Old 08-20-2019, 09:43 PM #16
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner will become famous soon enough
Originally Posted by MAST4R View Post
I thought the consensus here was that the 4R does not charge AGM properly and thus this kind of battery needs extra care?
You do not have to do anything to run an Odyssey. Just put it in and drive it. I talked to Odyssey about this concern on the forum and posted this info in another thread. Odyssey said there has never been a problem with 4runners and the lower voltage would not be a warranty issue. I am going on 2 years on my Odyssey with no modifications and it works great.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 10:06 PM #17
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R is just really nice MAST4R is just really nice MAST4R is just really nice MAST4R is just really nice MAST4R is just really nice
MAST4R's Avatar
Really? Well, that's great to hear, especially since you are right here in AZ. What size is yours?
How long did your stock battery last? I doubt I can trust mine more than 2 years.
On a different note, have you driven Red Mountain/Backaway to the Desert Bar? I know it has got a lot harder than it used to be, but is it really beautiful?
Old 08-20-2019, 11:33 PM #18
Akkording's Avatar
Akkording Akkording is offline
Akkording has a spectacular aura about Akkording has a spectacular aura about Akkording has a spectacular aura about
Akkording's Avatar
Originally Posted by jhguth View Post
X2 at batteries plus, made by northstar
This if in a 24F if you don't need a fridge. It's light and simple. Maybe an ArcLightLeds voltage booster or a GM diode to extend the life to get close to a 14v charge. I always carry a portable usb jump starter for emergency easily had on eBay for 60ish bucks
2012 SR5 | 285 Toyo OC ATII | Level 8 Slam | PC | X2Power w/ArcLightLeds V2 Booster | Borla 40665 | URD Y pipe & Maf Cal TRD tune | C4 Center LP | X20 10k Factor55 | Shrockworks sliders/skids/Bussmann RTMR mount | RCI LCA skids | LFD Offroad 7/8 Gobbi Ladder | TJM Airtec dry aFe HPS coupler w/TRD cai tube | 6112 7/5 clip w/650# King | ICON Delta Joint | 5160 | SAW 1.5" w/Dobinsons 15mm trim packs | .5" Headstrong top plate |
| 03 Tacoma OME equipped, 288k |
| Restoring 02 Tacoma, 230k |
Akkording is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 12:10 AM #19
I took my still working stock battery out at 4 years age. My neighbor put in in his Sienna minivan and ran it another year when it failed. I am not a good comparison for battery life in AZ because my 4runner is in an airconditioned garage 95% of the time. My Odyssey is a 34r.
I have been to the desert bar 5 or 6 times. I am not sure what trail exactly you are asking about but I know 3 ways to get there. The main road is a very easy graded trail. The second way is about 1/2 way down the main trail you cut off to a medium difficulty trail that goes by some mines and goes to the bar. The 3rd way is more challenging. I did it 10 or 12 years ago in a lifted jeep Wrangler. If you can get up the big hill at the start near highway 95 you should be alright but it gets very slow with 7-9" rocks near one of the mines for a good distance. You would want a lift and some descent tires. Trails change a lot here over the years so it may be different now. As far a beauty it is ok but not the best in my opinion.
Old 08-21-2019, 05:01 AM #20
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec will become famous soon enough rigtec will become famous soon enough
rigtec's Avatar
Real Name: Greg
Originally Posted by Peak Runner View Post
I was leaning toward the odyssey extreme due to the lower weight than the Northstar and the good reviews
Hi Peak Runner,
You can't go wrong with the "Odyssey EXTREME!" It fits in the factory battery tray, no hassling with changing the cables, and it's reviews are ***** 5 star rated! 'Happy Trails,
~rig~ cheers
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 05:28 AM #21
mrblah mrblah is offline
mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold mrblah is a splendid one to behold
Anything with the word "extreme" has got to be good!!!!!! Word has it, that the battery is filled with mountain dew.
jk.. I got the same battery, it's pretty good.
2016 sr5 2x4 Mall rated edition:
Current peasant build: spacer lift 3 inches, lots of plastidip, sr5 wheels w/ 265s, lots of LED lights, and lots of overlanding stickers and sponsored stickers. faking it with the IG crowd since 2016.
Old 08-21-2019, 11:50 AM #22
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
LOL! Good one mrblah!
rig, cheers!
Old 08-21-2019, 03:30 PM #23
GNB GNB is offline
GNB is on a distinguished road
GNB GNB is offline
I ran AGM / Optima batteries in my Z0-06 Corvette, but only because the battery tray was directly over a lot of electronics that leaking battery acid would have caused big $$$ problems.
That's is not the case on my 2015 TRD Pro 4Runner. Not meaning to offend anyone here, but why bother spending the extra $$$ on an AGM battery when a Walmart battery would work fine? My OEM battery is still working fine going through pretty extreme heat and humidity in Houston.
GNB is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 04:59 PM #24
Gyprat Gyprat is offline
Gyprat is on a distinguished road
I've been looking to either upgrade the existing Panasonic battery with an AGM or to install a second battery. I need more capacity to run my ham radios when parked.
