Old 08-28-2019, 04:36 PM #1
Louisiana Overland's Avatar
Louisiana Overland Louisiana Overland is offline
Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough
HAM radio antennas and mounts
Ive searched and read many threads on this but still have a few questions on antennas
I bought the Yaesu FTM400xdm during the HRO summer sale and am currently studying for my FCC license. The next step will be installing the radio and antenna. I plan to mount the radio under the drivers rear seat and the face plate will likely mount to a RAM Mount stalk I put in for an ipad on a second xgrip right below the ipad. This is a dual band radio and requires a dual band antenna. Ive seen folks using ditch light brackes up front. Or, lip clamp mounts on hood edge or hatch edge. RAGO also makes a bracket that mounts along side the rear hatch at bottom of tail light. Im not crazy about the clamps...I fear they will eventually cause rusting. The ditch brackets I have read are too thick for the NMO mounts. So...
Has anyone used the rear RAGO mount for HAM successfully? If so, what antennas do you use?
For the ditch brackets, what is the solution to use the NMO mount and what ditch bracket specifically do you use? Several manufactures make these, and what antenna do you run?
For the lip mount crowd, are you experiencing any rust? What antenna? This would need to be located at drivers side on rear hatch to clear the vestibule on my roof top tent when opening the hatch while camping.
Any other advice on HAM antenna/radio install is appreciated.
Louisiana Overland is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 05:03 PM #2
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
I sent you the link to the antenna I am using right and the pics?
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 05:25 PM #3
Yes you answered questions and supplied pics in your build thread. I think a roof mount will interfere with the roof top tent. Ive seen a few who mount to the rack but would rather keep the overall height to minimum. Did you get your shimmy and radio sorted?
Old 08-28-2019, 05:49 PM #4
hawthornearms's Avatar
hawthornearms hawthornearms is offline
hawthornearms is on a distinguished road
They make thick and very thick NMO mounts. Most of them are 3/8" hole.
My recommendation is always "don't be afraid of the NMO mount hole". Mount that sucker center in the top, allowing room for the tent. Give the antenna a good counterpoise/ground plane and a high point to live off of.
I don't know how they perform out of band, but they probably do fine, we use a lot of the Laird C150/450C dual bands.
Forgot to add I own a commercial two-way shop, that's why I know how the C150/450C do at 460 MHz but not 440 MHz.
'19 4Runner Nightshade Edition
hawthornearms is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 05:59 PM #5
rochmpr's Avatar
rochmpr rochmpr is offline
Real Name: Krister
rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all
rochmpr's Avatar
Real Name: Krister
Do not mount the face in an X-grip as it messes with the GPS antenna. Somewhere in my build, I have info on the install and mounting of the same radio.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
rochmpr is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 06:09 PM #6
Maybe a ram ball mounted to the yaesu bracket that shipped with the radio instead?
Old 08-28-2019, 06:13 PM #7
With tent mounted there is no room to the rear. To the front I have a sunroof. So mounting to the roof is a no go. I could possibly do a short antenna on a crossbar above the sunroof. Is this advisable? How shortcan i get away with there?
Old 08-28-2019, 06:59 PM #8
KWSRStorm's Avatar
KWSRStorm KWSRStorm is offline
KWSRStorm has a spectacular aura about KWSRStorm has a spectacular aura about
KWSRStorm's Avatar
No issue with the lip mout on the hood with an nmo antenna.
For the rear i skipped the rago a got a firestick jamp mount to use with a cb. The rago will work if you grind the powder coat off and use a good ground strap.
Same for any ditch light bracket, make sure you grind the powdercoat off at the bolt where it kounts, and where the antenna attaches.A few companies have a ditch light braket woth an nmo hole.
As for what antenna, depends on your use. Do.you want dual band, what size could fit in your garage, do you want to hit repeaters 100 miles away? I have a nagoya 30$ 19 inch from amazon as my day to day. I have a longer one if i need it to do quad band repeating.
