09-02-2019, 08:53 AM
#16
If your not handy. Find a shop that specializes in automotive electronics. It will be expensive for diagnosis, but they should be able to track down the issue. If there are any still in existence that is.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
09-02-2019, 12:13 PM
#17
Another vote on checking your battery cables where they terminate on the battery. I have seen negative battery cable terminals super loose on a FJ to where you could just lift it off of the post.
2012 TE~Shoreline Blue~KDSS~Nav
ARB Diff Breather, Dobinson 302/700, 327/701, Yokohama Geolandar MT G003 255/75R17, ARB CKMA12 onboard air, IndeFlate, Arclight LED, Victory 4x4 Strike rear bumper, Kenwood TM D710GA Ham Radio, Engel MT-45, Method 701 (Black) UpTop Overland Bravo, 38” Extreme LED lightbar, Dobinson UCA
09-06-2019, 11:15 AM
#18
Thank you everyone for the help/recommendations on trying to find a solution to my problem.
I just picked up the truck last night from the Dealer.
Diagnosis:
-Check engine light finally turned on with code "P2610
Fix:
-Reprogram ECM
So far the truck is running like a champ.
again appreciates everyone time in looking into this.
12-10-2019, 12:21 PM
#19
SAME PROBLEM HERE. What was the cause? Send me a DM OP. Thank you.
12-11-2019, 04:54 PM
#20
Banned
Real Name: Mark
Banned
Real Name: Mark
Diagnosis:
Fix:
-Reprogram ECM
Hmmm. So it was a goofy ECM that just needed a kick in the pants?
They found no other issues like wiring problems as others have mentioned?
Here’s a link with some more information on the problems that could generate a P2610 code.
P2610 ECM/PCM Internal Engine Off Timer Performance
02-13-2020, 08:19 PM
#21
Botman this is an engine cutting off thread not a man not being able to pop off. Happy Hallmark Day
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
02-13-2020, 08:31 PM
#22
What'choo mean? This thread is about (engine) non-performance. Perhaps dropping Michaeladadonse (aka Botman) into the gas tank might just improve performance.
When in trouble - obfuscate
04-20-2021, 02:33 PM
#23
Does the battery light flicker? And does it light up at the start so you know bulb is working? Buy a bluetooth OBDII and Torque Pro app and see what the voltage is when youre driving and what codes there might be and start there.
Originally Posted by gfego1
Same thing is happening to my 2011, the ECO light starts flickering, then when I hit the brake, the dash electronics reboot. Happens after I've been driving for over an hour.
Here is the link to the video of it happening:
5th gen 2011 4runner dash shutting off while driving and applying brake - YouTube
In the video you don't see the full dash reboot, but a couple of instances of a partial reboot.
Any ideas?
99 SR5 v6 4WD
11 SR5 v6 4WD
04-20-2021, 02:55 PM
#24
No stored codes, battery voltage nominal. Using a Sprint Drive device so I can check while driving. Just fine battery in green. I forgot to put that it reset the trip a/b mileage and the clocks. Today it also did it just after it started the car and put it into reverse gear having applied the brake.
Check the ground connections including the towing connector. Also check if brake bulbs are working.
99 SR5 v6 4WD
11 SR5 v6 4WD
04-27-2021, 08:19 AM
#25
Real Name: Mark the Common Sense Wizard
Did you ever find out what was going on with this? I had a similar problem this morning on my way into the office. I'm hoping its just a loose cable, but I'm afraid it might be the alternator or the charging circuit.
I'm 007Tacoma. ...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
04-27-2021, 11:33 AM
#26
I'm betting CPS issue
04-27-2021, 06:22 PM
#27
I've had this exact issue (granted it was on Jeep) but it turned out to be my ground wire was loose. Whenever I hit a bump the car and all electronics would shut off for a second or two and then restart.
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
04-27-2021, 07:09 PM
#28
C P S = CPS. Duh...
CPS... Let me Google that...
City Public Service
Cycles Per Second
Command Personnel Summary
Child Protective Services
Control Panel Subassembly
Corporate Project Solutions
Core Provider Switch
Computer and Peripheral Subsystem
Communist Party of Siam
Contingent Preferred Stock
Chicago Public Schools
C'est Pas Sorcier (French: It's not Rocket Science)
Certified Pedigree Swine
Cool People Syndrome
Charge Position Sensor
Charismatic Pet Sasquatch
Clustered Penal Station
...Okay... I have to admit I stopped searching after Certified Pedigree Swine and started making up my own.
04-27-2021, 07:11 PM
#29
I'm hoping that was my issue... but the cyclical pulse of the headlights tells me I might be wrong.
04-28-2021, 11:28 AM
#30
Cam Position Sensor, but I'd assume you would have codes if there was a problem. If it's aggrevated by using the brakes I would have a look at the towing harness wires in the back that are easily damaged. And the brake lights. Assuming the voltage is normal and not battery or alternator.
By cyclical with headlights do you mean regular intervals?
City Public Service
Cycles Per Second
99 SR5 v6 4WD
11 SR5 v6 4WD
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
