Old 08-29-2019, 12:57 PM #16
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
Originally Posted by deadbeat son View Post
Therein lies your problem "driving at altitude". It's not the altitude, it's the reduction in power from going with a 33" tire on the stock gearing coupled with the grades you're pulling on I70 west of town. It's a tradeoff you either have to deal with, or re-gear to correct the overall ratio and restore the factory power.
I can see how the tire size is a contributor but it was the same experience with 265s. Maybe not as extreme.
Once I wear these out I’ll probably go down to 275s or do the 255/80
But that’s a ways off.
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 04:30 PM #17
Bergz Bergz is offline
Bergz will become famous soon enough
Hey mscot,
I didn't read all the replies but wanted to chime it. I'm also in Denver and have the same ToyTec lift as you do. I started with K02's at the time of the lift and had the same crazy harsh ride you are referring to. I switched to the Ridge Grapplers and really wish I would have started there. The ride is literally half as rough as it was with the K02's. Night and day difference, IMO. Also, not sure if your running spacers but they will greatly increase the harshness as well. For driving at altitude, I can say the Sprint Booster is almost a must have for our rigs in the Mtns. It's made a HUGE difference for me both around town and in the high country. I do have a CAI and a high-flow exhaust as well, which I'm sure helps "some" . Good luck!
__________________________
2014 4Runner LE - XD Grenade OR 17" Gunmetal Wheels - 285/70/17 Ridge Grapplers - XREAS Delete - ToyTec BOSS Suspension Lift w/SPC UCA's - Borla Catback Exhaust - AFE Momentum GT Pro CAI - Sprint Booster (wow!) - Tint Match - AVS Aeroskin - K&N Washable Cabin Air Filter - Black Emblem Kit - Stock Running Board & LE Rocker Trim Delete - Added RSG Flat Sliders w/bump-out & TE Rocker Trim - Full LED Swap - Rola Rack & Fox Wing Awning: Skids, lights and new front end w/Slimline bumper & winch still awaiting clearance from the tower...
Bergz is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 04:36 PM #18
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
I upgraded my Toytec lift to Icon and moved to California.
Solved both problems.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 05:47 PM #19
Oregon1 Oregon1 is offline
Oregon1 is on a distinguished road
So general question - with larger tire choices is it the weight or the diameter that really has an effect? Im running KO2 E 275/70/17 which claim to be 56 lbs each - I've been thinking of going to the P rated Falkens 285/70/17 which list as 51 lbs each - does the jump in diameter offset the drop in weight?
Oregon1 is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 05:57 PM #20
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
the diameter will have more affect. it changes the overall gearing. it just slows the crank down too far, gets its below the necessary torque area.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 06:56 PM #21
deadbeat son deadbeat son is offline
deadbeat son is on a distinguished road
Interesting. I've had a 2nd Gen Tacoma, 4th Gen 4R V6, and 2 5th Gen 4Rs and haven't had the issue you speak of. I could definitely feel the effects on the Tacoma after switching from the stock 31" tires to aftermarket 32" tires. All of the 4Runners had/have stock sized tires and I felt there was plenty of power for the I70 racetrack.
deadbeat son is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 09:03 PM #22
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
For performance, both.
The Wildpeaks will be better than Ridge Grapplers in the rain, but the latter are 44 lb in 285 and that will make a difference. Maybe the G2 is better in the rain than RG and just as light, not sure if available in P285 though.
For tire size, neighboring sizes can almost overlap depending on models. In your case, the KO2 is 32.2 and the Wildpeak is 32.8. It is not a huge difference but it will be easily felt vs stock. For tread width, they totally overlap and a 265 can be wider than 275 or even match a 285.
So you gotta look at all numbers. Tire Rack is the best for that purpose, for the tires they carry anyway.
Old 08-29-2019, 11:15 PM #23
Horsethief Horsethief is offline
Horsethief will become famous soon enough Horsethief will become famous soon enough
Stock tires are 39lbs each, 56lbs is super heavy! Why are you running an E rated tire? I'd drop down to a stock size or 255/75/17 in a P rating, that will be more like the stock weight and should make a noticeable difference. For instance, a 255/75/17 Duratrac weighs 39lbs.
Also, I had my 4R in NH last week, It was struggling in the 3000' altitude range, I cannot imagine driving this thing in CO. Honestly, if I frequently drove in the mountains I would not have bought this.
Horsethief is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 01:58 PM #24
It’s hard for me to believe that all of us knuckleheads running 33s in CO have spent $2k+ on regearing.
I may try the CAI and leaving it in 4th while climbing to see if that helps.
Kinda stuck on the suspension. I’m worried about spending more money and it still riding this stuff - knowing that no two 4runners are the same.
Maybe I can ride in someone local with a king set up and a eibach pro set up to see what it think.
Nonetheless thanks for all the advice everyone.
Build thread
Old 09-19-2019, 07:46 PM #25
Update: a week or so ago I went over to Toytec and road in a truck with KDSS that had their 2" Boss on it. It was a much smoother ride.
After some thought, I ended up buying the Eibach Pro Truck that people have been raving about.
I'll be picking it up tomorrow or Wednesday and installing it asap.
That means there is a very lightly used Toytec Boss Performance 2.5" suspension that will be on the market soon if anyone is interested.
