11-03-2014, 05:04 PM
Replace SR5 rocker panels with TE ones
I want to add Bud Built Rock sliders to my new to me 2011 SR5 4Runner. All the slider manufacturers state that one can only install their sliders on Trail Edition T4R’s. The bolt on rocker panels on the SR5, Limited, etc. T4R’s are a couple inches taller than the TE ones.
So the question is: can I remove my SR5 panels and just install a set off a Gen 5 trail edition T4R? Or is there additional issues with matching up the front and rear wheel well sheet metal with a TE?
I found a set of TE rocker panels off a wreck. don’t want to order them and have them shipped here just to find out that they don’t work.
Dale
11-03-2014, 05:10 PM
Real Name: Jordan
Real Name: Jordan
Originally Posted by WU7X
I want to add Bud Built Rock sliders to my new to me 2011 SR5 4Runner. All the slider manufacturers state that one can only install their sliders on Trail Edition T4R’s. The bolt on rocker panels on the SR5, Limited, etc. T4R’s are a couple inches longer than the TE ones.
Dale
Won't work. Fenders won't match up.
Shrockworks has a trim kit that works.
11-03-2014, 05:25 PM
Wow! that was a quick reply, and with the info I needed. thank you!
11-03-2014, 05:50 PM
Banned
Banned
get the 2014/15 sr5/te rocker parts... looks better than shrockworks
11-03-2014, 06:37 PM
Actually it works kind of, 2014 Trail Rocker Trim
2014 Trail Edition<-2006 Sport Edition<-1994 Limited
11-03-2014, 06:46 PM
I have a 2014 sr5 and mistakenly bought the Shrockworks trim kit which I found out later I did not need.
So.. you can either buy my kit from me for cheap OR buy a new 2014 sr5 rocker panel set from Toyota (But that is probably stupidly expensive)
I will honestly say that of the two you want the Toyota rocker panel. It keeps mud from being flung up under the doors a lot better.
The Shrockworks trim kit was really meant for earlier gen 5 like you have but fit mine perfectly, using all the same rocker panel mounting holes. So I would assume that the 2014 sr5 rocker panel would fit on the earlier gen 5 body as well...
11-03-2014, 09:28 PM
Real Name: Jordan
Real Name: Jordan
Originally Posted by crackiswack
Yep ends up about $600.
I guess if you found a wrecked 2014+ one then do that.
11-03-2014, 09:48 PM
Yeesh, for two pieces of unpainted black plastic and a few plastic snap fasteners :P
I'll sell my Shrokworks ones for like $50 plus shipping. They are missing the little drywall fasteners that were used to hold them on but that's like another $10 from home depot.
11-03-2014, 11:14 PM
Dale
Yes, they will fit. However, for the front you will have to buy these to match up the front:
2014 front trim covers
75857-35010
75858-35010
And the rear door fenders will slightly stick out cause the trail rocker trim is slimmer on the rear but is hardly noticeable.
2013 SR5 4x4 Classic Silver
RevTek 3/2 | 18" Ultra Gauntlets in 285/65/18 Trail Grapplers | 1" Bora Spacers | AFE CAI | Magnaflow 12256 | Camelback Metal Gear Roof Rack | ToyWerx 'Raptor' Grill
20" LED Bar (Behind Grill) | Under-Hood LEDs | 3 Cans of Plasti-Dip
11-03-2014, 11:16 PM
Warthog, I sent you a PM.
02-12-2016, 07:50 PM
Real Name: Sean
Real Name: Sean
I know this is an old thread but the information is kind of scattered and I am just hoping for some clarification:
I have a 2016 SR5, will I or will I not need to cut/replace the rockers and trim to install "TE Only" runners/steps/rails?
2004 Lexus IS 300 - Current Vehicle
2016 MGM SR5 4x4 w/Entune Premium and 3rd Row - Traded In July 2017
2000 Echo setup for SCCA SMF Class - Totaled Nov 2015
Lexus Certified Service Technician - Lexus of Austin - Austin, TX
ASE Master Certified
02-12-2016, 08:03 PM
Real Name: Halko
Real Name: Halko
Nope, your current rocker is the same as the trail, the above was regarding 10-13 SR5 and all LE.
Edit: You dont have KDSS either, just in case you weren't aware when you are looking at steps.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
02-15-2016, 11:18 AM
Real Name: Sean
Real Name: Sean
Thanks, it was just that when I was searching I couldn't seem to get a solid answer on the 2014 and up rockers and this seemed the most appropriate place to ask.
Yeah, I'm aware of the suspension I've got so that's not a big deal. I was a Toyota/Lexus Tech for about 7 years, so it's more that I'm just fuzzy on some of the less obvious idiosyncrasies between trim levels.
EDIT: And now, after re-reading, I realize I missed Warthog's post about 2014 rockers, which was quoted directly above my post ... smh
02-16-2016, 03:59 PM
Real Name: Michael
Real Name: Michael
if these don't go I will take some of that action.
THX
2013 Silver SR5 Third Row, Entune, SCS Ray 10 DRK BZN 285/70 17 BFG KM2, Satoshi Grill, Icon Stage 2, Total Chaos UCA, Canvasback, Ezei Awn K9 2.2 rack, Pelfreybilt Sliders
09-10-2016, 09:40 PM
@ Midnight Anvil
- Curious if you've gotten the budbuilt sliders installed on your T4R?
I'm looking at ordering one for my 2015 SR5 and wanted to make sure there was no need for the TE rockers on my 2015 SR5.
