Help removing tow hooks, SSO Slimline, 2017 TRP Pro
(Im new to the forum, if this should be on the Problems and Warranty Forum I will move it)
I have a 2017 TRD Pro, Southern Offroad Slimline front bumper. I'm trying to remove the tow hooks to have them painted but there are locked (likely rust). I've tried the usual (hitting both with PB Blaster, yarding hard on them with a screwdriver in the pin hole) but no luck. Afraid to torque too hard on it and somehow damage the bumper itself.
Any ideas would be greatly appreciated!
Reason: Added photo
If you have a hammer drill or impact see if you can attach it to the "bolt head" end and zip it off. Or air hammer the flat end while trying to turn the other end to see if that breaks stuff loos enough to spin. It needs some tappy and spinny action at the same time to break loose.
Air hammer on the end while trying to twist it. Need hammer time while twisting like Samwhich said. If you don't have an air hammer...id say blow torch if you are good with one. If not you will probably mess the powder coat up.
__________________ IG: ksotrdpro
2015 Inferno Red TRD Pro | Piaa Platinum LED Headlights | Shrockworks Dual Battery Relocator | National Luna Dual Battery Kit | Optima Yellow Top | SPOD SE | ARB Air Compressor | Rago MSP | Expedition Essentials T4RPAM | C4 Fab Rock Sliders | C4 Fab Dual Swing Rear Bumper | Frontrunner Slimline II Rack | KC C-Series Lightbar | Cooper Discoverer STT Pro 285/70/17 | Dobinson C59-701V | Fox 2.5 Shocks with Remote Resi and DSC | ProComp 2.25" Front Spacer
2011 Salsa Red TE, KDSS, Running boards (not sure what to replace these with), Weathertec mats, Canvasback cargo liner, BudBuilt skid plates, full set of Billy 5100s, Light Racing UCAs, Toytec Ultimate front coilovers (with the "correct" 5th gen 5100s), SAW 1.5 rear coils, ScanguageII...
