01-11-2017, 12:19 AM
Icon Coilovers to Achieve Softer than OEM Suspension?
Guys, a little background. I adore my '16 SR5 4x4 and would like to do a front leveling. This truck will be 99% commuter. I just did TRD Pro's and 265/70-17 KO2's. I actually don't want to do front and rear Daystar, I only am interested in doing the front spacer to bring it up a bit. My question is, is there any shock/spring/ coilover setup out there, whether OME, Fox, Icon, etc that will ride softer than stock? I've searched quite a bit and haven't found any conclusive information. My 4Runner buddy says it's impossible to achieve a softer than stock ride, but that can't be the case can it? I know 5100's are totally out as they will for sure be stiffer. 6112's don't seem any softer than stock. So it seems I'm looking at an Icon coilover or similar setup. Any ideas?
'16 SR5 4x4. OEM TRD Pro's. Falken Wildpeak AT3W 265/70-17, Toyota All-Weather mats.
01-11-2017, 12:51 AM
If your looking for just front shocks I wouldn't recommend just front shocks. If your looking for front lift just get an inch spacer and be done or pick up someone's TRD PRO suspension. If you want better suspension get it. I have Fox 2.5 F+R and it rides like a dream IMO. YMMV.
2016 Super White SR5P 4Runner 4X4
Mods:TRD Wheels, TRD CAI, TRS LED Fogs, Outgear Solutions Rack, Rigid Ditch Lights, X-Wing Sliders, Icon Uniball UCA, AirLift 1000, Fox 2.5in XT front and rear with Icon 2in lift springs, 285/70/17 BFG KO2.
01-11-2017, 09:06 AM
What exactly do you mean by soft? Passengers feel almost nothing over curves or bumps?
Sent from my Pixel using Tapatalk
Newb | 2014 LTD | Silver | Stock aside from really dark tint and Maxliner MAXFLOORMAT set | actively researching lifts and tires
01-11-2017, 09:27 AM
If you want a soft ride I would not go with icon. They are great over big stuff but we're rigid over pot holes and bridge abutments.
01-11-2017, 09:34 AM
Real Name: Will
Real Name: Will
It's going to be hard to get softer than the mushy pile of shit that is the stock suspension. I would advise you to contemplate if the 4runner platform is appropriate for your needs and decide if you need to sell it for a Cadillac
01-11-2017, 11:57 AM
@ marshal
, I want you to work on your “directness”.... I don’t think you’re getting your point across clearly.
2017 Porsche Macan GTS - Carmine Red w/ matching side blades
2014 Black TEP w/ KDSS / nFab steps / Yakima Cross Bars / Bilstein 5100s (front at 1.75) / 1 inch rear Cornfed Spacers / FN Countersteer Type X / Nitto Terra Grappler G2s 265/70/R17 / RCI Aluminum (front) Skid - sold
2011 Silver Limited - sold
2007 SE Shadow Mica - sold
01-11-2017, 12:52 PM
OP, I am interested in this too. I drive >4000 miles a month, every month. It is all highway 75mph+ driving and I can't stand the way 5100s feel when you drive 8 hours in one day. I put the stock suspension back on.
I've considered going back to a C Class, but I take this in the woods at least 2x a month and would miss that too much.
01-11-2017, 01:35 PM
Keep the stock ride with a 1" spacer up front. It will give you 2" of lift.
01-11-2017, 01:46 PM
I've been in my icon for a month. Previously I was on XREAS. I agree with you.
01-11-2017, 04:34 PM
That can be said for any platform anywhere. You can lower an Escalade and make it handle. You can even make a fox body Mustang handle. You can lift a 2WD 4Runner, etc. People like going different ways to suit their different needs. I love the 4Runner platform, and since I plan to do shocks or spacers of some kind, I figured I would ask. My question on softening the truck pertains mainly to the rear. It feels like it could use a few 100lb sand bags in the cargo area. If there are no other rear spring/ shock options available to me that would soften the ride and make it ride like a Prerunner (stock height or otherwise), then I will accept that completely! I just wanted to pose the question to see if I had any options.
01-11-2017, 05:31 PM
Give king a call! Their OEM kit comes with very soft springs (550lb I believe). You can also discuss spring options with them.
I have the compression adjust in the rear, and you can adjust it to be stiff, or comfortably soft for the highway. I have mine on setting 4 of 20. Loaded up with gear in the woods, stiffer feels better to me.
regardless-- I'd explore spring options if you're looking for a very soft ride. I would definitely describe king as soft, but you can make it rigid with heavier springs. With no preload, their OEM series will level everything out.
They're great to talk to, I was amazed by their customer service.
just my $.02
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
01-11-2017, 06:02 PM
King is king. Mine rides super plush over bumps and on the road, but still firm enough on the road. The TRDP shocks I had before rode pretty similarly.
Spacer lifts suck. All you'll do is get a shitty ride when you preload the springs to get lift. Maybe not at 1/2 or so, but you'll feel it at 1" or more.
IG @go.xplre
01-11-2017, 06:13 PM
I did call King but they promptly told me none of their coilover packages would be softer than stock in any way. It was a brief phone call lol.
I thought the spacer goes above the spring/strut assembly. How does that preload the spring?
01-11-2017, 07:13 PM
It depends on the manufacturer. Some go on top of the assembly, essentially retaining the same ride while others require disassembling the CO and do pre-load the spring. Some do both.
2012 SR5 4WD in Blizzard Pearl - traded in
2016 Limited in Barcelona Red
01-11-2017, 11:27 PM
Real Name: Ray
Real Name: Ray
I have an Icon Stage 2 lift on my 4th gen and it rides extremely stiff. The ride was so... much softer (close to factory) with a 3/2 spacer kit. You should also consider cost. King is high end and will cost you mucho dinero. A spacer kit on the other hand is very inexpensive and gets the job done.
2016 Trail Edition. Prinsu Roof Rack, Rigid 50" Midnight Light Bar, Ditch and Fog Lights, Icon Stage 2, Icon Rebounds, TRD CAI, Flowmaster 60 series.
