Old 08-22-2019, 08:35 PM #31
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Originally Posted by 03_4x4Runner View Post
You do not have to do anything to run an Odyssey. Just put it in and drive it. I talked to Odyssey about this concern on the forum and posted this info in another thread. Odyssey said there has never been a problem with 4runners and the lower voltage would not be a warranty issue. I am going on 2 years on my Odyssey with no modifications and it works great.
False. Read your warranty and specs, the factory charging system will void your warranty because the voltage is too low.
Odyssey requires 14.0 to 14.7V, the factory charging system is not sufficient for an AGM battery, the voltage is too low.
AGM Battery recommendations-screenshot_20190822-204753_drive-jpg
jhguth is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 09:08 PM #32
Racehoss's Avatar
Racehoss Racehoss is offline
Racehoss is on a distinguished road
Racehoss's Avatar
I have two 4Runner both have odyssey batteries. Both work great and have for two years. Buy and don’t look back. People that complain don’t own them. Real experience wins on this one.
16' TEP OME suspension, ARB bumper and rack, Budbuilt Sliders
SOLD 85' 4runner Built SOLD 03 FJ100 SOLD 92' FJ80
Sold 14' trd crewmax tundra
Racehoss is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 09:23 PM #33
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
A lead battery, AGM or other, will slowly sulfate internally if you can’t provide it with the correct charge voltages. It’s a slow death and you might not notice it is happening at all.
If you actually capacity test your battery, as in run the cell from 100% to 0% state of charge by voltage and measure power out consumed, you would basically see a greater loss of capacity over time vs a unit that was maintained correctly. Both will have capacity loss, but one will be at an expedited rate.
In addition to the capacity loss, it's ability to delivery higher currents will also be reduced.
It will continue to degrade and its ability to hold a charge will reduce. Ultimately forcing you to remove it from service. By that time, its ready to replace and probably too far gone to recover properly. At the end of the day, all you are doing is reducing its potential service life. It just wont last as long as one that was maintained correctly.
Batteries are pretty simple devices... how you treat them is directly related to their service life.
Old 08-22-2019, 09:45 PM #34
Bumbo's Avatar
Bumbo's Avatar
2 years those batteries are still babies.
I would expect a premium AGM to last 5 to 9 years. You won't see these ill effects until later in life.
Old 10-25-2020, 10:21 PM #35
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Actually, Enersys says otherwise. @03_4x4Runner talked to them and I have my info from them in writing from last week.
The fine print on everything is normally made to make things look scarier than they are in order to prevent abuse. Write them an email and see what they say for yourself.
Old 10-31-2020, 05:23 PM #36
curmudge1 curmudge1 is offline
Real Name: Dave
curmudge1 is on a distinguished road
Real Name: Dave
Question What about DieHard AGM?
I have a 4 year old Diehard AGM, fine so far, although I plan to test it before winter sets in hard. Not that winter is all that bad in NJ. No special voltage adjuster installed.
Advance Auto is carrying the DieHards now, since Sears is just about dead.
Does anyone have more experience/info on the Diehard AGM?
curmudge1 is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 06:25 PM #37
Twilghtzone Twilghtzone is offline
Twilghtzone is on a distinguished road
Diehard AGM ?
Looks like Johnson Controls makes them.
If they do, it's probably a good battery.
Twilghtzone is offline   Reply With QuoteReply With Quote
agm , battery , group , recommendations , size
Good AGM battery recommendations for winch Noshirtganshirt 3rd gen T4Rs 6 10-04-2016 10:20 PM
Need new starter battery - Any recommendations? vision-quest 4th Gen T4Rs 1 01-05-2016 01:54 PM
Battery Recommendations? gamefreakgc 3rd gen T4Rs 42 09-30-2015 01:26 PM
Battery recommendations jev2022 3rd gen T4Rs 8 11-16-2005 03:52 PM
Battery Recommendations live4swell 4th Gen T4Rs 14 07-03-2004 12:36 AM
