Old 08-20-2019, 10:46 AM #1
metzger metzger is offline
Real Name: austin metzger
metzger is on a distinguished road
Looking for more flex
14' SR5 4x4, I currently have bilstein 5100s @ .85" setting and 1" spacer mounted on top of the mount. With the intent to not increase spring rate to get more flex out of the front. What is limiting flex in the front? Upper control arms? Please educate me.
metzger is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 11:07 AM #2
Hydguy's Avatar
Hydguy Hydguy is offline
Hydguy will become famous soon enough Hydguy will become famous soon enough
Hydguy's Avatar
The CV shafts are the limiting factor.
IFS will never get the articulation of a SFA.
2018 4Runner TRDORP MGM MODS: TRD Intake, full set of ARCLight Icraus Premium lights,Precision LED interior door/exterior lights, Rago MOLLE panels, Ellis Precision shift knobs w/Custom engraving, N-Fab nerf bars, 3-1 LED DRL/Fog lights.
Hydguy is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 12:23 PM #3
MisplacedTexan's Avatar
MisplacedTexan MisplacedTexan is offline
MisplacedTexan is on a distinguished road
A spacer lift doesn't get the same travel as an actual suspension lift. You still have stock articulation or may a little less, but jsut an inch higher because of the spacer.
Suspension lifts with longer springs, longer shocks, and new UCA's are where you can start getting more flex.
UCA's aren't necessarily required, but are suggested when getting a 3" lift for alignment reason. Also, when switch over to a uniball setup you can gain more droop as a ball joint style UCA may bind while drooping.
CV shafts do play a limiting factor, but thats when you start getting into the long-travel stuff.
2010 SR5 | ARB | Baja Designs | SCS Ray 10 | Falken Wildpeak 285/70 | Shrockworks | OME | SPC | Blue Sea | Hella Horns
MisplacedTexan is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 12:39 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Front sway bars also get in the way of flex... quick disconnects or temporary removal have been done in the past for people who off-road.
CV's are also a limiting factor, along with the general suspension geometry which doesn't really change until you move into a long travel setup.
Alternately, you could do a solid axle swap, but I would probably change the vehical before getting to that point.
Old 08-20-2019, 12:40 PM #5
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Do you mean 'flex' or 'travel' or 'droop'?
Jack up your front end and try rotating your tires by hand, then do the same thing with the steering at full lock each side. Any CV binding? If so, trying to get more travel at this point will only damage the CVs. If not I'd be interested in hearing from others what the limiting parts are; the stock UCA ball joint, then maybe shocks or LCA ball joints after upgrading the UCA.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 01:00 PM #6
Inv4drZm's Avatar
Inv4drZm's Avatar
Read this thread, for 4th gens but it should still apply:
Higher angle inner CV joint options for 4th gens?
5100s actually have the same extended length as 'extended length' Icon coilovers. And with your 1" spacer on top your shock can't be limiting your travel.
Old 08-20-2019, 01:23 PM #7
that's what i think.
Looking for more flex-20190817_104310-jpg  Looking for more flex-20190817_104325-jpg
Old 08-20-2019, 02:05 PM #8
Inv4drZm's Avatar
Inv4drZm's Avatar
Ah, that just one of the challenges of IFS. Trying to get equal flex front/rear.
Maybe try stiffening up the rear, add the sway bar back in if removed, something, to try and reduce it wanting to take all the articulation.
IMO as long as all 4 are on the ground you've got nothing to worry about, it doesn't matter if the front stays flat as a pancake.
Also, in that picture you have less weight acting on the front end as it's up in the air. Try backing up to the hill so you get more nose weight if you want to actually test front articulation.
Old 08-20-2019, 02:11 PM #9
Horsethief Horsethief is offline
Horsethief will become famous soon enough Horsethief will become famous soon enough
Yeah, IFS doesn't really "flex".
This is why people do solid axle swaps, and why Jeeps still have a solid front axle. WAY better for offroading that requires articulation, and easier to increase the travel.
My old Grand Cherokee had a solid front axle, and the front would flex just like the rear of the white one above is doing.
Horsethief is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 02:39 PM #10
Bumbo's Avatar
Bumbo's Avatar
Not mine, but one of the better 5th gen SAS photos ive seen.
flex , front , increase , rate , spring
Flex fan or..?? Wolf_Girl Classic T4Rs 7 12-14-2016 01:17 PM
How much flex? Rushingman 4th Gen T4Rs 6 12-08-2015 10:54 PM
Got Flex? Run 4 Fun Off Topic 4 06-12-2015 01:33 PM
More flex out of the 1st gen. DanKendall6 Classic T4Rs 9 02-03-2015 02:04 PM
IFS flex Javelin 4th Gen T4Rs 54 06-18-2012 12:02 AM
