Old 08-15-2019, 07:08 PM #1
TotalAutomotiveLV TotalAutomotiveLV is offline
Official Vendor
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
Official Vendor
ICON 2.5 Series | 5th Gen 4Runner Bundles
2.5 Coilovers paired with 2.5 Rear Shocks have been in huge demand.
ICON 2.5 Series is designed for Off-Road Enthusiasts and Daily Drivers in mind.
To help make it easier for 5th Gen Owners, we have created 3 popular choices;
Bundle 1 - Part #Gen5-ICON-2.5-Bundle-1
- Part #58746, 2.5 Coilover with Standard Travel
- Part #57810P, 2.5 Rear Shocks, w/Res
Bundle 2 - Part #Gen5-ICON-2.5-Bundle-2
- Part #58747, 2.5 Coilover, Extended Travel, w/Res
- Part #58451DJ, Delta-Joint Upper Control Arm (UCA)
- Part #52700, 2" Rear Coil
Bundle 3 - Part #Gen5-ICON-2.5-Bundle-3
- Part #58747C, 2.5 Coilover, Extended Travel, w/Res, w/Adjuster
- Part #57810CP, 2.5 Rear Shocks, w/Res, w/Adjuster
- Part #52800, 3" Rear Coil
To see all 3 Bundles - Click Here
_
TotalAutomotivePerformance.com - Your Toyota Upgrade Headquarters!
Contact Us by Phone at 702.979.1577 or via Email at info@lvtap.com
We have the best pricing on 4Runner upgrades! From ARB, Rigid, Baja Designs, ICON, King, Bilstein, Fox - Racks, shocks, lifts, lights, wheels, intakes, tuners, exhausts, suspension, and more! Send us a PM or shoot us an email and we will hook up your 4Runner with the highest quality parts and service around
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 03:50 PM #2
Official Vendor
Official Vendor
What a great response to the 2.5 Bundles.
Thank you T4R for all the support.
We have received a lot of requests for 700lb coils. ICON comes standard with a 650lb coil.
We made this easy as well. Just add Part #IVD700 for the coil-over upgrade. Or add to notes, “700 coil” and we can take care of it for you.
As always, please let us know if you any questions or need help placing your order.
_
Old 08-17-2019, 04:12 PM #3
jaemz's Avatar
jaemz jaemz is offline
jaemz will become famous soon enough jaemz will become famous soon enough
jaemz's Avatar
do i need to add a track bar if i have kdss?
ig // @ja.emz
'17 trd off road premium
jaemz is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 12:10 PM #4
Official Vendor
Official Vendor
Yes - Do to the extended travel of ICON Rear Shocks, you will want to
add an Adjustable Track Bar, Part #54200, when running KDSS.
ICON Part #54200 - Click Here
_
Old 08-21-2019, 03:53 PM #5
Official Vendor
Official Vendor
ICON 2.5 Bundle #1 - Click Here
ICON 2.5 Standard Travel adjustable coil-over shocks have proven their strength and
longevity for years on end and they keep going.
These shocks offer the best ride quality and handling.
They increase suspension travel and dramatically increase the capabilities of your
4Runner's front suspension.
These coil-over’s come complete with all the hardware necessary to complete the
installation as well as a sway bar relocation bracket kit to adjust the location of the
sway bar to clear the larger shock.
Recommended tire size 285/75R16, wheel 16X8 with 5" back spacing.
Technical Specs:
- Adjustable ride height from 0" - 3.5"
- Race shock piston with flutter stack compression valving
- Kit Includes Sway bar relocation brackets
- Cad-plated threaded body / Extreme Weather Plating Option Available
- Billet aluminum upper mount
- 5/8" PTFE-lined spherical bearing
- Completely re-buildable
- 2.5" shock diameter to prevent overheating
- Chrome-silicon spring
- 250 PSI nitrogen-charged internal reservoir
- Made in the USA
- Nitro-steel shaft will not chip or rust like chrome shafts
ICON Vehicle Specific 2.5 Series shocks are designed and built to give your
vehicle outstanding performance off-road and a smooth ride on the street.
These shocks are configured specifically for each application in both length
and damping tune.
Like all ICON shock absorbers, 2.5 Series shocks are 100% rebuildable and
100% revalveable.
