Old 09-02-2019, 09:06 AM #1
Drew1122 Drew1122 is offline
Drew1122 is on a distinguished road
2015 Limited front suspension creak
Hi Folks, I have a 2015 Limited 4wd, completely stock with only 28,000 miles.
There is a creaking noise in the front suspension when going over small bumps etc, also when turning the steering wheel back and forth at slow speeds. Sounds like it's coming from the front left but not 100% sure. Sounds like a dry bushing somewhere.
Have lubed the hood latch, rubber piece under the wheel well that makes noise on some Runners, the drive shaft, and also took apart the sway bar bushings and cleaned and lubed those with silicone grease.
Anyone know of anything else to check? Thanks...
Drew1122 is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 11:09 PM #2
fr4c fr4c is offline
fr4c is on a distinguished road
Check the fender liners behind the wheel; it is held together by a clip. The noise on my Limited was caused by the liner being loose. I used a small zip tie where the clip was and that solved my squeak.
2019 Voodoo Blue TRD Pro
fr4c is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 11:52 PM #3
Gecko's Avatar
Gecko Gecko is offline
Gecko is a jewel in the rough Gecko is a jewel in the rough Gecko is a jewel in the rough
Gecko's Avatar
Seems like there is a thread on this posted almost every day...
I had the same issue, for what it’s worth, and mine showed up around 26k miles. Just traded in for a 2019.
2021 Lexus GX 460 Luxury , Atomic Silver/Black @LandCruiserDNA
Previous: 1999, 2016 and 2019 4Runners
Gecko is offline   Reply With QuoteReply With Quote
front , limited , noise , sounds , wheel
Strange suspension creak when compressed deodra 4th Gen T4Rs 0 08-07-2018 02:16 PM
Front Suspension Creak Xtremluck 5th gen T4Rs 20 12-04-2017 01:39 PM
Unknown Creak from front right suspension assembly, not ball joints, wheel bearing?? ryanbigcheese Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-22-2014 07:39 PM
Suspension(?) creak when making sharp right turn dfjelstul 4th Gen T4Rs 5 03-14-2008 01:10 PM
Front Seat Squeak/Creak '03 Limited bluduk15 Problems & Warranty Issues 2 02-04-2004 11:25 PM
