Old 08-16-2019, 10:53 AM #1
brown dog brown dog is offline
brown dog is on a distinguished road
Front skid bolts broke
Upgrading from stock front skid and the two bolts from the front end of the skid broke off while I was removing them. Half of both of those bolts are still stuck in the hole. Thoughts on how to remove them? Or should I just try to screw in the new bolts and force the broken bits up through the back end of the hole? Don't really want to drill into them, don't have the equipment. Figured one of you geniuses may have a 'life hack' on how to get broken bolts out.
2011 SR5 4x4 - Mag Gray - Bilstein 5100s front/rear, Wheelers T1/T13, BFG KO2 275/70/17R, RSG Rock Sliders, LFD Off-Road Front Skid, LFD Ruggedized Roof Rack Cross Bars
brown dog is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 11:03 AM #2
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
If they're broken flush there really aren't any other options besides drilling....
if you still have some bolt showing and you've got a welder, you could weld another nut on to the end that would allow you to get it out.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 11:08 AM #3
No bolt showing and I don't have a welder anyways.
Old 08-16-2019, 11:08 AM #4
osugsxr osugsxr is offline
bolt extractor simple and straight forward
Old 08-16-2019, 11:10 AM #5
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Bolt extractor kits are relatively inexpensive..probably the best route to go.
Old 08-16-2019, 11:11 AM #6
Jeckolame Jeckolame is offline
Jeckolame is on a distinguished road
+1
Jeckolame is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 11:17 AM #7
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
Jarheadoo7 will become famous soon enough
Jarheadoo7's Avatar
Bolt extractor, tap set, new bolts and some anti-seize. Extract the old. Tap the hole to clear it of booger’s, then put some anti-seize on the new bolts.
Jarheadoo7 is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 11:24 AM #8
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Those bolts seem undersized, and seem to rust and seize very easily, resulting in broken bolts. Use anti-seize any time you remove and replace them.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 12:01 PM #9
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
If using an extractor, I'd hit the top of the holes with some penetrating lube first a day or so beforehand just in case the bolt is seized. Might help things along.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
Old 08-16-2019, 02:50 PM #10
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
... Don't really want to drill into them, don't have the equipment...
You’re going to need to drill into the broken bolt to use a bolt extractor. If you’re not familiar with the process, here’s an explanation.
How to Use a Screw Extractor: 12 Steps (with Pictures) - wikiHow
Old 08-16-2019, 03:14 PM #11
Forgot to mention, if half the bolt is still stuck in the hole, remember that bolt is screwed into threads.
By screwing in a new bolt you'll most likely achieve at least one of 2 things:
1) Whatever exposed threads there are that you're using the new bolt to catch on to will be completely stripped (may not be enough exposed threads to get enough bite to do any "pushing")
2) You'll strip the threads the busted bolt are screwed into.
Either way, you're going to end up with stripped threads. You can't just push a threaded bolt out of a hole -you have to rotate/turn it in or out. The new bolt won't magically turn/screw the old/stuck bolt.
Like the other guys said, you probably have 1 of 2 options:
1) Carefully drill through the existing bolt and try not to damage the existing threads. Tap to clean shit up.
2) Extractor bit.
A third option is to bring it to a shop and hope they care as much about your car as you do to not damage the threads. .
Old 08-20-2019, 03:56 PM #12
Yeah, I've decided to go the extraction kit route. We'll see how this goes. Cross your fingers for me.
Old 08-20-2019, 05:07 PM #13
Deep_palancar's Avatar
Deep_palancar Deep_palancar is offline
Deep_palancar will become famous soon enough
I would undecide while you still can.
If those bolts are seized to the point of snapping while loosening then they are really bound. Depending on if there is a lot of rust evident, it's likely that they are cross threaded. Those front bolts are really easy to cross-thread.
Those bolt extractor bits can only stand so much torque and will snap off if over-wrenched.
The extractors are made of hardened steel. Once they break in a bolt you are pretty much done, you're not going to drill that extractor bit out with anything less than a wet diamond. You are down to torch and weld as a fix.
Instead, drill the whole bolt out and repair with a helicoil kit of the original size.
Deep_palancar is offline   Reply With QuoteReply With Quote
bolts , broken , end , front , skid
Front skid plate bolts 4flyer 3rd gen T4Rs 10 12-19-2022 07:57 PM
14 trail skid plate bolts broke :( dgirouard39 5th gen T4Rs 12 02-24-2016 08:32 PM
Front skid plate bolts Brian1973 3rd gen T4Rs 4 06-24-2013 10:00 AM
Front skid plate bolts on 03'SR5 4x2 V8 jj4runner 4th Gen T4Rs 3 05-27-2013 06:51 PM
broke off a bolt trying to remove front skid plate 05 2wd uwrasta Maintenance/Detailing 9 12-15-2011 05:15 PM
