Originally Posted by AZTrail
my 2016 T4R had 20 miles on it . I jacked up the truck to see how this was gonna work out and if the spare would drop etc etc... the toyota jack is a POS ,,, dangerous and unstable.
I now use a 12 ton bottle jack with a 14 inch lift. I also have a short bottle jack 10 ton 6inch to 9 inch so I can lift the front wheel off the ground with out jacking on the frame I jack up the front wheels on the lower control arm much safer ...vehicle is level when the front wheel comes off the ground so less apt to roll etc...also I carry wheel chocks to hold the vehicle .
I also found that I had to get a screw driver to get the jack to work which was not supplied , thanks Toyota .
