Old 11-21-2020, 07:10 PM #31
Camping4R Camping4R is offline
Camping4R is on a distinguished road
The code isn’t working for me. Is it only in effect on cyber Monday itself ?
2020 SR5 Premium • Super White
BF Goodrich KO2 285/70R17 • TRD Wheels • AnytimeBackup Camera • VLEDs Interior • Gobi Stealth Rack
Camping4R is offline   Reply With QuoteReply With Quote
Old 11-22-2020, 04:46 PM #32
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
Thank you for the heads up. The Complete Kits were not yet activated.
All Good to Go Now!!
_
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 07:26 PM #33
** Limited Stock - Ready to Ship **
Bundle 3 - Part #Gen5-ICON-2.5-Bundle-3
- Part #58747C, 2.5 Coilover, Extended Travel, w/Res, w/Adjuster
- Part #57810CP, 2.5 Rear Shocks, w/Res, w/Adjuster
- Part #58451DJ, Delta-Joint Upper Control Arm (UCA)
- Part #52800, 3" Rear Coil
Order Today - Click Here
_
Old 02-03-2021, 11:01 PM #34
Elephant_Turd's Avatar
Elephant_Turd Elephant_Turd is offline
Elephant_Turd is on a distinguished road
I was checking out your site...do you have any of the king shocks available for 2017 trd pro? Looking for options...
Instagram: single_shade_of_grey
Elephant_Turd is offline   Reply With QuoteReply With Quote
Old 02-04-2021, 10:18 PM #35
Check out our KING Complete Kits Thread - Click Here
_
Old 02-05-2021, 08:27 PM #36
_
Hey, are they in stock though? I'm getting a lot of backorder info regarding these sets.
Thanks!
Old 02-05-2021, 10:41 PM #37
NM...didn't see the 14-16 week timeframe post until just now. What do you have in stock currently for the 17 pro, if you don't mind me asking?
Old 02-08-2021, 01:56 PM #38
Thanks!
We sent you a PM!
_
Old 02-08-2021, 02:11 PM #39
WOW - ICON is Kicking Off 2021 with a Bang.
We received more inventory last Friday, but here is the current stock;
Part #58647 - In Stock (Extended Travel)
Part #58747C - Limited Stock (Extended Travel, w/Res, w/Adj)
Part #57810P - Limited Stock (w/Res)
Part #57810CP - Limited Stock (w/Res, w/Adj)
Part #52700 - Limited Stock
Part #58451DJ - Backorder
Part #58747 - Backorder
Part #57810P - Backorder
Part #52800 - Backorder
Need help finding a UCA option, let us know.
_
Old 02-26-2021, 05:16 PM #40
All Orders placed this week have been processed and shipped!
Thank you so much for all the support.
We blasted through our Delta-Joint UCA's received.
Here is the current stock remaining;
Part #58646 - In Stock (Standard Travel)
Part #58747 - 1 In Stock (Extended Travel, w/Res)
Part #52700 - Limited Stock (2" Rear Coil)
Part #52800 - Backorder (3" Rear Coil)
Part #58451DJ - Stock Delay
Need help finding another UCA option, let us know.
_
Old 02-26-2021, 05:26 PM #41
** Update on 700lb Coil Upgrade **
Current production lead time is 14-16 weeks
Part #58747-700
Part #58747C-700
FEATURES & BENEFITS:
- Adjustable coilovers yield 0-3.5" of front lift height
- Fully serviceable design allows for revalves, rebuilds, and an immeasurable service life
- Bolt-in design makes for an easy install into OEM shock location
- Increased wheel travel and vehicle specific valving provides unrivaled ride quality across a wide range of on and off-road use
- Extended Travel length requires installation of aftermarket front upper control arms
- Superior low speed control reduces body roll and increases on-road stability
- External reservoir to attain cooler operating temperatures during extended off-road use
- ICON's CDC Valve technology allows for 10 levels of high-resolution compression adjustability with the turn of a knob
- High quality ICON-engineered coil springs with higher spring rate included to better support added weight to front end
- Corrosion resistant CAD plated shock body with 7/8" shaft
- FK Rod End bearings provide extended longevity and minimal deflection
TECH INFO:
- Factory Wheels & Tires Fitment: Yes
- Recommended Aftermarket Wheels: ICON Alloys | 17x8.5 w/ 4.75" Backspace / 0mm Offset
- Recommended Aftermarket Wheels: ICON Alloys | 18x9 w/ 5" Backspace / 0mm Offset
- Recommended Aftermarket Tires: 33" x 11.50" (Larger Tires May Fit but Fender Trimming and Modifications will be Required)
_
Old 06-28-2021, 02:21 PM #42
** ICON 2.5 Bundles Going Fast **
We received a delivery today to process and ship all pending orders from last week.
We have a extra units available and Ready to Ship...
Part #58747 - Limited Stock
Part #58747C - Out of Stock
Part #58747-700 - Out of Stock
Part#58747C-700 - Out of Stock
Part #57810P - In Stock
ICON 2.5 Bundles - Click Here
_
Old 07-14-2021, 10:18 AM #43
** Wanted to share a quick stock update **
Limited stock on hand for all 3 2.5 Bundles - Ready to Ship.
700lb coil upgrades are on stock delay;
*When ordering online, use Promo Code "T4R" for added savings on most brands.
_
Old 07-26-2021, 01:36 PM #44
** 2.5 Bundles are In-Stock and Ready to Ship **
Looking for adjusters? Front and Rear ready to ship - Click Here
We have increased our inventory to meet demand, but these still go quick.
Please let us know if you have any questions or need help with a particular build.
_
Old 08-11-2021, 03:09 PM #45
++ ICON 2.5 Bundles are Hot Movers!! ++
Thank you for all the love and support.
We have been able to process and ship most ICON orders within 1-2 days.
Due to the Increased Demand of the 2.5 Bundles, we are currently out of
stock of the 2.5 Coilovers, w/Reservoir, Part #58747.
We hope to see more of these within the next week or 2.
Fronts and Rears with Adjusters (CDCV) are being processed without delay.
_
part , rear , shocks , travel , w/res
ICON Rear Coils for 2.0 VS Series? wettRunner 3rd gen T4Rs 5 09-18-2018 08:57 PM
WTB: 2003+ 4Runner ICON Dynamics V.S. 2.5 Series RR Rear Shocks (0-3" Lift) Run4ever* Want to Buy/Trade 2 09-12-2018 03:42 PM
FS: 3rd Gen 4Runner ICON 2.5 Series RR Rear Shocks w/CDCV, Buena Park, CA mcgyver0302 For Sale: Suspension/Wheels/Tires 2 04-22-2017 01:39 AM
4th gen Icon 2.0 VS series rear shocks Darklight For Sale: Suspension/Wheels/Tires 10 07-15-2016 03:24 PM
Icon Rear Piggyback Reservoir 2.5 V-series shocks Andres_Huerta For Sale: Suspension/Wheels/Tires 18 10-14-2015 02:44 PM