Sent from my SM-G973U using Tapatalk
KWSRStorm is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 07:00 PM #9
Yea I get it. Short + VHF doesn't exist. Best short antennas are transit mounts (ETRAB4503 for example) but they're only single band and the VHF ones kind of suck. Ok actually the VHF ones really suck.
How often to you put the tent on? Does the tent have anywhere you can mount the antenna? Stainless Steel L bracket like the Laird LBT8U, stainless screws, some Lexel to water seal everything is always an option.
Old 08-28-2019, 08:30 PM #10
rochmpr's Avatar
Real Name: Krister
rochmpr's Avatar
Real Name: Krister
I took a metric bolt and welded to an SAE bolt. It's not pretty, but it works well. Has not had any impact on the GPS.
Sent from my SM-G965U using Tapatalk
Old 11-06-2019, 04:48 PM #11
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
Now that I am prepared to take the exam, I have no idea where to begin choosing components for my 19 ORP. Where is the best resource to get an idea of what exactly I need to buy?
I am thinking about mounting the face in the console, and I like the idea of the ditch light mount as an antenna mount. pro's/con's/opinions?
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 05:25 PM #12
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
assuming you want mobile radio (not handheld), you need:
radio
radio control head remote mount kit if applicable (some radios can do this without a kit, others require you to buy stuff to mount the control head separate from the radio)
antenna
antenna mount
antenna cable if it didn't come with your mount
speaker for the radio (not strictly required, but if you are mounting your radio remotely you'll probably want an external speaker)
I have an FTM-400 which doesn't require anything to mount the head seperate from the radio, but I had to make longer cables for the mic and control head so i could put them where i wanted. easy to make, or you can buy online from n2rga.com
can you get a ditch light mount that will accept an NMO mount?
I use an NMO hood lip mount in the same area:
and a cheap antenna, trails near me are narrow so i use a cheap antenna so i don't need to care about if it gets damaged
antenna mount:
https://www.amazon.com/Tram-1246B-Bl.../dp/B00TSZ9SXS
antenna:
https://www.amazon.com/dp/B00IDTJ2KE..._BMZWDbYQ45G46
radio
You are being redirected...
radio install location:
jhguth is offline   Reply With QuoteReply With Quote
Old 12-16-2021, 11:05 PM #13
rsean10's Avatar
rsean10 rsean10 is offline
rsean10 is on a distinguished road
rsean10's Avatar
radio
antenna
antenna mount
antenna mount:
Amazon.com: Tram 1246B NMO Black Trunk Lip Mobile Antenna Mount w/ Cable : Electronics
antenna:
Amazon.com: Tram 140MHz-170MHz + 430MHz-470MHz Dual Band NMO Antenna (1181) : Electronics
radio
@jhguth that faceplate mounting location is awesome, how is it attached?
2010 TE, OME 2884/2895, OME UCAs
rsean10 is offline   Reply With QuoteReply With Quote
Old 12-17-2021, 11:45 AM #14
PrettyGoodSam PrettyGoodSam is offline
PrettyGoodSam will become famous soon enough
following!
PrettyGoodSam is offline   Reply With QuoteReply With Quote
Old 03-01-2022, 07:14 AM #15
Fadelio Fadelio is offline
Fadelio is on a distinguished road
Has anyone figured out how to mount the radio faceplate like that?
Fadelio is offline   Reply With QuoteReply With Quote
hatch , mount , mounts , radio , rear
2 Antennas? toiday 4th Gen T4Rs 13 04-29-2022 10:39 AM
CB or HAM Radio and Antenna Mounts on 5th Gen rasber3140 5th gen T4Rs 15 05-21-2021 11:42 PM
antennas cary General Discussions 1 03-13-2011 09:22 PM
Any CB Radio Recommendations? PA Speakers? Antennas? Mr Castulucci Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-02-2005 04:14 PM
