Old 09-06-2019, 12:34 AM #16
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
Originally Posted by Agent_Outside View Post
Running wiring and planning out a slide mount.
I only have 3 rivnuts on hands so I had to order more but here's the plan. I made a cut a board out of 1/2" birch plywood and shaped it slightly to fit snug up against the passenger side trim. I'm going to put 2 or 3 rivnuts in that crossbar to mount th front of the board. I verified its open under neight the bod so I'll put 2 or 3 more in the back along with metal spacers. I'll cut out holes in the styrofoam layer for the spacer to pass through. I cut the insulation off the underside of the trunk carpet where the board will sit to reduce the height a little bit. Right now I'm still waiting on the fridge slide to continue, its held up being shipped out of FL because of hurricane Dorian causing problems. Once the board is mounted I'll line up the slide to have it as far forward and the side as I can without anything hitting anything. When the mounting is figured out I'm going to use pronged t nuts inder the board to mount the slide from the top. I'd trim down the board as much as possible then Bedliner the whole board to keep it protected and waterproof. With this setup when I take it out for ski season its 4 quick bolts to remove the side and no other hassle.
It should right about here, it'll still clear the privacy cover.
I got the wiring almost buttoned up yesterday. Its ran, it's grounded, and I put some temporary terminals on it to just to turn it on so I could verify the wiring. Dometic has a hardware socket kit thats 25 feet of 10 gauge wire, seeing as I'm running one of the smaller fridges and my run of wire is only about 17 feet or so I opted to go with 12 awg. the temporary hook up was to verify the wire is gauged ok to not impede function. As the fridge compressor starts the max voltage drop on startup is right around .28 volts, that'll work fine. 0.0 is ideal but not worth running like 6 or 8 awg. The performance will be just fine, the one potential concern is the battery protection could kick in earlier if it thinks the battery is lower than it is because of a voltage drop. But, I have everything aftermarket running through a low voltage disconnect right at the second battery so I don't need to utilize the fridges internal battery protection.
I realize I didn't take many pictures, I'll try to grab a few more today, especially if I finish up the wiring.
Fridge seems small for a family of three and a case of beer. Just sayin’.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 09-07-2019, 11:04 AM #17
Agent_Outside's Avatar
Agent_Outside Agent_Outside is offline
Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice
I don’t need a case of beer to enjoy the outdoors with my family
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 05:37 PM #18
I went out of town for a few days and then got sick. Today I finished up the car side wiring. Still waiting for the slide to move forward from here. It should get delivered Thursday, we’ll see how much I can get done before I go back out of town again.
Old 09-14-2019, 05:18 PM #19
I got the fridge install finished.
I was kinda planning out the space. I didnt have enough rivnuts on hand so I had to order more but this was the gist of it. I wanted to to do 3 rivnuts along the brace and 2 towards the back with spacers.
Rivnuts installed
I cut off the insulation from the underside of the carpet where the board would sit to give it a more solid surface on the hard foam under the carpet and bring the overall height down a hair.
I countersunk the 5 holes to mount the board the to the floor of the body so it sits flat and flush and for the side to attached I used pronged t nuts that were glued and hammered in. Then I coated the board with black primer/sealer scuffed it up and hit it with 4 coats of bedliner.
I cut holes in the thick foam for the spacers to slide in, then I cut small holes in the trunk carpet for the bolts to pass through and I cut out a scetion of the Canvas Back liner so it can just be permantly sandwiched in there and mounted up the board. Its supper solid, it doesnt flex or move.
From there I bolted up the DFG Offroad slide.
I checked to see how long I'd need the wiring before cutting the 12v plug off and installing an Anderson SB50 connection.
When I was planning everything I was measured known dimensions out with a tape measure and made some assumptions about the unknowns and it was going to be to close to tell if it would fit with the privacy cover or not. I'm happy to say it all came together exactly how I had hoped.
You can retract the cover and the fridge can be opened and closed as it sits. With the cover in place, it can be slid right out and opened.
YouTube
clear , cover , fit , roller , slide
5th Gen ARB Fridge Install Cypher 5th gen T4Rs 38 10-19-2021 02:50 PM
Fridge install advice? Louisiana Overland 5th gen T4Rs 17 07-21-2018 11:31 PM
Fridge Install Help Louisiana Overland 5th gen T4Rs 5 04-29-2018 09:27 AM
ARB fridge wiring loom install help Toycdn 5th gen T4Rs 14 07-27-2016 02:55 PM
Electrical Wiring(lights, fridge, etc.) - 1 wire or 2 wires jicko General Discussions 12 09-15-2015 08:03 AM
