Old 12-19-2022, 08:00 PM #1
drkb63 drkb63 is offline
drkb63 is on a distinguished road
Eibach Front Springs Question
Greetings everyone. I have the Eibach Pro Truck Lift System (Stage 1) on the highest settings (2.75" front, 1" rear). I purchased a C4 lo pro bumper (75lbs) and Smittybuilt winch (67lbs) recently and was wondering if anyone knows whether or not the Eibach springs I have will support the new weight without sagging or if I will need newer/different springs.
The lift has been on the truck for about 1000 miles and sits level, which of course, is the stance I'd like to keep. Thank you for any input you can provide.
2022 SR5 Premium XP
drkb63 is offline   Reply With QuoteReply With Quote
Old 12-20-2022, 11:39 AM #2
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
I just finished installing the Pro Truck Stage 2 system on my 2018 TRDORP. I went with heavier springs on the rear when I bought this kit. I have a low profile bumper similar to C4 built by Artec, and a Harbor Freight winch, and I got 1" of lift on the front and 1-1'2" on the back (I had leveled my stock front before this, so those numbers started out with a level stance) right out of the box. I'm not set up on the highest for the front, I have room, but I am allowing a little rake so that when I load up it levels out. Plus, honestly, it looks good with a little lift and still raked.
Does anything I'm typing equate or help? I don't know... but I think the best answer is to reach out to Eibach. They take customer service pretty seriously, and when I thought I'd only get an email back, they actually called me to talk it through. My setup is similar to yours, but I do have different components.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 12-20-2022, 11:48 AM #3
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
I had the same exact set up - the lift dropped almost an inch.
When I called Eibach to ask them about it, they told me they had no clue how a bumper and winch would affect the suspension.
It was clear they hadn't actually tested their suspension offering IRL.
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 12-20-2022, 01:44 PM #4
Thank you for taking the time to respond. While different parts can have different weights, it would only make sense to me that there would be some sag associated with adding 150 lbs to the front end. I'll probably give Eibach a call to see what they have to say.
2022 SR5 Premium XP
Old 12-20-2022, 08:27 PM #5
Thank you for the response also. I called and spoke with someone in customer service. He said the front springs should support the weight of the new bumper and winch. Respectfully, based on the few posts I've read, including yours, I'm thinking there will be a little drop. I'll have to consider a new set of front springs as that will likely be the most affordable option. Thanks again.
2022 SR5 Premium XP
Old 12-21-2022, 07:28 AM #6
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
You should be running a 650 lb spring rate with that combo. The stage 1 Eibachs are probably 550lbs and will sag about an inch with your bumper/winch combo.
TRD PANTHER is offline   Reply With QuoteReply With Quote
eibach , front , lift , springs , truck
Fs: Toytech/Eibach front lift springs 98runnerelock For Sale: Suspension/Wheels/Tires 4 01-05-2017 09:43 PM
WTB: Toytec/Eibach Front Springs Taylor20 Want to Buy/Trade 0 06-12-2015 11:16 AM
Eibach Front Coil Over Springs $140 sn0wrunner For Sale: Suspension/Wheels/Tires 8 03-29-2012 05:09 PM