Build thread
Old 09-19-2019, 10:32 PM #26
it feels pretty rough all over. I could definitely put the eibachs on the rear first and drive it around as I'll probably do it over two days anyway.
I had one of the guys at Toytec drive it and he said it's riding exactly as designed. Its just more shock than I need and I don't get out as much as I thought I would.
Build thread
Old 09-20-2019, 01:39 AM #27
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice
Real Name: Luke
For me it was an altitude/temp combination under load. Mostly the truck was fine, but dragging 3000lbs of trailer 2000ft up (I know, nothing compared to out west) at 94F ambient and 80+% humidity the truck was a dog trying to get up the grades of backwoods KY. I ended up with a SC, but there was an interim step where I was extremely happy for the cost. It was a combination of the aFe MomentumGT CAI and URD's MAF Calibrator.
Adding a CAI doesn't do much if you're not adjusting the computer for the additional air flow. This is especially important if you've changed the diameter of the tube near the MAF sensor, between the air filter and the throttle body. Adding a Sprint Booster or the like will change the throttle mapping, kind of like going to sport mode instead of eco-mode in some other vehicles. URD's MAF Calibrator will correct the readings of the MAF Sensor to be appropriate to the diameter of the inlet pipe and amount of air flowing through it. There was a noticeable (though not large) performance increase over stock in this configuration.
Also what octane fuel are you using? The engine will automatically adjust timing on a variety of variables. The smaller partial pressure (thinner air) at altitude means advanced timing because it takes longer to burn. Because of its tendency to pre-ignite, low octane requires retarded timing. The idea of 85 octane at altitudes came with vehicles pre-1984 when timing had to be manually adjusted. At that point the thinner air meant you could run a lower octane fuel which costs less and balanced with the timing advance required for higher altitude operations, hence less tuning and adjustments required. It was simpler for lower octane fuel to be sold in high altitude areas than to adjust the timing of every vehicle when they happened to drive through those areas. For those who live there, a timing adjustment was a better long term solution. On modern vehicles the computer will automatically adjust timing, so this is not as big of a deal. However, if you want more efficiency (which can translate into more power), try running a higher octane. Just know that it can take a couple full tanks for the computer to adjust to the better efficiency (or you can reset it by disconnecting the battery for about 2 hours).
Like anything it's likely a combination of multiple factors, high altitude, ambient temps (summer vs winter), lower octane fuel?, larger diameter tires, wider tread (more friction), lift (increased air resistance), and even more!
FWIW I also didn't care for the rough ride on the KO2 E load tires and dumped them in almost new condition less than a year after I bought them. Now running the Cooper Discoverer AT3's and they're much better.
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
2018 BMW 340xi M-Performance 6MT
Friggin Idiot is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 09:08 AM #28
Pandarturo Pandarturo is offline
Pandarturo is on a distinguished road
Suspension
Hey MSCOT,
I'm diwn in castle rock, just wondering how much uppity we're gonna sell your suspension for?
Pandarturo is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 10:02 AM #29
Dame-O's Avatar
Dame-O Dame-O is offline
Dame-O is on a distinguished road
Dame-O's Avatar
A turbo is the only real solution at altitude. I travel to the eastern sierras on a regular basis and have to climb the Sherwin grade. My 4runner needs to be high in the power band to maintain 70+ up the grade. In contrast my truck with a turbo diesel basically idles up the grade at 70+, even with my camper on it climbs better at elevation than the T4R.
2018 TRD Offroad
Eibach pro truck stage 1
Method 703 titanium wheels 17X8.5 0 offset
285/70/17 BFG KO2’s
Dame-O is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 10:43 AM #30
CO-Cygnus's Avatar
CO-Cygnus CO-Cygnus is offline
CO-Cygnus will become famous soon enough CO-Cygnus will become famous soon enough
CO-Cygnus's Avatar
The second is just the nature of the truck and where I live.
Driving to/in the mountains is a pain in the ass and we spend most of our winter back and forth from Denver to resorts (often quite tired).
You're constantly having to floor it to get the engine going when climbing hills and it is not a smooth acceleration at all.
Is there anything that can be done short of the supercharger? Would a new air intake or cat back exhaust help here?
Welcome to my world. I commute down to Golden for work a few days a week and just ended up getting a small turbocharged commuter car instead of constantly flogging the 4R over Berthoud Pass. Plus it helps keep the miles off of the 4R.
HP loss at altitude is real and you have to flog this truck a bit to get it to really move heading up Berthoud or Loveland... heck, even Genessee Hill.
CO-Cygnus is offline   Reply With QuoteReply With Quote
advice , answer , boss , toytec , truck
Need advice! Coolant boiling in high altitude Runs with Dougs 3rd gen T4Rs 36 06-18-2016 06:14 PM
Suspension upgrade (among other things?) XxTiBEARiusxX 3rd gen T4Rs 34 09-25-2015 10:26 PM
What's first things in suspension to fail herff 4th Gen T4Rs 6 10-08-2013 11:19 AM
Buying a 1995 4Runner - Advice?? Things to watch for?? ryanbigcheese Classic T4Rs 5 10-18-2012 12:28 AM
Advice: Things that can go wrong in Winter, and why... Thai Maintenance/Detailing 2 10-28-2004 01:15 AM
