Old 08-19-2019, 05:28 PM #1
93civEJ1's Avatar
93civEJ1 93civEJ1 is offline
93civEJ1 is on a distinguished road
93civEJ1's Avatar
Bad ball joint?
Ive got a new to me 4runner, and it has a toytec boss kit on it with SPC UCA. Ive got a clunk sound that happens (not all the time) when going over bumps on the passenger side. Ive looked around and tried to chase anything that is loose, but cant find anything. My only suspect is maybe the SPC UCA balljoint as it seems to have a lot of grease below to boot on it compared to the one of the driver side. I dont know if maybe this one just has too much and it pushes out, or if the joint is bad and that is leading to my clunk. Is there a way to tell if its the joint that is making the noise? I am super irritated trying to chase this clunk down and dont want to replace the joint prematurely if it is not the source.
93civEJ1 is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 05:35 PM #2
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Pretty normal for the grease to come out. Better that it is coming out than it is to be dry. How long has the UCA been on the 4Runner? If it is used, maybe the previous owner didn't grease the joint enough and then when he realized it wasn't enough he filled it up to try and solve an issue that came up because of neglect? Are the shocks silver? Maybe the shocks aren't for the BOSS and they are too short so they extend until it maxes and that makes the thump? Does the thump occur going down or up?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 08-19-2019, 05:57 PM #3
93civEJ1's Avatar
93civEJ1's Avatar
Actually I am not sure if it is up or down. It just bumps in the road when driving. The struts are silver, as expected though because this is the kit:
TTBOSS-4R210 - ToyTec BOSS Suspension System for 10+ 4Runner and GX460
Old 08-19-2019, 08:33 PM #4
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie has a spectacular aura about Teamoatmealpie has a spectacular aura about
Grease your UCA every oil change with the correct moly infused grease-
Your prob have SPC UCA as that is commonly what Toytech pairs with their Boss kits.
But if you have the clunk and need check for worn BJ its pretty easy.
Teamoatmealpie is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 07:39 AM #5
93civEJ1's Avatar
93civEJ1's Avatar
Thanks for this video. I am leaning to this being my issue.
Old 08-20-2019, 08:29 AM #6
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Worn sway bar bushing will give the sound you describe. i chased the noise around forever and when I replaced mine and clunk was gone. Easy and cheap to rule out.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
bad , chase , clunk , joint , side
Should I get new ball joint boots, ball joints, or UCA's? Rishi3 4th Gen T4Rs 7 05-25-2017 04:28 PM
Leaking Upper Ball Joint - Replace UCA's or Just the Ball Joint tannerk15 4th Gen T4Rs 4 03-28-2017 08:53 AM
Front Upper Ball Joint - replace arm or joint? dleeallen 4th Gen T4Rs 7 02-05-2016 12:14 AM
Leaking CV Joint or Ball Joint?? Hard to Tell - Pics Inside 4WDFTW 4th Gen T4Rs 21 11-06-2014 05:46 PM
Ball Joint or CV Joint r32 Maintenance/Detailing 1 03-20-2008 12:09 PM
