Old 08-24-2019, 03:28 PM #1
FamousAv8er's Avatar
FamousAv8er FamousAv8er is offline
FamousAv8er is on a distinguished road
No Spring Compressor...Remove Sway Bar?
Doing my install now. Do I NEED/WANT to remove my sway bar to do the no compressor strut install?
Also any torque specs are appreciated.
Also +1 : do I need any red/blue lock when reinstalling any of these bolts?
Daily Driven '17 T-Force T4R - Baja Flat Rack - 5100s
odo: 80,000
FamousAv8er is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 05:37 PM #2
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
Generally, you only need a spring compressor if you’re swapping coils on a strut, not for a strut install. More details would help.
But yes, if installing new struts, disconnecting the sway bar links from your spindles will help.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 06:07 PM #3
71gs3504sp's Avatar
71gs3504sp 71gs3504sp is offline
Real Name: George
71gs3504sp is on a distinguished road
71gs3504sp's Avatar
Real Name: George
[QUOTE=FamousAv8er;3344468]Doing my install now. Do I NEED/WANT to remove my sway bar to do the no compressor strut install?
You don't need to remove sway bar at all, just the bottom end link to the lower control arm. To remove you need to loosen the both bolts on the lower control arm and let the arm swing down so you can just remove the strut with spring.
2018 4Runner SR5
2002 4Runner Limited (low mileage, my dad purchased new)
2008 FJ with Off-Road Package (191k miles) Sold 6-19
71gs3504sp is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 06:07 PM #4
Any tips for if my lower arm isn’t going low enough? I’ve loosened the bolts quite a bit
odo: 80,000
Old 08-24-2019, 06:51 PM #5
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
I believe you can use a bottle jack stuffed up in the wheel well pushing down on the upper control arm which will also push the lower arm down
Mantilgh is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 06:52 PM #6
agentcross agentcross is offline
agentcross will become famous soon enough
I literally did this today and DID NOT remove sway bar
agentcross is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 06:53 PM #7
hwnrunner's Avatar
hwnrunner hwnrunner is offline
hwnrunner will become famous soon enough hwnrunner will become famous soon enough
hwnrunner's Avatar
Use the floor jack handle or long breaker bar etc to leverage it down.
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
hwnrunner is offline   Reply With QuoteReply With Quote
Old 08-24-2019, 06:53 PM #8
Did you remove the two nuts on the LCA and loosen the alignment cam nuts to the rear of the LCA? My LCA was hanging at 180 degrees today when I did it
Old 08-24-2019, 07:30 PM #9
So we got the lava and everything together. Do I want any blue or red lock on the ball joint bolts
odo: 80,000
Old 08-25-2019, 01:45 PM #10
Fronts are all solid. For the rear 5100s do I need the middle washed from the stock struts?
odo: 80,000
bar , compressor , install , remove , sway
HELP: Need Spring Compressor - So. Cal / S.Bay jasxn 5th gen T4Rs 3 08-08-2017 02:56 PM
spring compressor aarona3184 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 08-01-2013 07:35 PM
no need for a spring compressor Elton H 3rd gen T4Rs 33 08-20-2012 06:47 AM
Spring Compressor (used once) jerseygeorge Classifieds - buy & sell (no commercial ads please) 0 08-23-2008 12:03 PM
strut compressor vs. spring compressor jmrwd3 3rd gen T4Rs 6 05-19-2008 03:03 AM
