Old 08-31-2019, 02:40 PM #1
5point9limited 5point9limited is offline
5point9limited is on a distinguished road
VSC and Steering Wheel/! Lights on After Spiral Cable/Clock Spring Replacement-HELP!
Hello,
I have a 2011 SR5-Premium. The horn wasn't working, so upon dignosis, I replaced the clock spring/spiral cable with an EBay replacement for $35 vs. $500 OEM. I know the risks involved.
After I reinstalled everything, I noticed that the VSC "Skid/Swerve" light and steering wheel light with an exclamation mark were on. I tried to reset the code using the Zero Calibration method by jumping the OBD connectors to no avail.
From there, I disassembled the the steering wheel once again and boom, there it was, a small wire harness on the bottom of the CS assembly that i failed to reconnect. I reassembled everything and the lights disappeared!
Until a mile down the road. They both came back on, steadily lit. I drove the truck 30 miles with no issues.
I read on these forums that the lights are not easily cleared and usually have to be done at the dealer.
To avoid that trip, what should I do?
My Questions are:
Which code readers are capable of reading/resetting these lights?
Will TechStream be able to read and reset it? I have a Sequoia as well, and would love to use that software on it.
Do you have ANY input for me!
Here is a link to a video of what happens during Zero Calibration:
YouTube
VSC and Steering Wheel/! Lights on After Spiral Cable/Clock Spring Replacement-HELP!-4runner-lights-jpg
5point9limited is offline   Reply With QuoteReply With Quote
Old 08-31-2019, 06:00 PM #2
Deep_palancar's Avatar
Deep_palancar Deep_palancar is offline
Deep_palancar will become famous soon enough
You must clear the old data prior to performing the calibration.
The procedure document is attached. Read through the steps several times and plan ahead; note that the final step requires driving straight at 25mph for 10 seconds.
Get yourself a mini VCI and a copy of techstream even if this event is cured with
the jumper method, it's a must have item if you are going to own and work on Toyotas.
Deep_palancar is offline   Reply With QuoteReply With Quote
Old 09-01-2019, 02:09 AM #3
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
You can always try disconnecting the battery for 10 minutes and then reconnecting it. That might work if the cable isn't broken.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 09-01-2019, 09:06 AM #4
Originally Posted by Old Red View Post
Did you center the spiral cable before attaching the steering wheel on the column?
The spiral cable has 5 full turns before the internal cable gets tight. You most likely broke the cable inside and need a new spiral cable. When you install it, turn it one direction until you feel very slight resistance. Don’t turn it any more that direction. Turn the opposite way 2-2.5 turns so that the spot with the connectors is at the 12:00 position. Then install the steering wheel.
If you reach the end of the cable limit or are close to it when you install the steering wheel, and then rotate the wheel further when making a turn, the cable breaks, and the VSC and steering indicator light comes on and stays on.
Hope this helps.
First, thank you for taking the time to help. The spiral cable came with a tab that needed to be broken off before the install of the steering wheel. I imagine that was what kept it in place. Otherwise, no, I did not wind it up. Here is what it looks like. notice the orange tab.
VSC and Steering Wheel/! Lights on After Spiral Cable/Clock Spring Replacement-HELP!-spiral-cable-jpg
Old 09-01-2019, 09:08 AM #5
I am printing these directions right now. I have read before that the codes MUST be cleared. I was searching for these directions! I really appreciate it! I will report back. Thank you, again.
And yes, I need the TechStream!
Old 09-01-2019, 09:09 AM #6
I actually let it sit overnight... Thank you, though.
Old 09-02-2019, 06:54 AM #7
No problem. Get it fixed?
Old 09-02-2019, 04:51 PM #8
Not yet. I just got the TechStream items in the mail.
Old 09-03-2019, 12:49 AM #9
Dang well good luck man
Old 09-07-2019, 08:40 PM #10
So, I am "unsuccessful" in trying this reset. I used the Techstream program. I followed the directions the best I could, other than the fact that I was unable to drive for 25mph for 10 seconds.
However, the VSC light never flashed upon the reset process. Only the ABS light did. When I jumped the terminals with a paperclip, the light DID flash.
Also, using techstream, it states that I need to select the "Skid Control ECU" to clear the Zero Point Calibration. I cannot find that menu. I feel like that may be the missing link.
Any input is appreciated. I will be trying again in the coming days. This is frustrating!
Old 09-08-2019, 12:13 AM #11
You MUST clear the old data:
(7) Enter the following menus: Chassis / ABS/VSC/TRAC / Utility / Reset Memory.
(8) Select the skid control ECU to clear the zero point calibration data using the Techstream.
(9) Turn the ignition switch off.
Old 04-26-2020, 07:06 PM #12
Wazioc Wazioc is offline
Wazioc is on a distinguished road
Angry
This is killing me... I cannot figure out how to get these lights to turn off after replacing the spiral cable on my 2011 Trail Edition.
I've followed the instructions step by step and keep hitting endless loops where it says if the slip indicator light is not blinking, do it again... I gave up after repeating it 3 times in a row with no change. I also tried to push through the full document regardless and still exactly the same as when I started.
After I replaced this part the first time I took it to my local shop, they said they were getting an error that made it look like it was a hardware connection issue. Got and installed a whole new spiral cable and wanted to get more info so I bought a cable and got a copy of techstream.... Now I've wasted hundreds of dollars and tons of time and I'm still right where I started.
Anyone have any additional help or guidance to figure out how I can fix this? My vehicle inspection is now expired and I can't get it renewed until I fix the lights.
Wazioc is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 09:10 PM #13
sunapeelakers sunapeelakers is offline
sunapeelakers is on a distinguished road
You ever get this fixed?
sunapeelakers is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 05:34 PM #14
petron5000 petron5000 is offline
petron5000 is on a distinguished road
I have the same issue. My tech stream won’t clear the errors. Any luck taking it to a dealer to get cleared?
petron5000 is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 01:20 PM #15
Took it to the dealer. They won't clear the codes.
Want to sell me a new Clock Spring for $1300.
light , lights , reset , steering , wheel
How to install a Clock Spring a.k.a. Spiral Cable. Lugnutz 3rd gen T4Rs 36 06-11-2022 12:43 PM
Clock spring/spiral cable question Cisco Kid 4th Gen T4Rs 0 06-28-2017 03:33 PM
Spiral Cable (Clock Spring) Tedward 5th gen T4Rs 7 05-24-2016 09:47 AM
Wanted 96 4Runner clock spring / spiral cable enertronik Classifieds - buy & sell (no commercial ads please) 2 02-13-2011 04:33 PM
