Old 07-27-2020, 02:30 PM #1
meder24's Avatar
meder24 meder24 is offline
meder24 is on a distinguished road
meder24's Avatar
Rear Driver Side Wheel Squeal
Hello,
For a while now, I have been having an intermittent squealing noise from my rear driverside wheel. I have verified that it is in fact this location where the noise comes from.
The noise sounds very much like metal contacting metal. The noise only occurs once I have been braking for a little while and the brakes have had time to heat up. The noise also is only present when the outside air temp is about 75F or higher. It is totally absent when temps are lower. The sound will occur at all speeds and comes and goes intermittently. The only way to stop the noise is to apply the brake. It will come back ever now and then when not braking. Therefore, I am assuming it is brake related. There is no change in braking performance other than the annoying and embarrassing squeal.
Anyways, after searching through this forum, I found a couple of threads where parking brake components caused similar sounds and I have since replaced all of those components. I have also replaced all the pads and rotors, at all four wheel locations, with OEM parts. This includes new pins and other small retainer pieces and everything was greased properly. I also installed new OEM shims all the way around. The dust shield is not contacting anything either.
The only thing I have not done is bleed the brakes or replace the brake caliper. But based on the fact I hear or see nothing for 9 months of the year, these do not seem to be a problem.
Has anyone had a similar situation and if so, what did you do to remedy? I guess it is possible the higher air temps could cause some sort of expansion of some component, but I am no longer sure what that part would be.
Any input or previous experience is greatly appreciated.
Thanks
If you want it done right, do it yourself!
meder24 is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 02:34 PM #2
spartacus's Avatar
spartacus's Avatar
Did you bed the brake pads after you installed new pads and rotors? Might help. Google bedding new brake pads.
Old 07-27-2020, 02:37 PM #3
themaestro's Avatar
themaestro themaestro is offline
themaestro will become famous soon enough
themaestro's Avatar
I had the same issue. I spent a bunch of time trying to track it down thinking it was coming from the front, so I gave up and had a mechanic look at it. Ended up having something to do with the parking brake. I didn't do the work myself so I can't say specifically, but it was like a bracket or a clip that holds the parking brake was bent and was scraping on the rotor.
themaestro is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 02:48 PM #4
meder24's Avatar
meder24's Avatar
New pads and rotors were bedded together after replacement.
Old 07-27-2020, 02:48 PM #5
meder24's Avatar
meder24's Avatar
I was hoping this was the case for mine as well but the new parts unfortunately did not change anything.
brake , braking , noise , temps , wheel
Noise behind the rear wheel driver's side. calcrc 5th gen T4Rs 10 08-16-2020 05:24 PM
Help, rear driver side wheel locked up in nuetral popsmckracken 3rd gen T4Rs 3 01-19-2017 08:28 PM
Driver side rear wheel offset from passenger isde ssk1 3rd gen T4Rs 3 06-17-2013 02:00 AM
Squeal from rear driver side wheel 2008 SR5 4WD CPR 4th Gen T4Rs 0 03-23-2012 06:31 PM
Hot rear driver's side wheel. oakes 4th Gen T4Rs 2 12-06-2010 02:01 PM
