08-29-2019, 07:43 PM
Picture request please.
I am looking for pics of 285/70/17's on a 4 Runner with no lift and with a lift. I am planning on getting new wheels but I got a really good deal on Wildpeak M/t01's. The lift won't be done until December since I will not be driving a hour to work, it will be a 20 minute commute then.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
08-29-2019, 07:50 PM
Not sure you can fit 285s without some sort of lift?
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
08-29-2019, 08:03 PM
I have no clue, that is why I am asking, If not then I will just keep the tires in the garage until I get the lift on. There are a ton of build threads but it's hard to find things on this site because everything is spread out over multiple boards. If it ca't be done, then Ill take a pic of 285's with a 3 inch lift. I have a OME kit sitting in the garage.
The Build
08-29-2019, 09:59 PM
Yeah, there are a ton of threads on this. you can fit 285/70/17's on a stock suspension. you will need to
1) remove the screws that fix the bottom of your fender liner to the bumper cover
2) push your fender liner as far fwd as possible, drill new holes in the bumper cover and then reattach the fender liner
3) trim the now excess portion of your bumper cover
you will rub like hell when turning in reverse, but it will float you until you get your lift installed. I did this with general grabber at2s
Troner envy... the struggle is real!
08-29-2019, 10:01 PM
this
