turning at lower speeds and hit a bump (for example, hitting the driveway with a little speed), but not enough to even bother trimming as it's a rare occurrence.
Before/After
MTDJS is offline   Reply With QuoteReply With Quote
Old 03-01-2023, 11:33 AM #655
So, I have had a front strut fail and am trying to determine the cause. Has anyone else had an issue with this and the Eibach Springs? I have not seen anything and am still doing research on the cause, but thought I would ask.
Old 03-02-2023, 12:14 AM #656
Added the Eibach springs along with 275/70R17 Wildpeaks. Went with the 275's as I wanted to stay within the recommended tire size with the Pro wheels so I have no issues airing down and I didn't want to trim. Also added the Prinsu full rack. Loving the look!
Eibach needs a stock TRD PRO in SoCal-img_1675-jpeg  Eibach needs a stock TRD PRO in SoCal-img_1663-jpeg  Eibach needs a stock TRD PRO in SoCal-img_1662-jpeg
Old 03-23-2023, 08:44 PM #657
tls3601 tls3601 is offline
Real Name: Tom
tls3601 will become famous soon enough tls3601 will become famous soon enough
Real Name: Tom
So how would airing down be a problem with 285’s on Pro wheels? Have two friends with Pro’s, neither experiencing any issues. More sidewall is a good thing off road.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
tls3601 is offline   Reply With QuoteReply With Quote
Old 09-28-2023, 10:24 AM #658
Ramonesg Ramonesg is offline
Ramonesg is on a distinguished road
Did you install front and back?
Does it feels much different than stock springs?
Before/After
Ramonesg is offline   Reply With QuoteReply With Quote
Old 11-24-2023, 04:30 PM #659
TyGuy40 TyGuy40 is offline
TyGuy40 is on a distinguished road
Eibach Springs
Just got a used 2020 TRD Pro. Want to put on 33s (285/70/17s KO2s)
It has about 45k miles on it. I was also going to inquire about re-building the Fox Shocks, but what's the current verdict on these Eibach springs on stock Fox struts? I do off-roading mainly in Colorado, doing some high mountain passes (Imogene Pass, etc.). Not heavy bouldering. But I wanted to try to avoid rubbing, etc. I know I can cut some things, but I would rather not if I can avoid it. Should I also consider a different UCA? Or would these springs do the trick?
Many thanks, and apologies if this has been asked 3k times. New here.
TyGuy40 is offline   Reply With QuoteReply With Quote
Old 11-25-2023, 11:03 AM #660
like2lean's Avatar
like2lean like2lean is offline
like2lean is on a distinguished road
like2lean's Avatar
That's the kit I used, no UCA needed. I wanted to stay with 265 but have plenty of room. Easy install no spring compressor needed either, caster will be a bit lower but drives perfect.
like2lean is offline   Reply With QuoteReply With Quote
eibach , pro , prototypes , stock , weeks
FS: 5th Gen 2010-18 Eibach Pro Lift Springs - Diamond Bar (SoCal) - $260 obo racerdre For Sale: Suspension/Wheels/Tires 10 01-27-2020 09:59 PM
New guy in Socal from Eibach Ryan at Eibach New Members 3 02-05-2019 02:23 PM
TacomaBeast's West Coast Bound @ Eibach Meetup (SoCal) June 16th ScarfaceT4R 5th gen T4Rs 2 05-01-2018 07:05 PM
Toytech eibach out of stock? blackbuzzard 3rd gen T4Rs 11 05-24-2012 10:50 AM
