Old 08-15-2019, 02:44 PM #1
molokai_4Runner molokai_4Runner is offline
molokai_4Runner is on a distinguished road
Help removing tow hooks, SSO Slimline, 2017 TRP Pro
(Im new to the forum, if this should be on the Problems and Warranty Forum I will move it)
I have a 2017 TRD Pro, Southern Offroad Slimline front bumper. I'm trying to remove the tow hooks to have them painted but there are locked (likely rust). I've tried the usual (hitting both with PB Blaster, yarding hard on them with a screwdriver in the pin hole) but no luck. Afraid to torque too hard on it and somehow damage the bumper itself.
Any ideas would be greatly appreciated!
Help removing tow hooks, SSO Slimline, 2017 TRP Pro-img_1318-jpg  Help removing tow hooks, SSO Slimline, 2017 TRP Pro-img_1319-jpg
molokai_4Runner is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 05:02 PM #2
samwhich's Avatar
samwhich samwhich is offline
samwhich will become famous soon enough samwhich will become famous soon enough
samwhich's Avatar
If you have a hammer drill or impact see if you can attach it to the "bolt head" end and zip it off. Or air hammer the flat end while trying to turn the other end to see if that breaks stuff loos enough to spin. It needs some tappy and spinny action at the same time to break loose.
| - 2016 Turd Bro - |
SSO Slimline / x20 | Dobinsons 314/327 - Airlift 1000 | Gobi Stealth Rack W/ Ladder | Dobinsons Snorkel | All Pro Sliders | Shrockworks Rear Bumper | 285 BFG KO2
samwhich is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 05:07 PM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm is a glorious beacon of light Inv4drZm is a glorious beacon of light Inv4drZm is a glorious beacon of light Inv4drZm is a glorious beacon of light Inv4drZm is a glorious beacon of light
MY GARAGE
Inv4drZm's Avatar
MY GARAGE
Large breaker bar/long crescent wrench and lots of torque on the right side.
Or drill out the bolt from the left side.
Torch it if only because you are angry at this point and want to see it melt into a puddle.
2005 4R Sport 4WD "The last of the V8s!" - Dirty Deeds 20" SS Exhaust - Icon 2.5 Resi's. - 1.5" BL - SCS SR8's - 35's - Dana 60 - Build Thread
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 05:37 PM #4
Mutant138's Avatar
Mutant138 Mutant138 is offline
Real Name: Tobias Fünke
Mutant138 is a splendid one to behold Mutant138 is a splendid one to behold Mutant138 is a splendid one to behold Mutant138 is a splendid one to behold Mutant138 is a splendid one to behold Mutant138 is a splendid one to behold
Mutant138's Avatar
Mall crawling strikes back.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 06:53 PM #5
kso818 kso818 is offline
kso818 is on a distinguished road
Air hammer on the end while trying to twist it. Need hammer time while twisting like Samwhich said. If you don't have an air hammer...id say blow torch if you are good with one. If not you will probably mess the powder coat up.
Could maybe find a long thick punch/pry bar that tapers down small enough to fit into the whole. Something like this...https://www.google.com/search?rlz=1C1GCEV_en&biw=1707&bih=846&tbm=shop&ei=huFVXc7bEqKp_Qb85rqwCg&q=long+punch+pry+bar&oq=long+punch+pry+bar&gs_l=psy-ab.3...5242.9740.0.9879.0.0.0.0.0.0.0.0..0.0....0. ..1c.1.64.psy-ab..0.0.0....0.4a5tEIR8g2k
Then put a pipe over it and use some torque.
IG: ksotrdpro
2015 Inferno Red TRD Pro | Piaa Platinum LED Headlights | Shrockworks Dual Battery Relocator | National Luna Dual Battery Kit | Optima Yellow Top | SPOD SE | ARB Air Compressor | Rago MSP | Expedition Essentials T4RPAM | C4 Fab Rock Sliders | Frontrunner Slimline II Rack | CVT Mt. Shasta Pioneer | KC C-Series Lightbar | Cooper Discoverer STT Pro 285/70/17 | ARB 3" Medium Duty Rear Coil | ProComp 2.25" Front Spacer
kso818 is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 06:55 PM #6
boyguan boyguan is offline
boyguan is on a distinguished road
fyi the bolts are only suppose to be finger tight, use a zip tie to tight it onto the shackle.
boyguan is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 01:20 PM #7
GREAT forum and THANKS to all the helpful replies. I'll give those suggestions a shot and report back. And yes, I have my torch ready as a last resort
Old 08-16-2019, 02:16 PM #8
Mutant138's Avatar
Mutant138's Avatar
You're welcome.
Old 08-16-2019, 03:11 PM #9
STLDAVE's Avatar
STLDAVE STLDAVE is offline
STLDAVE is on a distinguished road
STLDAVE's Avatar
Righty tighty, lefty loosey, lol.
2011 Salsa Red TE, KDSS, Running boards (not sure what to replace these with), Weathertec mats, Canvasback cargo liner, BudBuilt skid plates, full set of Billy 5100s, Light Racing UCAs, Toytec Ultimate front coilovers (with the "correct" 5th gen 5100s), SAW 1.5 rear coils, ScanguageII...
STLDAVE is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 03:19 PM #10
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman will become famous soon enough
I would throw a cloth/towel between the D-ring and the bumper to protect it, put a screwdriver through the hole, and whack it with a rubber mallet.
2015 SR5 Premium | SSO Slimline Bumper | 20" Lightbar | 10K LB Smittybilt Winch | 275/70/17 KO2
ryguytheman is offline   Reply With QuoteReply With Quote
bumper , forum , hard , pro , trp
***Southern Style OffRoad - Summer of 2017 - Slimline Hybrid group buy*** SouthernSS Group Buys 253 01-27-2019 09:20 AM
###Southern Style OffRoad 4Runner Slimline Group Buy / Fall 2017 ### SouthernSS Group Buys 92 12-07-2017 09:17 PM
DECEMBER 2017 ELLIS PRECISION GROUP BUY - Closes Oct 31st, 2017 Ellis Precision Group Buys 2 10-28-2017 07:35 PM
Does Removing the Lower Grill Insert Require Removing the Bumper? Bluesky 07 4th Gen T4Rs 5 06-03-2016 07:24 AM
I wish we had tow hooks Falls 4th Gen T4Rs 67 12-27-2007 09:59 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
