Old 08-21-2019, 08:22 PM #1
blakek blakek is offline
Real Name: Blake
blakek is on a distinguished road
Real Name: Blake
I CANNOT decide on a lift....
I want to do as little as possible really, don't want to do shocks and UCA's, etc
most importantly, keep stock sized tires -- I may go up a size to 275 when these are replaced
I want to really lift the front up 1.5-2" and the back under 1"
right now running the TRD Pro tires on stock rims, Nitto 265/70
I know the 1" cornfed may look OK (I found that thread on here), but wanted to go up just a tad more to at least level out the front if I don't do anything in the back. that's why I mention doing a 1.5" but then do I just skip the back and do diff shocks? or what?
it's hard to find pictures with stock tire sized, lifted 4Runners on here
cornfed has some great pics of the 2/1" but none of their pictures have stock size tires, they are all 285 it seems, looking at their site and Facebook and various other places
help me out, anyone?
blake
2012 SR5 4Runner
blakek is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 08:33 PM #2
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
I used these threads when deciding if I wanted to stick with stock size tires after lifting 2"
Any lifted 4Runners with stock tire size?
Anyone have 265 tires with a lift?
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 09:05 PM #3
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Eibach pro kit, no need for control arms. Great improvement over stock. I know its more then your looking at, but it cant be beat for the price. 265 Toyo's.
I CANNOT decide on a lift....-20190218_144104_resized_2-jpg  I CANNOT decide on a lift....-20190530_073825_resized-jpg  I CANNOT decide on a lift....-20190218_144257_resized_2-jpg  I CANNOT decide on a lift....-20190218_144320_resized_2-jpg
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 09:11 PM #4
Real Name: Blake
Real Name: Blake
that's what I was looking for, those were buried with what I searched for
thanks for that!
blake
2012 SR5 4Runner
Old 08-21-2019, 09:18 PM #5
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
Check out the:
Eibach Pro-truck lift I like mine.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 10:23 PM #6
SalmoTrutta SalmoTrutta is offline
SalmoTrutta is on a distinguished road
Originally Posted by Drobs View Post
Check out the:
Same here
SalmoTrutta is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 10:24 PM #7
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Your two best options, as I see them:
1/ Billstein 6112 with your choice or rear shocks. I run Icon 2.0. Add 1" rear Eibach springs. Total: 1,000. Huge difference everywhere, front has different levels of adjustment. If you have any weight at all, you may want to go 1 notch up from what the guide says. So, instead of 3 and 5 for 1.6" lift, 4 and 6.
2/ Eibach shocks and rear spring with Dobinsons front spring (the 1" one, which is great quality) OR you can even keep the stock spring if performance matters less. This will be around 600 with stock front and 800 with Dobinsons front. So better get the Billstein 6112.
The Eibach kit may seem like a great value but for a couple hundred more you can get adjustable Billstein 6112 with matching rear shocks which is both cheaper and better than an entry level performance suspension such as Fox 2.0 or Radflo 2.0 and which will perform better than any of the good, sound, non-performance options like Eibach, Dobinsons twin tubes, or 5100s.
The 6112 are extraordinarily smooth in town so it is not like it is an offroad upgrade only. At least if you stay at 2 or less (true for all).
back , front , size , stock , tires
Still trying to decide on a lift kit Dirtrider216 4th Gen T4Rs 4 10-13-2017 02:21 PM
Help me decide on what lift to get - Oh no not another one munkel 5th gen T4Rs 20 10-11-2016 08:48 AM
Help me decide my tires to match the lift decker1 5th gen T4Rs 25 06-26-2015 12:51 PM
LIft or tires? Can't decide flying fuzz 5th gen T4Rs 34 08-01-2012 10:16 AM
Lift - Help me decide! paquitox 4th Gen T4Rs 6 06-10-2012 06:08 PM
