Old 03-02-2022, 11:19 PM #16
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
Originally Posted by Fadelio View Post
Has anyone figured out how to mount the radio faceplate like that?
Don’t know. Maybe some L bracket that bolts to something under the plastic head liner thing.
I wanted to ask others experience with ditch mount NMO style. I did this but it provides no ground plane and I don’t think I get good range from it. I installed a proper braided ground strap but that didn’t help. I think a small mag mount on the roof would work better.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 03-03-2022, 02:20 AM #17
sierrahiker sierrahiker is online now
sierrahiker is on a distinguished road
I'm using a Larsen Middle Thickness NMO mount on a Cali Raised Ditch Light Bracket with a Rago Ham Antenna Extension. Ran 1/2" braided ground strap from the mount to the hood hinge bolt. SWR is ~1.7 @ 146MHz, ~1.3 @ 435MHz. Not great, but OK and the ground strap made a noticeable difference for me. Haven't tried to test max range, but have no problems hitting regional repeaters even on on low power. I tested various locations on the truck with a mag mount antenna; center of roof was definitely better, but I often carry a cargo box on the roof so roof mount was not a good option for me.
sierrahiker is online now   Reply With QuoteReply With Quote
Old 03-03-2022, 03:00 AM #18
This diagram illustrates the effect of antenna mounting location on ground plane and losses.
Old 04-25-2022, 09:01 PM #19
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
OP probably drilled a small hole in the plastic housing and used the provided 1/4-20 screw (or bought a longer one) to attach the radio unit.
Daikon is offline   Reply With QuoteReply With Quote
Old 08-21-2022, 08:29 AM #20
RaceAddict's Avatar
RaceAddict RaceAddict is offline
Real Name: Kevin
RaceAddict is on a distinguished road
RaceAddict's Avatar
Real Name: Kevin
That placement is ideal for a speaker in my opinion... I want my faceplate mounted a little more central, less "eyes off the road" but I definitely need to know how it's mounted up there. Speaker placement has been the one thing holding me back from installing a mobile setup. I've never seen one I liked.
2016 TRAIL - MGM
C4 Bumper - WARN VR10S
OME Lift - Prinsu Rack
Adventure Index DIY Storage System
Summer: Falken A/T3W (Winter: Nokian Hakkapeliitta 8 SUV)
RaceAddict is offline   Reply With QuoteReply With Quote
Old 08-21-2022, 11:05 PM #21
i put a small speaker in front of the shifter, blocking the useless storage cubby. (kinda gets in the way for big gulps though) Radio is in the center console. antenna is on the roof using a magnetic mount. Clear as can be. speaker isnt great, but thats cause i cheaped out.
hatch , mount , mounts , radio , rear
2 Antennas? toiday 4th Gen T4Rs 13 04-29-2022 10:39 AM
CB or HAM Radio and Antenna Mounts on 5th Gen rasber3140 5th gen T4Rs 15 05-21-2021 11:42 PM
antennas cary General Discussions 1 03-13-2011 09:22 PM
Any CB Radio Recommendations? PA Speakers? Antennas? Mr Castulucci Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-02-2005 04:14 PM
