Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
Old 09-02-2019, 08:53 AM #16
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
If your not handy. Find a shop that specializes in automotive electronics. It will be expensive for diagnosis, but they should be able to track down the issue. If there are any still in existence that is.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 12:13 PM #17
4R4Trout's Avatar
4R4Trout 4R4Trout is offline
4R4Trout will become famous soon enough
4R4Trout's Avatar
Another vote on checking your battery cables where they terminate on the battery. I have seen negative battery cable terminals super loose on a FJ to where you could just lift it off of the post.
2012 TE~Shoreline Blue~KDSS~Nav
ARB Diff Breather, Dobinson 302/700, 327/701, Yokohama Geolandar MT G003 255/75R17, ARB CKMA12 onboard air, IndeFlate, Arclight LED, Victory 4x4 Strike rear bumper, Kenwood TM D710GA Ham Radio, Engel MT-45, Method 701 (Black) UpTop Overland Bravo, 38” Extreme LED lightbar, Dobinson UCA
4R4Trout is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 11:15 AM #18
chihuahua chihuahua is offline
chihuahua is on a distinguished road
Thank you everyone for the help/recommendations on trying to find a solution to my problem.
I just picked up the truck last night from the Dealer.
Diagnosis:
-Check engine light finally turned on with code "P2610
Fix:
-Reprogram ECM
So far the truck is running like a champ.
again appreciates everyone time in looking into this.
chihuahua is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 12:21 PM #19
Narbeh Narbeh is offline
Narbeh is on a distinguished road
SAME PROBLEM HERE. What was the cause? Send me a DM OP. Thank you.
Narbeh is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 04:54 PM #20
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Diagnosis:
Fix:
-Reprogram ECM
Hmmm. So it was a goofy ECM that just needed a kick in the pants?
They found no other issues like wiring problems as others have mentioned?
Here’s a link with some more information on the problems that could generate a P2610 code.
P2610 ECM/PCM Internal Engine Off Timer Performance
Old 02-13-2020, 08:19 PM #21
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Botman this is an engine cutting off thread not a man not being able to pop off. Happy Hallmark Day
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 08:31 PM #22
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
What'choo mean? This thread is about (engine) non-performance. Perhaps dropping Michaeladadonse (aka Botman) into the gas tank might just improve performance.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 02:33 PM #23
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Does the battery light flicker? And does it light up at the start so you know bulb is working? Buy a bluetooth OBDII and Torque Pro app and see what the voltage is when youre driving and what codes there might be and start there.
Originally Posted by gfego1 View Post
Same thing is happening to my 2011, the ECO light starts flickering, then when I hit the brake, the dash electronics reboot. Happens after I've been driving for over an hour.
Here is the link to the video of it happening:
5th gen 2011 4runner dash shutting off while driving and applying brake - YouTube
In the video you don't see the full dash reboot, but a couple of instances of a partial reboot.
Any ideas?
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 02:55 PM #24
No stored codes, battery voltage nominal. Using a Sprint Drive device so I can check while driving. Just fine battery in green. I forgot to put that it reset the trip a/b mileage and the clocks. Today it also did it just after it started the car and put it into reverse gear having applied the brake.
Check the ground connections including the towing connector. Also check if brake bulbs are working.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 04-27-2021, 08:19 AM #25
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Did you ever find out what was going on with this? I had a similar problem this morning on my way into the office. I'm hoping its just a loose cable, but I'm afraid it might be the alternator or the charging circuit.
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 04-27-2021, 11:33 AM #26
Argyle Edison Argyle Edison is offline
Argyle Edison will become famous soon enough
I'm betting CPS issue
Argyle Edison is offline   Reply With QuoteReply With Quote
Old 04-27-2021, 06:22 PM #27
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
I've had this exact issue (granted it was on Jeep) but it turned out to be my ground wire was loose. Whenever I hit a bump the car and all electronics would shut off for a second or two and then restart.
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 04-27-2021, 07:09 PM #28
007Tacoma's Avatar
007Tacoma's Avatar
Talking C P S = CPS. Duh...
CPS... Let me Google that...
City Public Service
Cycles Per Second
Command Personnel Summary
Child Protective Services
Control Panel Subassembly
Corporate Project Solutions
Core Provider Switch
Computer and Peripheral Subsystem
Communist Party of Siam
Contingent Preferred Stock
Chicago Public Schools
C'est Pas Sorcier (French: It's not Rocket Science)
Certified Pedigree Swine
Cool People Syndrome
Charge Position Sensor
Charismatic Pet Sasquatch
Clustered Penal Station
...Okay... I have to admit I stopped searching after Certified Pedigree Swine and started making up my own.
I'm 007Tacoma.
Old 04-27-2021, 07:11 PM #29
007Tacoma's Avatar
007Tacoma's Avatar
I'm hoping that was my issue... but the cyclical pulse of the headlights tells me I might be wrong.
I'm 007Tacoma.
Old 04-28-2021, 11:28 AM #30
Cam Position Sensor, but I'd assume you would have codes if there was a problem. If it's aggrevated by using the brakes I would have a look at the towing harness wires in the back that are easily damaged. And the brake lights. Assuming the voltage is normal and not battery or alternator.
By cyclical with headlights do you mean regular intervals?
City Public Service
Cycles Per Second
99 SR5 v6 4WD
11 SR5 v6 4WD
driving , engine , engines , stereo , times
Weird Noise After Shutting Off Engine Stockton 5th gen T4Rs 38 03-07-2022 05:38 AM
Need input!! Engine shutting off Questionable 3rd gen T4Rs 10 05-08-2021 05:28 PM
4R shutting down while driving carrot6993 Problems & Warranty Issues 16 04-06-2021 12:07 PM
HELP! Engine Shutting off Randomly. Sotovo 3rd gen T4Rs 28 07-26-2020 07:46 PM
2006 4Runner Engine Shutting Off While Driving Mikasa67 4th Gen T4Rs 41 08-21-2015 02:09 PM
