Old 09-02-2019, 04:12 PM #1
silverslug silverslug is offline
silverslug is on a distinguished road
Icon Stage 1 Lift Kit Questions
Just got my stage 1 lift kit installed with SPC UCAs. Love the ride, both on and off road. However, my installer had to make serious coilover ride height adjustments to the front ride height in order to get the T4R level. Initially it was about ⅝” lower on the driver side. After the adjustments (and realignment) it is now level at aprox. 23” from hub to bottom of fender opening. The problem is that there are almost twice as many threads showing on the driver side vs. the passenger side now -- 2 inches of threads on driver side vs. 1 inch of threads on passenger side!. My questions are:
Is this normal as my installer is telling me?
If it isn’t normal, what’s wrong with the installation?
Will it cause any problems with the coilovers and/or degrade performance?
Thanks in advance for any advice you guys can provide.
Truck after lift:
Driver side coilover threads:
Passenger side coilover threads:
2019 T4R TRD ORP Silver | BFG KO2s | RSG Sliders | Rago MSP | SSO Roof Rack | Icon Stage 1 | CBI Steel Skid Plates
2005 UZJ100 LC | 200k miles strong
silverslug is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 05:47 PM #2
Fern's Avatar
Fern Fern is offline
Fern will become famous soon enough Fern will become famous soon enough
Fern's Avatar
It is known as the driver side lean. It's normal.
2005 4R V8 4x
Fern is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 05:51 PM #3
cmilviper's Avatar
cmilviper cmilviper is offline
cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice
cmilviper's Avatar
Yep, Very normal to have significantly more pre-load on the driver's side, to get it leveled out.
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
cmilviper is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 05:58 PM #4
Thanks, Guys! Aware of the driver side lean, but didn't think it would take so many turns on those threads to correct a 5/8" inch lean. That makes me feel much better with a Moab trip coming up in 2 weeks. CBI steel skids going on this week and then ready to roll.
Old 09-02-2019, 07:07 PM #5
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
Not to send off any alarm bells, but I do think that 1 inch more preload to make up for 5/8" driver side lean is quite excessive. Now I wish i could point to something for you to check out, but there is not any reason you should have to have it cranked 1" more on one side to make up for 5/8" lean. That should be maybe 2 turns of the coilover, three at the VERY most to make up for that.
That 2" preload makes you almost maxed out on one side... not right in my opinion. I also think that with 2" of thread showing, you should be higher than 23" also. I have 2" threads showing on both of mine, and with that I'm at 23" with a hybrid bumper, 10,000 lb. winch, and lightbar up front which dropped the front about 1/2" from the weight.
I wouldn't worry too much about the 23" you are getting on both sides now, as much as having one side cranked so much over the other. I just thought I would add that detail, just to give you an idea on what height someone else is getting!
Your mileage may vary, but that is just my 2 cents.
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 07:49 PM #6
Thanks for your input @4runnin4mylife .... those were my thoughts exactly. I would have expected maybe a half-inch difference between the threads showing on the driver vs. passenger side to level it out, NOT almost a whole inch. I just can't figure out what else would be causing the installer to have to crank so much preload in order to level things out left to right. I also notice with the current setup that almost all the rake is gone vs. stock and had expected the front to be about 22 inches, not 23. Maybe I need to have him lower the entire front end by about 1/2 inch?
I don't care much about the lift; I'm really more interested in getting the best compression and rebound possible and having the least amount of driver side lean as possible. Perhaps it would be worth leaving a little of the driver side lean???
Old 09-02-2019, 10:53 PM #7
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 has a spectacular aura about shrub1 has a spectacular aura about
shrub1's Avatar
Post a pic of your driver CV boot.
shrub1 is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 11:50 PM #8
Smile
Interesting observation!! Driver side CV joint angle definitely greater ...
Driver side CV boot:
Passenger side CV boot:
Old 09-03-2019, 12:48 AM #9
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Can you measure your down travel (fender to a convenient spot on the hub) and tell us how much travel you have pax and driver (no need to post the fender to hub distances)? Apparently, the correct way is to jack the front and then measure as both are at full droop and not wheel by wheel.
And also your lift size.
On the face of it, one inch between sides sounds too much. I am no expert but the normal amount needed to compensate is 0.4" -0.5" inches of lift so less than that on the shock.
EDIT: also, lift on any one corner affects the diagonally opposed corner. What is your case in the rear?
Old 09-03-2019, 10:15 AM #10
shrub1's Avatar
shrub1's Avatar
If you just got this installed it will settle some.
We have pretty much the same set up and I gave up on measurements and started to pay more attention to CV boot rub and to even out both sides as much as possible with minimal bellow contact. Even though Icon calls out max at 2.13 max for exposed treads thats way too high for my rig. I ended up with 16 threads exposed on driver and 9 on passenger and both sides are at 22.5. Some rigs can handle more preload with less boot rub..wasn't the case with mine which is why I focused on boot rub and adjusted from there.
From your pics your inner boots look ok, but the outer boot seems a touch deformed.
Old 09-03-2019, 10:31 AM #11
I'm with MAST4R on checking on this bolded part above! What are your measurements in the rear? Is there possibly a spring not seated correctly on the REAR passenger side making it sit higher, therefore compressing the FRONT driver side more? Which the installer then cranked down on coilover to make up for. Just throwing some ideas out there. Those CV's are at quite the different angle also. I will chime back in if I think of something else.
Old 09-03-2019, 04:42 PM #12
Thanks so much, guys. I measured the rear and it's very close (within 1/8") to level between Drive and PAX sides. I also called Icon today and they are going to review my input and everything on this thread to try and determine what the cause might be. They are also suggesting that I have my installer back off the threads on both sides by maybe 2 turns, which should lower the entire front end by about 1/4 of an inch. Since the driver side is right at 2 inches now, this would give it a bit more leeway (2 1/8" being the most they suggest). Let's see what Icon says, but I really help everyone's input here and hope to get the issue solved soon. Will definitely share what I learn with everyone for future reference. Cheers, Steve.
Old 09-04-2019, 01:11 PM #13
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
What did your front hub to fender measure out at?
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 02:04 PM #14
shitty shitty is offline
shitty is on a distinguished road
Is it possible they gave you two different rated springs? +/- 50lbs?
shitty is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 10:53 AM #15
any updates on this situation from ICON?
coilover , driver , ride , side , threads
Icon Stage 6 Installed Today, I Have a Few Lift/Alignment Questions JimJr15 5th gen T4Rs 10 01-19-2018 07:00 PM
icon stage 1 lift kit Tigerfan86 4th Gen T4Rs 0 07-24-2017 05:36 PM
WTB: ICON Stage I Lift 4th Gen shirlth85 For Sale: Suspension/Wheels/Tires 4 04-26-2017 02:15 PM
Icon stage 1 lift question Metalhead77 5th gen T4Rs 10 05-10-2011 06:30 PM