For piggyback and specific remote reservoir applications; ICON’s unique use
of a 6061 billet aluminum manifold a few inches below the top cap of the shock
creates an internal “Bump Zone” that when used creates an additional 20% of
damping force.
This additional force helps prevent harsh bottom outs and controls the suspension
when compressing at high velocity.
If you are looking for a more user defined tune, consider looking into the Compression
Damping Control Valve (CDCV) or the OMEGA Series bypass shocks.
KEY FEATURES:
- ICON’s internal “Bump Zone” increases damping by 20% to provide more control as the shock approaches full compression
- Remote reservoir design improves heat dissipation to reduce shock fade during prolonged use
- Premium grade 5WT shock oil for consistent suspension damping along a wide temperature range
- One piece digressive piston design with vehicle specific valving for unsurpassed performance and ride quality on and off-road
- 7/8” diameter induction hardened, chrome plated shock shaft
- Polyurethane bushings and forged steel mounting stems for OE factory type fitment
- PTFE lined spherical bearings and application specific mounting hardware
- 6061 aircraft grade aluminum CNC machined components
- CAD plated, precision machined 1026 DOM steel shock body for maximum durability and corrosion resistance
- 100% Rebuildable
- 100% Revalveable
- Made in the U.S.A.
- All ICON 2.5 Series Piggyback and Remote Reservoir shocks can be upgraded to ICON’s Compression Damping Control Valve (CDCV)
_
Old 09-17-2019, 07:50 PM #6
Official Vendor
Official Vendor
Building off the 1st Bundle, the 2nd has Extended Travel Coilovers, the
ICON Delta-Joint UCA's and 2" Rear Coils.
These shocks have been in development for over a year.
ICON Vehicle Dynamics has taken their already perfect performing coilover shocks and
given it the heat dissipation and long lasting performance of a full blown race shock.
All of this has been developed to bolt on and install with ease. They increase suspension
travel and dramatically increase the capabilities of your 4Runner's front suspension.
These coilovers come complete with all the hardware necessary to complete the installation
as well as a sway bar relocation bracket kit to adjust the location of the sway bar to
These coil-over’s are meant to be installed with an aftermarket uniball upper control arm
kit to ensure the proper amount of wheel travel and to prevent premature ball joint wear.
Technical Specs:
- Adjustable ride height from 0" - 3"
- Kit also Includes Reservoir Mounting Brackets
- Hose Length Optimized for Increased Fluid Transfer
- Mounting Bracket Orients Reservoir for Optimum Tire Clearance
- External Reservoir Ensures Maximum Cooling
- Made in the USA
_
Old 10-03-2019, 10:59 PM #7
Official Vendor
Official Vendor
Looking to Turn-It-Up a Notch?
Take a look at the 2.5 Bundle #3 - Adjusters Front and Rear...
Part #Gen5-ICON-2.5-Bundle-3 - Click Here
2.5 Coilover, w/Reservoir, w/CDCV (Adjuster) - Part #58747C
The ICON Vehicle Dynamics V.S. Series 2.5” remote reservoir coilover shocks w/ CDCV are an
incredible upgrade for the front end of the 2010-UP 4Runner.
ICON’s Vehicle-specific valving provides a sport tuned feel on and off-road while offering 0-3.5”
of lift height adjustability for use of larger, more aggressive wheel and tire combinations.
The ICON CDC Valve upgrade is included for those desiring an easy way to tune the ride externally
with 10 adjustment settings from soft to hard.
KEY FEATURES:
• Increased wheel travel and ride quality over stock
• Vehicle specific tuned for superior shock damping and control
• External reservoir to attain cooler operating temperatures during extended offroad use
• ICON CDCV equipped for external tunability of your shocks
• Height-adjustable coilovers offer 0-3.5" of lift height
• ICON engineered coil springs
• 6061 Aircraft grade aluminum CNC machined components
• Corrosion resistant CAD plated shock body with 7/8" induction hardened, chrome plated shaft
• FK Rod End bearings for extended longevity and minimal deflection
• 100% Bolt-on - no drilling or welding necessary for installation
• Made in the USA
2.5 Rear Shocks, w/Reservoir, w/CDCV - Part #57810CP
The ICON CDC Valve is an externally adjustable valve that restricts oil flow into the reservoir which
creates 10 levels of compression damping force ranges.
