08-25-2019, 11:31 AM
Transmission S shift issue?
I find it odd that whenever shift into (S) sequential shift mode it always goes into 4th gear no matter my speed. But I could still shift into any gear.
I also have an oddity when running close to 80mph using cruise control and it downshifts on a hill to 4th it seems to get stuck in it. And when I switch to S mode and try to manually shift it won't.
Very odd?
Sent from my SM-N960U using Tapatalk
Reason: 2019 4R 3000mi
08-25-2019, 11:37 AM
I've been using the S shifter to pull a light utility trailer for the last few weeks. All it really does when you shift it is eliminate 5th gear from the equation. Also using it doesn't mean you have to manually shift 1 to 4 as you go. It mostly eliminates the top gear depending where you shift it to but will still go through the gears like it was in D.
Hills and cruise control don't mix well especially a heavier car at 80 mph. For decades cruise control has done a crappy job with upshifts and then downshifts.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
08-25-2019, 01:21 PM
That makes sense it is a pretty heavy truck so it getting stuck in 4th I guess makes sense with cruise control. It's just odd when I disengage cruise control I can't use the S manual shift to change gears, just stays in 4th till I throttle in a bit to get it to shift out.
08-25-2019, 02:14 PM
Real Name: Max
Real Name: Max
5th Gen 4Runner transmission programming at it's finest
Ultimately you'll have to adjust your driving to match what the transmission wants to do...
08-25-2019, 02:42 PM
I feel much better if that's just the way it is. I've had issues with every single transmission in every single car I've ever owned except for my last Mazda and hopefully this. So I'm a little bit sensitive to transmission oddities.
08-25-2019, 02:56 PM
Real Name: BobH
Real Name: BobH
Modern cars with computer controls for engine and transmission. I get along fine with mine, we have to do it the Toyota way.
I miss my old GM car before electronic controls. I put in a B&M Shift Kit and made it do what I wanted when towing.
08-26-2019, 11:29 AM
it should manually shift, and generally it will drop down a gear when you push over into s-mode. it definitely does more than just eliminating 5th gear on mine (which it doesn't eliminate, you can shift into 5th just fine in s-mode)
mine definitely lets me shift manually and to the gear I want including shifting into overdrive. the transmission won't let you over-rev the engine, but it should let you drop down multiple gears. I used S-mode daily, the power band is pretty high so for merging and passing I just downshift in advance and then I donn't have any complaints that way about power or throttle response.
08-27-2019, 02:16 PM
That's what's so weird. I can manually shift all the time except for when it gets stuck in 4th gear in cruise control. I'll slide it over to S and it'll just stay in fourth.
I'll play around with it some more and have to dealer check it out when I see them at my five thousand Mile check up
08-27-2019, 02:40 PM
There is nothing wrong with it. It's not a manual mode in the way you think it is. It is a gear-limiter. Nothing more. When you see s4, it is locking out 5th. When you bump it back to s3, it will lock out 4th and 5th (assuming you aren't going too fast). So sure, if you're going in-town speeds, moving the shifter back and forth, it will feel like a manual mode. But on the highway, when you are in D and cruise control is active, and the trans is in 4th due to load and speed, there is nothing you can do to get it to upshift to 5th with S mode. If you want it to upshift, you'll need to turn off cruise and slow down (or otherwise remove load from the engine).
08-27-2019, 03:05 PM
uh, i s-shift into 5th daily
08-27-2019, 03:52 PM
We get it, he is saying it won't manually shift to 5 when he is in cruise control.
08-29-2019, 03:38 PM
Okay, if that's the way it is i can accept that. Its dumb, but its just the way it is. Thanks for the clear explanation.
My Mazda would shift into any higher gear i chose no matter the speed since up shifting is never an issue. Guess Toyota does not see it that way.
08-29-2019, 04:48 PM
Real Name: Jim
Real Name: Jim
I'm always in S mode around town. I see no need to shift thru all 5 gears when not going above 45. Not having that top end gear available gives me much better pedal acceleration when downshifting , braking and control on surface streets.
Lovin' my 4R
08-29-2019, 04:50 PM
But you will also have a loss of MPG. Not that it matters on an 4R. lol
08-29-2019, 06:49 PM
My understanding is shifting to "S" lets you pick the HIGHEST gear available, so the default is 4th. If you slow down the transmission will still shift to 3, 2, 1, unless you pick a lower gear.
So, putting it manually in "1" only lets you use first gear, "2" is first and second, and so on.
I feel like it also changes shift points. The lower the number, the higher the revs before it shifts. Anybody else feel this?
2018 TRD Off Road Premium - Barcelona Red
