Old 08-19-2019, 11:30 PM #1
Galdarn's Avatar
Galdarn Galdarn is offline
Galdarn is on a distinguished road
Galdarn's Avatar
27F OK? Battery pros and cons
Has any one here tried a 27F? If so what did you have to do to get it to fit? Did it work ok for you?
Would the 24F be better?
BTW: I have done a ton of searching on this and did not find any specific information on the 27F.
Thanks for the help
Galdarn
Galdarn is offline   Reply With QuoteReply With Quote
Old 08-23-2019, 01:53 AM #2
myf16 myf16 is offline
myf16 is on a distinguished road
Does this post help?
https://www.toyota-4runner.org/2429272-post14.html
myf16 is offline   Reply With QuoteReply With Quote
Old 08-23-2019, 09:34 AM #3
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
Only mod you need is a 4th gen battery tray. No cons except for added weight, takes more space and battery might cost more.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 08-23-2019, 10:23 AM #4
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
I had a 27F in my 4th gen for years and actually bought a battery tray to put into my 5th gen but ended up getting an Odyssey instead. I have a brand new battery tray for sale if anyone is looking to go this route
https://www.toyota-4runner.org/for-sale-non-t4r-items/271006-universal-large-battery-tray-$30-pittsburgh-pa.html
Old 08-23-2019, 04:07 PM #5
I just installed a 27F in my 2011 4Runner. I removed the old 24F battery and the plastic tray. The 27F fit on the shelf with no difficulty at all. I plan to install a larger plastic tray under the battery later this year. Maybe I'll find one at a salvage yard.
Old 08-23-2019, 05:11 PM #6
KYMike KYMike is offline
KYMike will become famous soon enough
I have a 27F in mine.
I installed the other OEM battery tray (P/N can be found in various threads) to fit the larger battery, but no other modifications were needed. The existing battery cables mounted up without issue. It is heavy though.
I installed the 27F mainly for the ARB fridge I run frequently.
KYMike is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 11:04 AM #7
I found a 4th gen tray on eBay. It fit perfectly, but damn that 27F battery was really hard to lift out of the vehicle. No handle on the 27F and it's HEAVY.
I'm very happy with my new setup.
Old 09-05-2019, 05:53 PM #8
Galdarn's Avatar
Galdarn's Avatar
S
Thanks for your reply. I found a 27F at Sams for $100.00 Its a Duracell.
Do you know if the 4th gen battery tray plastic like the one in my 5th gen?
I was thinking about making a simple tray with some scrap aluminum angle I have. Just not sure how to attach it yet or if it needs to be attached.
Galdarn
Old 09-05-2019, 06:51 PM #9
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
I remember reading on the Tacoma forums years ago about being problems when going from a 24F to 27F battery.
The Tacoma that came from the factory with a 27F battery also has a high output 130 amp alternator whereas the one that came with 24F battery came has the standard output 90 amp alternator.
The problem when sticking a high capacity 27F battery into a truck with the standard output alternator can kill the battery quickly because it won't keep it fully charged.
However the 4Runner comes with a either a 100 amp or 130 amp alternator so maybe a 27F battery will work if you have the 130 amp alternator.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 08:26 PM #10
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
If your truck with a 90a alternator can fully charge a 24F, it can fully charge a 27F.
In normal operating conditions, the alternator current capability has absolutely nothing to do with its ability to fully charge a battery because a full charge is completely dependent on system voltage, not available current.
The only time I would be concerned, is if you are actually using more current than the alt is capable of putting out. Because in that condition, and only in that condition, you will have voltage drop. How much drop depends on how much load you have in the system.
For most people, non-issue. If this was an issue most all battery tenders would not fully charge a car battery.
Think about dual battery setups too… you literally just doubled your capacity with the stock alternator. You could add 10 batteries, and as long as you can maintain your charge voltages, they will charge just fine. With that many batteries, It’s just going to take longer as the rate of charge will be split across each battery assuming you actually hit the alternators max output. The fuller a battery gets, its ability to accept current is also reduced.
Old 09-21-2019, 01:46 AM #11
Galdarn's Avatar
Galdarn's Avatar
Hans Moleman
Good to know about the alternator, Now I have to find what the output is on mine.
Galdarn
Old 09-21-2019, 01:55 AM #12
Galdarn's Avatar
Galdarn's Avatar
Thanks for the detailed info Bumbo.
I am also planning on getting an LED voltage meter to mount inside so I can monitor the battery voltage.
I would like to get a solar panel to mount on the roof for constant trickle charge also
since I don't drive it every day.
Anyone have suggestions for a roof mount solar charger under $100 to maintain the battery charge?
Galdarn
27f , battery , duracell , fit , good
4th gen V6 vs. V8. Pros/Cons, MPG whipkiller 4th Gen T4Rs 72 10-13-2019 05:44 PM
3rd Gen vs 4th Gen - Pros/Cons H20skier70 General Discussions 36 02-06-2019 09:11 PM
Pros/Cons of 1st gen vs 2nd gen jmitchell79 Classic T4Rs 27 11-30-2013 05:58 PM
3.0 pros and cons? Lil Evil1 Classic T4Rs 12 06-06-2012 03:02 PM
pros and cons of 4 cyl 2wd? JorgeSantos 3rd gen T4Rs 5 02-21-2006 05:25 PM