KEY FEATURES:
- ICON's CDC Valve technology allows for 10 levels of high-resolution compression adjustability with the turn of a knob
- 100% Rebuildable
- 100% Revalveable
NOTES: ICON V.S. 2.5 Series shocks are sold in pairs
_
Old 10-15-2019, 05:54 PM #8
Official Vendor
Official Vendor
Old 10-26-2019, 10:26 AM #9
Official Vendor
Official Vendor
Looking for a Superior ICON Build?
0-3.5” of lift height adjustability for use of larger, more aggressive wheel and tire combinations.
_
Old 11-02-2019, 07:51 PM #10
Official Vendor
Official Vendor
ICON 2.5 Front and Rear Bundles for Easy Ordering...
SEMA Show Specials - Click Here
_
Old 11-17-2019, 11:03 PM #11
Official Vendor
Official Vendor
Looking for ICON Suspension?
No Need to Wait - Order Today!
_
Old 11-18-2019, 02:56 PM #12
uh0h50 uh0h50 is offline
uh0h50 will become famous soon enough uh0h50 will become famous soon enough
For a Complete List of Black Friday and Cyber Monday Deals - Click Here
_
Is the promo code not applicable to Bilsteins? Interested in the Bilstein 6112 Front Suspension Kit.
2016 SR5P MGM: OEM TRD Pro Matte Black Wheels w/ Falken Wildpeaks, Bilstein 5100 F+R set at 1.75F + 1" Cornfed Spacers. OEM TRD F+R Lower Valances, TRD Grille Insert, Shrockworks Sliders, SS3 Yellow Fogs, 3rd Row Delete.
My 3rd Row Delete Thread
uh0h50 is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 03:29 PM #13
Official Vendor
Official Vendor
Bilstein 6112's - Click Here
When ordering online, use Promo Code "T4R" for added savings.
Looking for ICON Black Friday Deals, give a us a Call.
_
Old 12-17-2019, 06:56 PM #14
Official Vendor
Official Vendor
We have been received a lot of orders and PM's requesting 700lb Upgrade.
This is easy. Just add Part #IVD-700 to order to upgrade coilovers to a 700lb coil (650lb Standard).
Need help placing your order, contact us via Phone, Email, Online Chat, PM, or Social Media.
_
Old 01-10-2020, 05:45 PM #15
Official Vendor
Official Vendor
ICON 2.5 Bundles are on Fire!
We wanted to share a quick update as these builds are flying off the shelf.
Front...
2.5 Coilovers, Standard Travel - Part #58646 - In-Stock
2.5 Coilovers, Extended Travel - Part #58647 - In Stock
2.5 Coilovers, Standard Travel, w/Res - Part #58746 - In-Stock
2.5 Coilovers, Extended Travel, w/Res - Part #58747 - Limited Stock
2.5 Coilovers, Extended Travel, w/Res, w/CDCV - Part #58747C - Limited Stock
Rear...
2.5 Shocks, w/Res - Part #57810P - 3-4 weeks production time
2.5 Shocks, w/res, w/CDCV - Part #57810CP - Limited Stock
_
part , rear , shocks , travel , w/res
ICON Rear Coils for 2.0 VS Series? wettRunner 3rd gen T4Rs 5 09-18-2018 08:57 PM
WTB: 2003+ 4Runner ICON Dynamics V.S. 2.5 Series RR Rear Shocks (0-3" Lift) Run4ever* Want to Buy/Trade 2 09-12-2018 03:42 PM
FS: 3rd Gen 4Runner ICON 2.5 Series RR Rear Shocks w/CDCV, Buena Park, CA mcgyver0302 For Sale: Suspension/Wheels/Tires 2 04-22-2017 01:39 AM
4th gen Icon 2.0 VS series rear shocks Darklight For Sale: Suspension/Wheels/Tires 10 07-15-2016 03:24 PM
Icon Rear Piggyback Reservoir 2.5 V-series shocks Andres_Huerta For Sale: Suspension/Wheels/Tires 18 10-14-2015 02:44 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
