08-30-2019, 01:34 PM
#16
Real Name: Jim
Real Name: Jim
Originally Posted by Thrasher_S
My understanding is shifting to "S" lets you pick the HIGHEST gear available, so the default is 4th. If you slow down the transmission will still shift to 3, 2, 1, unless you pick a lower gear.
So, putting it manually in "1" only lets you use first gear, "2" is first and second, and so on.
I feel like it also changes shift points. The lower the number, the higher the revs before it shifts. Anybody else feel this?
Your understanding is correct and the way a shift limiter works.
I hadn’t noticed any change in shift points, but when wheeling on dirt I really prefer to be in control of the gearing more by using the “S” mode. Going up a steep hill in 4lo I may not want it to be able to shift out of first until I’m ready.
Now in city traffic I think hitting 5th gear when going 30mph is counter productive and the main reason I leave 4th as my top gear. I notice much better acceleration. After backing out of my garage the first thing I do is put it in “S” mode.
I wonder if there has ever been a forum poll done on driving in “S” mode as a preference when applicable and if the driver notices improved performance.
Lovin' my 4R
08-30-2019, 04:22 PM
#17
this isnt a sports car
08-30-2019, 04:30 PM
#18
True. But if there is a additional gear and there's an option to manually shift I should be able to choose it. LOL
Sent from my SM-N960U using Tapatalk
08-30-2019, 04:34 PM
#19
The car isn’t going to let you do something that won’t work. You’re driving a 4.5k lb brick at 80mph up a hill. It’s physically not possible to maintain that in 5th gear. Have you ever tried riding a bike in the highest gear up an incline? It’s like that.
08-30-2019, 08:44 PM
#20
Using S mode and staying mostly in 5th on the hwy makes no noticeable difference in fuel economy from my extensive experience. I soon realized using 4th for long hwy hillclimbs will keep the transmission from hunting between 4th and 5th and it works well with CC. Obviously a long hillclimb will kill your Mpgs but you’re not doing any favors trying to get it in 5th sooner.
S mode is also damn useful in keeping the dreaded unwanted downhill downshift in check.
After renting a Chevy equinox and driving a few Hondas lately, I’ll take the 4R tranny quirks any day. CC still sucks though.
08-31-2019, 10:34 AM
#21
Absolutely. But let me give a more specific example.
I'm in cruse control at 78mp and 3/4 up the hill it drops to 4th, i crest the hill and start going down and its still in 4th, i disengage cruse control and its still in 4th as it decelerates. I manually go into S mode and try shifting to 5th and nothing (im now at ~70mph). So i put it back in D and pump the gas and it goes into 5th.
This seems to only happen with this exact scenario.
08-31-2019, 11:19 AM
#22
Totally normal. All part of Toyota's "grade logic" programming for the trans. In this particular case (cresting a hill), the trans will hang onto 4th for way longer than necessary because it "thinks" the uphill grade might resume, requiring another downshift into 4th. The programming would rather stay in 4th too long and be absolutely sure you're done climbing hills than shift into 5th too early and start having to "hunt" between 4th and 5th. And yes, trying to "tell" it to shift into 5th using S mode will have no effect in this scenario.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
08-31-2019, 12:00 PM
#23
Banned
Real Name: Mark
Banned
Real Name: Mark
I run into this annoying uphill scenario when driving *without* cruise control. As I crest the hill in 4th and the road levels out, or even starts to decline, the transmission stays in 4th for quite a while, even if I back off on the pedal to lighten the load. After what seems like a long time, maybe 5-10 seconds, it finally shifts. My 3rd gen did not behave this way. After the transmission downshifted during a hill climb or accelerating to pass a car, when I’d lighten up on the pedal the transmission would rather quickly up shift.
Damn “grade logic”.
08-31-2019, 12:14 PM
#24
Real Name: BobH
Real Name: BobH
In my 2013 I always put it in S5 upon startup, this reduces the lag when wanting a downshift on a freeway ramp and does appear to slightly help the shift points.
When off-road I always use S mode to limit it to S2 or S3. Sometimes S4 when in 4L and on sand.
08-31-2019, 12:22 PM
#25
The manual does talk about this issue, but not in great detail. It has sections on S mode and AI-Shift mode.
"The engine speed may remain high after releasing the accelerator pedal. This does not indicate a malfunction".
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
08-31-2019, 12:57 PM
#26
Really only use the S mode for when I want to rev out higher. Whether that be when going up a steep incline on the trail, mud/snow, or when there's a short onramp.
08-31-2019, 08:22 PM
#27
Really great info. Thanks for confirming this is normal. I'm so paranoid about my transmissions in my vehicles because I've blown so many over the years.
I guess the next question is when is the best mileage to change the transmission fluid? Lol
08-31-2019, 11:23 PM
#28
Changed mine at 55. Supposedly it's a "lifetime fluid" unless you do a lot of towing, but mine was already dirty. Then again I do have some added weight with the bumper, winch, rock sliders, as well as have bigger tires. All of which will cause more work for the transmission.
I just did a fluid exchange though, not the full hardcore dropping the pan and what not.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
