Originally Posted by 03_4x4Runner
You do not have to do anything to run an Odyssey. Just put it in and drive it. I talked to Odyssey about this concern on the forum and posted this info in another thread. Odyssey said there has never been a problem with 4runners and the lower voltage would not be a warranty issue. I am going on 2 years on my Odyssey with no modifications and it works great.
False. Read your warranty and specs, the factory charging system will void your warranty because the voltage is too low.
Odyssey requires 14.0 to 14.7V, the factory charging system is not sufficient for an AGM battery, the voltage is too low.
