Old 09-01-2019, 09:46 PM #1
Cheers!'s Avatar
Cheers! Cheers! is offline
Cheers! will become famous soon enough
Cheers!'s Avatar
Q on 5th gen limited trim diff and transaxle oil change
Hi T4R experts,
Is the differential oil change on a Limited Trim 4Runner the same procedure and spec as the rest of the 4Runner line up?
Same question for for the transaxle.
Thanks in advance!
Cheers! is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 11:20 AM #2
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
There is no transaxle on this vehicle. For the 4 wheel drive system there's a transfer case, a front differential, a rear differential, and a transmission.
waypoint is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 12:36 PM #3
Cheers!'s Avatar
Cheers!'s Avatar
Right. apologies on the loose terminology being used.
I looked through the factory service manual. It looks like the only difference I could tell is the full time AWD transfer case is that the limited transfer case takes 1.5qts of oil instead of 1.1qts.
The front and rear differential amounts seem to be the same as the other trim levels.
Old 09-02-2019, 01:07 PM #4
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
All procedures are the same on the Limited.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 12:03 AM #5
Cheers!'s Avatar
Cheers!'s Avatar
Perfect! Thanks so much
4runner , change , oil , transaxle , trim
Change that diff oil Wizzard 5th gen T4Rs 40 06-11-2019 09:20 PM
Expected left transaxle repair cost jaxinmontana 3rd gen T4Rs 8 06-28-2014 03:20 PM
1990 diff change oldredrunner Classic T4Rs 2 01-15-2014 09:10 AM
1990 diff change oldredrunner Classic T4Rs 3 01-14-2014 11:05 AM