It seems like Autocraft Platinum batteries get very good reviews. A size 24F has 710 CCF and 70 AH capacity which is nice. It lists for $199 but you can purchase it online (pick at your local store) with a 20% off coupon to bring the price to around $160. It's not bad for an AGM battery with a decent capacity. I've had one on my truck for 5 years until I sold the truck. The battery never gave me any problems and I could run the radios for the whole day without having to run the engine to recharge it.
2016 4Runner SR5.
1998 Grand Cherokee 4x4, NP242 transfer Case, 4.0L
Gyprat is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 05:39 PM #25
Kuduhunter Kuduhunter is offline
Kuduhunter is on a distinguished road
Odyssey 34M-PC1500ST dual post battery
Any thoughts of using this marine battery as has dual posts if want to hook up accessories. I will be adding a winch and LED lights soon. Has the cranking amps and the reserve amps to handle most anything.
2017 ORP + KDSS/Barcelona Red/Toytec Boss 2.5 Performance Kit/Heftyfabworks full skids/RSG Sliders/Ceramic Coated/SCS Ray 10 Matte Bronze/Coverking seat covers/XenonDepot HID lows and LED Highs headlights/Morimoto Fog lights/Rokmen Lower Links/Pedal Commander/Falken Wildpeak AT3W 285/70/17/Ultimate Cargo liner/Rav4 side mirrors/Rago Molle Panels
Kuduhunter is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 08:28 PM #26
83Mule's Avatar
83Mule 83Mule is offline
83Mule has a spectacular aura about 83Mule has a spectacular aura about
83Mule's Avatar
I have a Kodiak dual system with two Odyssey Extremes in my 06 Rubicon. They are hitting 9 years soon! Costs $470 to replace them both so I am happy with the lifespan! 4Runner gets a old fashion Walmart lump. Mule gets a $56 Walmart 24F!
83Mule is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 11:43 PM #27
halflife78's Avatar
halflife78 halflife78 is offline
halflife78 will become famous soon enough
MY GARAGE
halflife78's Avatar
MY GARAGE
I bought the Northstar 31m and it was a waste of money getting the dual post...they are so close together you can't hook up accessories to the second terminal. If I think about it I will get a pic tomorrow showing the issue I ran into related to this.
2016 TRD Pro: C4 Rock Sliders | Victory 4x4 Roof Rack | Ellis Precision Shifters | Blackvue 650s 2 CH | Full Front Clearbra | 20% Tint | Beavertail | Borla S-Type | Pedal Commander | Tail as Turn | DRL LED Foglights | ArcLight Triple State Voltage Booster | Victory 4x4 Front Winch Bumper | Victory 4x4 Front Skid | TRD CAI | SCS Stealth 6 | Dobinsons Lift & UCA | Warn Zeon 10s | Northstar 31m | Factor55 Flat Link | ARCLightLED Hatch/Map/Dome Lights | Lock'er Down Console Safe | XD Door Light / License Plate Bulbs
halflife78 is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 01:54 PM #28
97BlackAckCL's Avatar
Real Name: Chris
97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold
MY GARAGE
Real Name: Chris
MY GARAGE
I like that it has the dual posts, I also like that it's name is Trolling Thunder lol
2017 Nautical Blue SR5 Premium - Black Emblem Overlays, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back, Morimoto HID Headlights, Auxbeam LED Highs, Morimoto Black XB LED Fogs, Fyre Flys LED Interior, Lasfit Amber LED Turn Signals, Smoked Amber LED Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, CaliRaised Low-Pro Ditch Brackets w/ Side Shooter LEDs, Anti-Dark Underhood LED kit, sPod w/ PowerTray Mount, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, N-Fab Side Steps, Satin Black Roof Rails, MB Quart Speakers all 6 door locations, JBL 3.5" in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, CanvasBack Liners, ScanGauge, Blackvue Dash Cams
Old 08-22-2019, 02:44 PM #29
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is just really nice Bumbo is just really nice Bumbo is just really nice Bumbo is just really nice Bumbo is just really nice
Bumbo's Avatar
9 year run on lead is pretty good... you must actually take care of your stuff.
I got away with running a Costco Interstate starter battery as my house battery for years. It still does surprisingly well when you don't need to discharge it to the floor.
The battery takes the fridge load overnight without a problem, I don't even hit the low voltage disconnect which is set at 12.1v To a degree I even question the need for a true deep cycle for most weekend warriors.
I can supplement it with a 50 watt solar panel and you don't even need to start the truck all weekend... I have it, but never use it.
That said, when it time to replace, I am building a custom lithium solution which should be pretty amazing in terms of size/weight and run time.
Old 08-22-2019, 05:04 PM #30
83Mule's Avatar
83Mule's Avatar
I often wonder, if my Shorai LFX-14 in my Motorcycle can put out 14 ah and weigh a pound....can't they scale it up to Truck size?!
agm , battery , group , recommendations , size
Good AGM battery recommendations for winch Noshirtganshirt 3rd gen T4Rs 6 10-04-2016 10:20 PM
Need new starter battery - Any recommendations? vision-quest 4th Gen T4Rs 1 01-05-2016 01:54 PM
Battery Recommendations? gamefreakgc 3rd gen T4Rs 42 09-30-2015 01:26 PM
Battery recommendations jev2022 3rd gen T4Rs 8 11-16-2005 03:52 PM
Battery Recommendations live4swell 4th Gen T4Rs 14 07-03-2004 12:36 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
