Old 08-28-2019, 03:55 AM #1
XswampX XswampX is offline
XswampX is on a distinguished road
Multiple transmission overheating episodes
Transmission overheated multiple times up in Death Valley and the Eastern Sierras (CA) this past weekend.
61k on vehicle now. Magnuson Supercharger installed at around 40k miles (probably not relevant). Replaced factory trans fluid at around 9k miles (yes I know supposedly a lifetime fluid) with Valoline MaxLife ATF (full synthetic). My buddies stock SR5 had no issues.
It was warm on a slow climb in low gears (2Hi or 4Hi). Nothing close to as steep as what the vehicle can handle. Just going slow as it was a both bumpy/rocky and somewhat steep. It was basically a single lane dirt fire/access type of road. Vehicle was full of camping gear, food, water and 2 little ones. Nothing being towed. It was warm but not above 95 degrees. I kept going for a mile or so driving more gently after the first episode. No limp mode or forced stop (don't know if our trucks do so). Warning message was gone after leaving the truck sitting (engine off) for 20-30 minutes. Continued on up to the 8k foot summit without recurrence.
On the second overheating, similar conditions, I stopped immediately and the warning message was gone after a very short cool down, maybe 5 minutes max. It did not come back over the next 2 hours of climbing up to 10k feet.
It seems that the SC low temperature radiator blocks some considerable portion of the stock radiator (which as I understand it houses the transmission cooler), but largely speculative if this could be the cause or a contributor. I do also have some much bigger rubber than my buddy, 285 70 R17 BFG K02, but also doubt that is a factor. Anyone else experience this? I can't imagine I need an aftermarket trans cooler. I have not checked trans fluid level.
XswampX is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 08:26 AM #2
CharlesNellis CharlesNellis is offline
CharlesNellis has a spectacular aura about CharlesNellis has a spectacular aura about
I would get torque pro or a standalone transmission fluid temp reader to monitor temps before the check light comes on. By that time some of the fluid may be degrading already from excessive heat.
Maybe a full flush(not drain and fill) with toyota atf.
Multiple transmission overheating episodes-screenshot_20190822-152950_torque_compress76-jpg
CharlesNellis is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 10:15 AM #3
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
You caused this by putting the wrong transmission fluid in it. Sorry to be the bearer of bad news. Next time use the real stuff. Toyota fluid is more expensive, but it's the only ATF that is appropriate for this transmission. And you should never change it. Maybe you can flush it and put Toyota fluid back in and it'll work better. Hopefully you didn't damage the clutches.
This video will help explain why you should use the correct ATF.
Old 08-28-2019, 10:24 AM #4
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
The guys saying the Valvoline Synthetic Transmission Fluid caused this are full of shit. You aptly pointed out that the Supercharger Aftercooler blocked a good portion of the radiator which houses the transmission cooler. Then you were slow going up a rocky grade working the transmission hard with minimal airflow. Supercharger also working with aftercooler dumping heat in front of the radiator. That combination right there is your problem. Don’t listen to the OCD Toyota Fluids crowd.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 10:34 AM #5
Jetboy's Avatar
Jetboy's Avatar
Different oils have different lubrication properties. The wrong ATF results in clutch packs that slip more than they do with the correct fluid and create a lot more heat. This isn't rocket science. If you put brake fluid in your differential - it isn't going to last very long. If you put rotella in your gas engine - it isn't going to last very long. And if you put the wrong ATF in your transmission... guess what?; it isn't going to last very long.
It doesn't have to be OEM Toyota fluid - but it DOES have to be the correct fluid. And currently only Toyota, Aisin, and Ravenol (possibly) make the correct lubricant for these transmissions. Valvoline ATF is about as close to WS as 5-20 engine oil. As explained in the video if it's T4 compatible - it is not compatible with WS fluid.
Also FWIW - Toyota WS is actually pretty cheap. Less than $10/qt.
EDIT: After a search there are a few other "WS" fluids at least on the label. Idemitsu claims to have one that is WS formulated (and not T4).
Old 08-28-2019, 10:43 AM #6
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
Originally Posted by Jetboy View Post
You caused this by putting the wrong transmission fluid in it. Sorry to be the bearer of bad news. Next time use the real stuff. Toyota fluid is more expensive, but it's the only ATF that is appropriate for this transmission. ....
X2 on this!
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 10:56 AM #7
my bet is slow going with poor airflow. Putting toyota fluid in and seeing if the problem happens again is easier than adding an aux tranny cooler tho. Adding an Aux tranny cooler is stupid easy btw.
Old 08-28-2019, 01:22 PM #8
Thanks all.
I think we are on the same page here.
There is plenty of discussion online on Maxlife ATF vs. WS ATF and plenty of empirical evidence that it is perfectly fine in Toyota ATs. I think Maxlife is superior for the same basic, well established reasons that synthetic motor oil is better than conventional. Some also have pointed out that Maxlife has/likely has a superior additive package.
Old 08-28-2019, 01:28 PM #9
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Originally Posted by XswampX View Post
Thanks all.
I'd probably add a tranny cooler and put in toyota ATF for peace of mind...but its your money.........
Old 08-28-2019, 02:25 PM #10
Jetboy's Avatar
Jetboy's Avatar
Toyota WS is very likely full synthetic. But it's not fully disclosed anywhere I'm aware of. The additive package cannot be "better" unless you know what film thickness you're designing for, what porosity the friction pads have, etc. It is not possible to make an ATF that is better both for a honda transmission and a Toyota transmission for example.
You know what the problem is. You can deal with it how you'd like.
Old 08-28-2019, 02:37 PM #11
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
2hi or 4hi in a slow climb? Have you tried 4lo? That could lower the temps a bit.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 03:45 PM #12
Cement4R Cement4R is offline
Cement4R is on a distinguished road
It seems that the SC intercooler blocks some considerable portion of the stock radiator (which as I understand it houses the transmission cooler), but largely speculative if this could be the cause or a contributor.
Visual inspection of the radiator? Is it dirty/muddy, are the fins bent, etc? Did this problem occur after a run in with some dirty conditions or something that would have damaged the fins?
With the IC blocking flow, I’d imagine any reduced efficiency due to the above could push your temps out of the normal operating range.
Cement4R is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 03:45 PM #13
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie has a spectacular aura about Teamoatmealpie has a spectacular aura about
Curious as to why the fluid was replaced at 9k? Was there a problem that initiated that?
Teamoatmealpie is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 04:02 PM #14
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
Better to have gone with Toyota WS or Aisin WS (most likely the exact same thing as Toyota WS).
I don't trust those Valvoline universal ATF for our transmissions.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 04:34 PM #15
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
So if it was the inter cooler blocking air flow, whats the fix? Duel fans, moving the trans cooler, larger radiator?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
cooler , fluid , trans , transmission , vehicle
Why is my transmission overheating?? 96TrailSurfer 3rd gen T4Rs 12 01-26-2021 04:11 PM
Transmission Overheating - Torque Converter Issue? 96TrailSurfer 3rd gen T4Rs 15 08-03-2018 11:52 AM
Transmission Overheating BE4Runner 3rd gen T4Rs 12 04-27-2017 03:43 PM
1990 4runner auto transmission overheating mexico General Discussions 3 09-02-2012 10:25 PM
1990 5 Speed Manual Transmission Overheating Tucson T4R Classic T4Rs 1 08-29-2005 01:32 PM
