08-19-2019, 07:50 PM
AGM Battery recommendations
Have researched the web and several links on this page but want some recent recommendations on which AGM battery is the best for running winch and lights on 2017 ORP. No plans to put in a refrigerator.
Northstar vs Odyssey vs Duracell. in Group 24M or Group 34M size????
Thanks for any input
2017 ORP + KDSS/Barcelona Red/Toytec Boss 2.5 Performance Kit/Heftyfabworks full skids/RSG Sliders/Ceramic Coated/SCS Ray 10 Matte Bronze/Coverking seat covers/XenonDepot HID lows and LED Highs headlights/Morimoto Fog lights/Rokmen Lower Links/Pedal Commander/Falken Wildpeak AT3W 285/70/17/Ultimate Cargo liner/Rav4 side mirrors/Rago Molle Panels/SSO Slimline bumper with High clearance mod/Smittybilt X20 waterproof 10K winch
08-19-2019, 08:16 PM
Moderator
Real Name: The Chosen One
Moderator
'89 4Runner SR5 - stock
08-19-2019, 09:45 PM
Real Name: Greg
Real Name: Greg
Hi Kuduhunter,
There are two that I've used, "see below":
...and...
I'm using the "Odyssey Extreme", and my wife's Camery has the "Exide Edge"! Both (IMHO) are just as capable! Here's a description of the Odyessy Extreme in my 4Runner: https://www.toyota-4runner.org/2012950-post1.html Best to you,
rig
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
08-19-2019, 10:13 PM
X2 at batteries plus, made by northstar
08-19-2019, 10:34 PM
Originally Posted by rigtec
Hi Kuduhunter,
...and...
rig
I was leaning toward the odyssey extreme due to the lower weight than the Northstar and the good reviews
08-19-2019, 11:17 PM
+1... and watch for their online coupons, you can save a ton. Very happy with mine 5 months in.
2023 Lexus GX 460 Premium
Sold - 2014 LE Barcelona Red
08-19-2019, 11:20 PM
I thought the consensus here was that the 4R does not charge AGM properly and thus this kind of battery needs extra care?
08-19-2019, 11:52 PM
I have dual Odyssey group 25s (genesis system) and a buddy has a single Northstar in a JK (don’t know the size). Both are holding up, but there are several things to keep in mind:
1. AGMs have a different charge profile. They require ~14.7 volts to fully charge. The 4Runners alternator only supplies about 13.5 volts which will only charge the AGM to about 85% depending on ambient temperature.
2. To keep the battery healthy it will need to be charged to 100% using a charger with the correct profile about 1-2 times a month. I chose to permanently install a Victron solar controller (which has an AGM profile) inside the engine bay and then I connect it to a 12 volt power supply, basically mimicking a 100w solar panel. This leaves me the option to add solar down the road if needed for roughly the same price as a stand-alone charger.
2018 ORP - A bunch of stuff that is nice, and a bunch of stuff I don’t need.
08-20-2019, 12:11 AM
Others and myself have used a voltage booster and have not had any issues
Triple State Voltage Booster - 5th Gen 4Runner — ArcLightLEDs
08-20-2019, 01:32 AM
I'm running a 2 battery setup using Northstar AGM batteries group 34. Very happy with them so far. I also added a diode booster fuse which delivers a charging voltage around 14.5 V. Once in a while I'll just hook up my battery charger which has an AGM charge algorithm and give them a charge but to be honest I don't need to do that but I have the charger so why not.
08-20-2019, 04:29 PM
+2. Has 6 year warranty. Just installed an auxiliary Group 34 to replace about 8 year old Diehard Premium AGM. X2 also seems to be popular over at expedition portal forum. I also have the voltage booster installed on my truck for slightly higher charge voltage. And have CTEC charger I can hook up periodically if I want.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
08-20-2019, 05:24 PM
Isn’t the Victron MPPT a buck controller… I have a couple and they won’t boost a DC-DC voltage.
As long as you are feeding it greater than the battery voltage this should work as this would be typical to what a solar panel would be doing.
08-20-2019, 06:18 PM
Real Name: Chris
Real Name: Chris
I've used Optimas for 15 years or so, I recently made the switch to Odyssey and I'm in love. I'm actually looking at getting the same Odyssey that I have in my 4Runner for my Acura, they're awesome quality batteries.
08-20-2019, 06:38 PM
Just needs higher voltage, and you can stick with stock size if you're not running a fridge or anything
08-20-2019, 09:23 PM
I run the odyssey 34r size and so far it has been great. I do plan to add a 2nd later when I get back to doing more camping later in the year or early next year.
I do not have a fridge but do run my roof rack lights off it when camping and power my phone charger, lights and a small fan in my RTT.
