Old 08-24-2019, 02:16 AM #16
Whippersnapper02's Avatar
Originally Posted by Havik View Post
I have a handheld tuner that can modify the ECU. Like I said in the original post, I'm not looking for hardware, I'm looking for someone to create the actual tune for me.
You can remove the current tune and go back to stock? That wasn't possible with the Toyota tune for the TRD blower.
HP tuners isn't a "hardwire" tune. It's been used on OEM GM ECUs for many years.
Old 08-25-2019, 11:18 PM #17
Havik's Avatar
Havik Havik is offline
Real Name: Derrick
Havik will become famous soon enough
Havik's Avatar
Real Name: Derrick
I didn't say hardwire, I said hardware. They also don't tune 4Runners, so doesn't really do me much good.
2015 Toyota 4Runner Trail Edition
Havik's Build Thread
Havik is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 12:38 AM #18
Maybe with enough interest they'll expand to include Runners. As to your original question, Bully Dog was the first to get into the factory ECU. I'm not sure if they can do anything for you.
Old 08-26-2019, 04:15 AM #19
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
There is a high performance shop in Fillmore, Ca that does custom tunes and work called Full Throttle Kustoms. They have a Mustang dyno and are a very reputable shop. I had a Magnuson on my SS Camaro and they did a full engine build. They can help you select your pulley size, injectors, set afr’s, fuel delivery and more. They’re not too far from where you live. Ray, is a master tuner and use to do a lot of imports besides muscle cars and Vettes. He helped me out on my old 2001 TRD supercharged 4Runner also.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 08:58 AM #20
Stormy246 Stormy246 is offline
Stormy246 is on a distinguished road
Hi all. First post here. I have a magnuson kit on my truck along with a urd y pipe a magnaflow catback and cold air intake. I was looking for a new tune for my truck and contacted Gadget at URD. He set me up with a Ucon EMS. Yes it is a bit pricey however my truck runs significantly better then it did on the canned magnuson tune. I have no regrets going this direction. Just food for thought.. no dyno tuning needed either however I did do a remote tuning session with Itronix the maker of the Ucon to get everything squared away.
Stormy246 is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 10:22 AM #21
Havik's Avatar
Real Name: Derrick
Havik's Avatar
Real Name: Derrick
So they have a UCON for the 5th gen 4Runner? I don't see that listed on their website. I emailed them asking about the tune, they haven't responded yet. I guess I will give them a call. Thanks.
Old 08-26-2019, 10:23 AM #22
Havik's Avatar
Real Name: Derrick
Havik's Avatar
Real Name: Derrick
If they can tune the 5th gen 4Runner, that would be my ideal choice. They aren't too far from me and a custom tune on a dyno is far better then a tune you get via email based loosely on the mods you have.
Old 08-26-2019, 10:40 AM #23
Yup. I didn’t realize they did at first as it is not on their site, but I can tell you that our engine will not need the cam gears installed. It is just the install of the Ucon which is simple if you are the handy type. Also will need to run the colder thermostat that is supplied with the kit. I will say that the truck runs smoother at idle as well as through out the rpm range. I definitely feel like it picked up some power too. The best part of the Ucon is that it has a guardian mode that will put the engine into limp mode in case any abnormalities occur.
Old 08-26-2019, 11:12 AM #24
Havik's Avatar
Real Name: Derrick
Havik's Avatar
Real Name: Derrick
Just got off the phone with URD. They do have the UCON EMS for the 5th gen, but it won't be available for sale for another 2 to 3 weeks. They've only let a few kits out for testing for now. He put me on the list to get one when they are made available. Thanks for letting me know.
Old 12-27-2019, 05:32 PM #25
87pony 87pony is offline
87pony will become famous soon enough
Any follow up on this??
87pony is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 06:05 PM #26
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
HPTuners still not released for 4R
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 03:13 AM #27
Havik's Avatar
Real Name: Derrick
Havik's Avatar
Real Name: Derrick
I have sort of an update: Magnuson doesn't not provide any tunes for anything other than a stock vehicle. I was told they had tunes for basic things like an intake or cat-back. They do not. I spent a lot of time with them on the phone and asked a lot of questions. They do not tune for anything other than stock. All the people saying they have tunes for anything other than stock are wrong.
On another note, I spoke with "Gadget" from URD. He says that with the Magnuson setup (using the stock injectors) that the fuel system is maxed out and didn't recommend installing the intake until I was able to upgrade the fuel system. He said he would be able to send me the UCON system even though they don't have it on their site. So if you are interested in the UCON setup, give them a call. I have not yet ordered one, so I can't say anything about it.
I can tell you that my wideband O2 sensor has never shown my truck running lean under boost so I don't think there is anything to worry about.
Old 12-31-2019, 11:14 AM #28
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Part number for larger injectors?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 07:25 PM #29
VB.TRD.Pro's Avatar
VB.TRD.Pro VB.TRD.Pro is offline
VB.TRD.Pro will become famous soon enough VB.TRD.Pro will become famous soon enough
VB.TRD.Pro's Avatar
Does Magnuson request a datalog after installing the SC and let you know what they're seeing in regards to IDC?
Looking at the URD system, it replaces the fuel pump and injectors. Sounds like it isn't as simple as swapping out injectors or can it be as simple as an injector swap?
2021 Lexus GX460 Premium Plus + Sport Design Pkg
2019 VooDoo Blue 4Runner TRD Pro
2016 Nissan GT-R Black Edition
VB.TRD.Pro is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 09:31 PM #30
jackjoachim jackjoachim is offline
jackjoachim is on a distinguished road
Just curious what type of power numbers are y'all shooting for?
jackjoachim is offline   Reply With QuoteReply With Quote
additional , magnuson , tuner , work , works
Are there performance tuners you can buy? Mikeyt 3rd gen T4Rs 18 12-13-2023 08:12 PM
5th gen tuners/programmers mikenac 5th gen T4Rs 26 12-21-2016 10:32 AM
Mobile tv tuners / DTV? A/V1 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 09-27-2008 02:39 AM
