05-25-2017, 04:02 PM
Real Name: Dave
Real Name: Dave
Phone/Tablet mounts
I am considering purchasing mounts for my iPhone 7+ and iPad Pro 9.7. I have looked at the Proclip line and they appear to possibly be a bit light in the event of even easy off roading particularly for the iPad. The Ram mounts look strong enough but a bit cludgy and quite large. These mounts will be going into a Limited so kind of prefer they don't look too "boy racer" like. The tablet mount could be removable but the phone mount would stay in the truck. I am an old f&rt so don't get too wild with the 4R, mostly got it due to snow around this area and a few photo trips. Do the pro-clamps work okay? Are there any suggestions of other brands I should look into? I have done Google search and received about 230,000 hits many of which look to be really cheap junque. Thanks for any suggestions.
2017 Blizzard Pearl Limited
Redwood guts
Gone but not forgotten:
2015 Attitude Black 4Runner Trail
05-25-2017, 04:18 PM
I made one out of some rod and plate that extends off of the seat mount and has a ram mount on top for adjustability. It doesn't even wiggle when offroading. Took me about an hour to put together. Check out my build thread for pics
Sent from my SM-G950U using Tapatalk
14' 4runner SR5 4x4, Baja Designs Squadron Amber Fogs, Dual Battery, Icon Extended travel CO, Icon tubular UCA's, RCI Skids, Custom Sliders, Icon 2.5 RR Shocks, OME 2895e, custom aluminum cargo area, Dometic 50 fridge, front runner fridge slide. Relentless fabrication LOPRO, Expedition one rear bumper with swingout. Build Thread
05-25-2017, 04:51 PM
Did you goggle search here ? At least 7 pg of posts about !!
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
05-25-2017, 05:02 PM
Here's an interesting idea or two
Tablet mount over head unit
2022 SR5 Premium 4WD
05-25-2017, 06:09 PM
Real Name: JB
Real Name: JB
I had a Proclip iPhone mount in my FJ. It was rock solid.
2014 Trail Premium KDSS
06-01-2017, 11:51 AM
Are you doing this for use map with map applications? If so what map applications are you using?
06-01-2017, 12:14 PM
2017 4Runner Limited 2WD
08-18-2019, 07:12 PM
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
