Old 08-19-2019, 06:35 PM #1
4central 4central is offline
4central is on a distinguished road
80w90 in rear diff
Hi All,
I had my first oil change at 45K miles for the rear diff. My Toyota dealership messed up and put 80w90 oil ( good chance conventional) in rear diff. I asked multiple times, and wanted original 75W85 oil. They even brought the cans, and said it is gonna cost $200. I said ok, please go ahead. Still they did what they believe is the best, at least they did charge much much less for this.
My question, do I need to worry about using 80w90? So far for 20 miles, no issues, felt a bit more responsive, but can be simply nothing.
4central is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 07:39 PM #2
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
No!.....it's not spec and it will run hotter. Also it's $6 a quart and 1/2 hour of labor so what did they charge for that?! Also worse gas mileage.
83Mule is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 08:09 PM #3
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
In my opinion: There is almost no difference in viscosity between 75w-85 and 80w-90. Secondly, at operating temp the viscosity is the same. Don't see how using 80w-90 will cause the diff to "run hotter".
Remember, asking a question about oil always starts a shouting match, so expect multiple opinions. I can only say what I would do--don't worry about it.
TOYO74 is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 08:42 PM #4
MaddoxPics's Avatar
MaddoxPics MaddoxPics is offline
MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough
MaddoxPics's Avatar
I did 75-90.
MaddoxPics is offline   Reply With QuoteReply With Quote
Old 08-19-2019, 11:25 PM #5
GripT4R GripT4R is offline
Banned
GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light
Banned
It will be perfectly fine.
GripT4R is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 12:50 AM #6
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Don't be ridiculous. It's a Toyota diff. 80W90 has worked for years. I raise my eyebrows hearing 75W85.
Old 08-20-2019, 08:33 AM #7
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I run amsoil 75w-90 with no issues.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 09:13 AM #8
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
I run M1 synthetic 75-90 in the diffs without an issue. I believe original fill is conventional but synthetic is definitely the way to go. DO it yourself, takes 15 minutes to do the rear diff, 30 to do the front since you have to drop the skid plate. 1 hour including clean up and you're done.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
80w90 , diff , miles , oil , rear
2001 4runner Front Diff and Rear axle/Diff assembly. Corpus Christi, TX zwalker16 For Sale: T4R Items 5 08-24-2018 09:53 AM
75W90 vs 80W90 beliboy32 3rd gen T4Rs 32 04-11-2017 12:36 PM
75w90 or 80w90 for rear diff Gecko123 4th Gen T4Rs 3 02-02-2014 08:33 PM
Can I swap the innards of my rear diff with a locking rear diff from another 4runner? xx_independent_xx 3rd gen T4Rs 23 11-19-2013 11:19 PM
75w90, 80w90 or 75w140? banzaj 4th Gen T4Rs 24 12-08-2012 01:47 PM
