Old 08-26-2019, 10:06 PM #1
daesonn daesonn is offline
daesonn is on a distinguished road
Need approval for tire/wheel/suspension combo
Hey guys,
Did some research and got some parts picked out. I know putting these things together can be a matter of compatibility sometimes and since I'm going to be doing things myself most likely I just want to make sure the parts I have picked out are going to be compatible and smooth riding!
I have a 17 TRD offroad with stock tires, wheels and suspension currently at 50k.
If you have any alternative recommendations or sizing, or things I should expect, please comment! Thanks!
Parts list:
Eibach Pro Truck Lift
JBA Offroad Upper control arms
SCS Ray10 17 X 8.5 6 X 139.7 4.30" -10mm
BFG KO2 AT 285/70/17
daesonn is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 02:34 AM #2
northcoast's Avatar
northcoast northcoast is offline
northcoast will become famous soon enough
northcoast's Avatar
I just got done posting about this in the Eibach thread. That offset with the 8.5 might be too much for 285s.
Only speculating, I'm a total novice. I did find this on another thread: "17x8 with 4.5" BS and 0 offset is the perfect wheel on the 5th gen. Least chance of rubbing and a flush with the fender look." From this page Best offset to be flush with 285s
Someone please correct me if I'm wrong!
2016 Nautical Blue T4R TEP w/KDSS, Oil Filter canister upgrade, Eibach Pro Truck lift 2.75/1.0, JBA UCAs, XD Machete 17X9 Wheels, Falken Wildpeak 275/70/17.
northcoast is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 02:18 PM #3
nimby's Avatar
nimby nimby is offline
nimby is a jewel in the rough nimby is a jewel in the rough nimby is a jewel in the rough
nimby's Avatar
You're approved on the suspension, tires, and UCA's.
I would like you to do some more homework on the wheels, however. If you were using the stock wheel width / offset / backspacing you would have no problems, or possibly only have to complete the fender liner mod. With this set-up, you might need one of these or possibly all of them:
Body Mount Chop
Removal of mudflaps
Fender liner mod
nimby is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 02:47 PM #4
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
Suspension approved
haha
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 05:49 PM #5
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
you'll get minor rubbing with those rims, but you will be ok for the most part.
Old 08-27-2019, 06:00 PM #6
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Not tracking JBA "off road" control arms. Stock replacement, STD high caster and HD high caster.
"Please Note: 32.7" and larger diameter tires need aftermarket wheels with less then factory wheel back space. Tire Size Calculator
Wheel recommendation
LT285/70R17 (32.7" x 11.2") tire on 17 x 9 wheel, -12mm offset (4.50" backspace)
LT285/70R17 (32.7" x 11.2") tire on 17 x 8.5 wheel, -9mm offset (4.30" backspace)
LT285/75R16 (32.8" x 11") tire on 16 x 9 wheel, -19mm offset (4.25" back space)
LT255/85R16 (33.10" x 10") tire on 16 x 8 wheel, -12mm offset (4" back space)
LT315/70R17 (34.4" x 12.4") tire on 17 x 9 wheel, -25mm offset (4.00" backspace)
Tire sizes that work well with the JBA UCAs
265/75R16 tire 31.6" x 10.4" on factory wheels
255/75R17 tires 32.1" x 10" on factory wheels
275/65R18 tires 32.1" x 10.8" on factory wheels
Any tire that is 32" diameter and smaller there is no fitment problem. "
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 06:06 PM #7
Charlievee's Avatar
Charlievee's Avatar
LT285/70R17
116/113Q C BSW 32.8" 11.5" 7.5-9" 8.5" 15/32" C - 6 ply 2755/2535 lbs 50 psi 99 mph 50.3 lbs Black 635
LT285/70R17
116/113Q C RWL 32.8" 11.5" 7.5-9" 8.5" 15/32" C - 6 ply 2755/2535 lbs 50 psi 99 mph 51.4 lbs Black/White Option? 635
LT285/70R17
121/118R E RWL 32.7" 11.5" 7.5-9" 8.5" 15/32" E - 10 ply 3195/2910 lbs 80 psi 106 mph 57.9 lbs Black/White Option? 635
Old 08-27-2019, 06:12 PM #8
Charlievee's Avatar
Charlievee's Avatar
Best to ask forgiveness then to ask permission.
Old 09-25-2019, 11:01 PM #9
@Charlievee so would I be better off not purchasing JBA UCA with my selected options then? Could you be a little more clear?
Old 09-25-2019, 11:10 PM #10
@nimby what am I missing exactly? Aren't SCS wheels made for Toyota trucks with aftermarket tires and suspensions? And how else could I achieve an (almost, if not) even line between the outside of my tires and my fenders without a negative offset/using wheel spacers?
Old 09-25-2019, 11:43 PM #11
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
People way over think this. Especially if you’re getting UCA’s. Find the wheels you want. Buy them. Find the tires you want. Buy them.
Yes back spacing plays a role and all tires are different blah blah blah.
I’ll say it before someone else does.....there’s literally a thousand threads about tire and wheel fitment. I’m running a 12.50” wide tire on my SCS wheels just fine. Have a huge amount of space to clear the UCA.
As someone stated. SCS is literally made for Toyota.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 12:04 AM #12
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
SCS wheels. Hub centric, lightweight, perfect offset. No guarantees, but fender liner mod and mud flap removal most likely if you get 285/70R17. Probably no BMC. Liner mod easy. I would do it again if I got a new 4Runner. I just chose ToyTech Boss and SPC UCAs but your setup would work perfectly fine.
I am sure you know, but expect poor gas mileage.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
50k , offroad , parts , picked , things
WTT: 2019 SR5 wheel+tires (250 miles) for Black wheel-AT Tire combo ToyoRuski Want to Buy/Trade 0 11-10-2018 11:23 AM
WTT: 2019 SR5 wheel-tires (250 miles) for Black wheel-AT Tire combo ToyoRuski For Sale: Suspension/Wheels/Tires 0 11-09-2018 07:54 PM
FS: 2016 4runner Trail - 4 Wheel/Tire Combo + 1 spare tire (Houston, TX) brg128 For Sale: Suspension/Wheels/Tires 2 03-21-2016 08:54 AM
Advice on tire/suspension combo sunnywala 4th Gen T4Rs 14 12-29-2014 01:09 AM
Wheel/tire combo??? pathfinder_88 3rd gen T4Rs 0 11-05-2010 06:10 PM
