02-03-2018, 01:43 AM
Alternate Rack
Lets talk about something other than Gobi and Baja. There seems to be a million threads on them. I want to see alternate roof rack set ups. Frontrunner, K9, Ect......
02-03-2018, 01:50 AM
Real Name: Krister
Real Name: Krister
Order yourself a Drabbit's!
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
02-03-2018, 02:26 AM
Those racks look pretty sweet. I recently pulled the trigger on a frontrunner. I was mainly just curious to see other setups.
02-03-2018, 09:44 AM
If you don't need a full rack and want a good one that is actually readily available... i just installed a Warrior rack.
Consolidated 5th Gen Roof Rack Guide
2016 Trail and half of an early 90s Ford Ranger
02-03-2018, 11:06 AM
Real Name: Jacob
Real Name: Jacob
Or, if you don't need a full rack, Ruggedized Crossbars...
02-03-2018, 01:23 PM
Link?
02-03-2018, 01:40 PM
Originally Posted by tundra555
Link?
Google much?
02-03-2018, 02:37 PM
Drabbits haha have not seen that in a minute! Glad I dodged that bullet.
Check out "OUTGEARSOLUTIONS" on instagram. Joe is a stand up dude and does some great quality work.
02-03-2018, 04:08 PM
Real Name: Jonathan
Real Name: Jonathan
If you want something inexpensive, lightweight, easy to take on and off and pretty versitle, look at the Rhino Rack steel mesh platform.
Steel Mesh Platform | Rhino-Rack
I have it and really like it.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
02-05-2018, 05:55 PM
How is it mounted on the oem rack?
2013 Toyota 4Runner Trail - Silver - (285/70R17 - 255/80R17) Cooper Discoverer S/T MAXX - TRD Bilstein Suspension Kit
1991 Toyota MR2 Turbo - Black
02-05-2018, 06:02 PM
Real Name: Andrew
Real Name: Andrew
I just ordered myself a Prinsu designs 7/8 rack! For half the price of a Gobi, you should check it out! They also make a 3/4 rack and full rack.
Best part of the 7/8 is that you get the "full rack" feel without having to deviate from the OEM mounting spots. All aluminum, so no rust/lightweight and the cross members are simple aluminum pieces of extrusion, so you can basically attach anything to them.
I can't speak to the quality because I don't have it yet, but it is a sister company of CBI, so I'm sure it'll be top notch!
EDIT: I ordered my rack last Wednesday (1/31/18), just received shipping confirmation that it'll arrive to my doorstep on Friday (1/9/18). Talk about quick turnover...you don't see that with a Gobi!
Best of luck in your roof rack hunt!
08' Limited V8 (2020-Current)
17' TRD Pro (Sold: 2017-2020) - Update/Mod/Build/Adventure Thread
08' Urban Runner (Sold: 2010-2017)
02-05-2018, 06:18 PM
I got a Rolla that mounted up pretty solid on the included pinch mounts and can be made (with aftermarket hardware) to attach to the stock roof mounts. Cheap and easily sourced (no wait) as well.....
02-05-2018, 06:44 PM
Real Name: Jonathan
Real Name: Jonathan
Rhino sells u-bolts that attach to the factory crossbars. I've been considering using heavy duty zip ties for easier off and on. The u-bolts aren't hard, just tedious to unscrew two knobs per corner.
02-05-2018, 06:55 PM
What size rack did you get?
I am think of using the Rola Rack Mount Kit.
03-09 4RNR Rola Rack Mount Kit
But I'm not sure if it will work.
02-05-2018, 07:01 PM
Real Name: JD
Real Name: JD
Ahhhh Drabbits. Last I heard there are people still waiting on their racks from 2015.
2016 SR5 Mod List: I put gas in it
