2015 Limited front suspension creak
Hi Folks, I have a 2015 Limited 4wd, completely stock with only 28,000 miles.
There is a creaking noise in the front suspension when going over small bumps etc, also when turning the steering wheel back and forth at slow speeds. Sounds like it's coming from the front left but not 100% sure. Sounds like a dry bushing somewhere.
Have lubed the hood latch, rubber piece under the wheel well that makes noise on some Runners, the drive shaft, and also took apart the sway bar bushings and cleaned and lubed those with silicone grease.
Anyone know of anything else to check? Thanks...
